Question about Seagate 36GB Savvio 15K SAS 2.5" SCSI Hard Drive
How can i put a sas hdd in my laptop?any coverter scsi avaible?
  • 558 Answers
If your laptop has a sas drive in there already yes as the interface is the same if not forget it. There is no physical adapter for it.use it externally in a case.
Posted on Sep 12, 2009
Trying to find the jumper settings for a Seagate 36G 80PINS SCSI 15K RPM HDD Hard Drive with an apparent part number 8E036JO (all my Google searches say it's a Maxtor), but the one I have is Seagate....
SCSI hard drives and devices have a jumper setting to configure the SCSI ID.
Each SCSI device must have a different ID.
The jumper/s are set for the following positions across 3 pairs of pins
: : : = SCSI ID = 0 no jumpers - usually for the boot hard drive
: : I = SCSI ID = 1
: I : = SCSI ID = 2
: I I = SCSI ID = 3
I : : = SCSI ID = 4
I : I = SCSI ID = 5
I I : = SCSI ID = 6
I I I = SCSI ID = 7
This gives a total of 8 possible SCSI devices on one SCSI controller.
Aug 25, 2011 | Maxtor 8E036JO 36G 80PINS SCSI 15K RPM HDD...
My computer malfunctioned and I took out the hard drive to try and retrieve my files using a USB cable. I am stuck
Your hard drive has no USB port, it has a (seral) SATA 3 GB/sec interface, currently and
by far the most popular used on laptops, and also desktop computers. The SATA (serial advanced technology interface) 3 GB/Sec is version 2.0 of the SATA standard.
So, you'll need another laptop or desktop with a spare SATA 2.0 port, or a spare SAS (Serial
Attached SCSI) port, since SATA drive may be attached to SAS backplanes, as well as SATA backplanes. For a laptop, you may need to use the eSATA connector/cable
(see http://en.wikipedia.org/wiki/ESATA#eSATA for eSATA technical specs and a photo).
May 13, 2011 | Seagate MOMENTUS 7200.4 320GB SATA SATA...
Ultrium 920 sas install problem
update your SCSI controller drivers and power cycle the server
May 05, 2010 | HP StorageWorks Ultrium 920 LTO-3 Tape...
Connect ide or sata drives to a dell poweredge 2600 for additional storage
Yes and No..
The standard machine only allows SCSI, (no IDE or SATA or SAS connectors...
However SCSI drives are not cheap.. so
To overcome the power issue (you will notice there are no 4 pin molex connectors, or sata power connectors). However there is a 4 pin molex socket on the SCSI backplane. You can use one of those molex adaptor cables (one connector to many) to get power, from the molex you can use a 4 pin to SATA power connector.
Next step is to decide the drive you want to use. I personally use SCSI, SATA, SAS and IDE in mine (overkill I know).
Cheapness says use IDE or SATA. You can get a pci IDE/SATA controller card on ebay dirt cheap (PCI cards are compatible with the large PCIX slots), they dont take the entire "socket" up but they work (be carefull here, there is one 5v pci socket on these machines, and 6 pcix sockets, the pcix sockets will accept 3.3v pci cards (look at the notches).
Next you have to mount them, with a bit of jiggery pokery you can feed the IDE/SATA cables past the SCSI backplane into the hot swap bay. (If you dont have any empty caddy's pick them up off ebay), just remember you cant just pull em out like you can with the SCSI's!) - or use one of the 5 1/2 media bays.
Plud the other ends into the appropriate controller card (as installed in the PCI bus).
Load up the OS, install drivers (if needed - these should come with the pci card(s), use the disk manager to initialise/first format the drives etc.
All done.
I have done this myself running a 2600, with 2X U320 72gb SCSI (on Raid) 1 x IDE CD/DVDRW in Media bay, DAT 27 SCSI (channel B) in the second media bay. 2x 146gb SAS on a DELL SAS pcix card (in 2 of the hot swap bays) and an old 160gb IDE HDD (Funilly enough theres a bit towards the back of the two fans on the SCSI backplane that if you press the 3 1/2 drive against seems to fit perfectly in this place and stay there! (I think thats fluke to be honest).
All done :)
Jan 04, 2010 | Dell PowerEdge 2600 Server
How to slave the new SCSI HDD
Hello Fred...SCSI's are not all the same...
Is the SCSI controller built in to your motherboard or an add-in SCSI card? SCSI HDD's have selector switches on the back with numbers instead of master/slave jumpers...
Your motherboard BIOS might have an option...etc.
Go to your HDD's Mfrs. website...they will normaly have an overlay of the drive and it's applications.
Hope this helps...good luck.
May 23, 2009 | Seagate (ST3300655LW) 300 GB SCSI Ultra320...
I need to get to the configuration utility
These menus are for SCSI/SAS controllers. If your server doesnt have a SCSI/SAS controller installed, or if it is disabled then you would not receive these prompts.
Dec 30, 2008 | Dell PowerEdge 4400 Server
Constant beep on poweredge 840 appears to work alright
Hi
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Mike
Apr 02, 2008 | Dell PowerEdge 700 Server
Seagate 36GB Savvio 15K SAS 2.5" SCSI Hard Drive Logo
193 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
