Question about Sanyo Televison & Video
3 digit code number for sanyo fxvl remote control for my sanyo tv
5 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: Masterplug tvrc4n 4 in 1 remote control/sanyo
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 23, 2008
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Posted on Feb 10, 2008
SOURCE: Total control remote
http://www.crestonline.biz/files/support/remote_controls-Total_Control/URC_4110_B01--Manual.pdf
this is the instruction manual for the TOTAL control remote and the 5 digit codes for all TVs it is a pdf file and can be printed 16 pages, My Mother-in -law lost control of her TV when we replaced the batteries and after searching the net found the manual while searching for the TV code Palsonic, numeroous attempts failed searching for the remote details, but there it is.
Posted on Apr 06, 2008
SOURCE: i need remote control codes for my GE universal
Need Code for GE RC24991-B Remote Control
Posted on Jan 13, 2010
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Jan 27, 2016 | Sanyo Televison & Video
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Jan 13, 2016 | Sanyo 42 in. LCD TV
Sanyo fxvl universal remote what is codes for emerson tv and how do i set it up
0004 0042 0049 0065 0101 0113 0119 0145 0152 0166
Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
May 02, 2015 | Sanyo Televison & Video
How do I program my sanyo FXVL tv remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Aug 31, 2014 | Televison & Video
Need code for my dvd player /sanyo remote fxvl
go to www. fitness.manualsonline.com or www.remotecodelist.com
sincerely. God bless you
May 07, 2012 | Sanyo 6450160929 Remote Control
We have a sanyo tv and a ge tv remote control and we need the code 2 program the remote 4 that sanyo tv.. helppp
hi,
you didn't specify the brand and model number of your remote . any way follow the steps to prgram your remote with your tv. if it is GE universal remote. any other brand contact me back with its brand and model number.
1.Manually turn on the device (TV, VCR, DVD, etc.) you wish to
program.
2. Press and hold the CODE SEARCH/SETUP button on the remote
until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming
(TV, VCR, DVD, etc.). For AUX, press AUX then the device button
you are assigning to AUX. The INDICATOR LIGHT will blink then
remain lit.
4. Enter the three or four digit ( or three digit)code for your device using the number
buttons in the GE Universal Remote. After your code is entered the
INDICATOR LIGHT will turn off.
5.Aim the remote at the device (TV, VCR, DVD, etc.) and press the
POWER button. Your device should turn off.
code for your tv if the remote is 4 digit one
0049, 0097 ,0110 ,0004
code for your tv if the remote is 3digit one
004, 012, 013, 049, 097, 108, 110, 180, 209, 268
ok
Feb 02, 2011 | Sanyo DS31590 31" TV
Living solutions a17g0510 item # m#606426 big universal remote control. I cannot program it to my old sanyo tv
TV Codes listing:
http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
If those dont work try the last three(or four) digits in the tv''s serial number. That's the only way could find my ATV TV's remote code.
Oct 08, 2010 | Universal Remote Control Remote Control
Three digit code for sanyo tv all for one remote
Goto the link below. Select the model number of your One for All then select TV then select Sanyo then click on Submit. That will give you your codes.
http://www.ofausa.com/en/advanced_search.php
Oct 25, 2008 | One For All URC-4330 Remote Control
Codes for tv remote
I've had good luck with this list for some TV's. Try one of these 3 digit codes.
SANYO
002 412 506 522 612 619 902
Oct 19, 2008 | Sanyo DS27820 27" TV
Tv codes for sanyo tv for a phillups magnavox pm35 remote
SANYO TV 3 digit codes; 328 425 426 428.
SANYO TV 4 digit codes. 0506 0311 0612 0002 0428 0802 0412 0619
Jun 22, 2008 | Philips PM3S Remote Control
Televison & Video Logo
856 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
