Question about ASUS Eee 4G Notebook
My EEE PC will not scan or locate wireless signals. how do i get it to work again?
  • 12 Answers
Hi, please check the 'wifi-button' this is often located at the top of one of the F-keys (F1-F12) and looks like an antenna. Combine this key with the Fn button at the bottom of the keyboard and press the together, now the wireless antenna's should be enabled. Re-scan for networks after you pressed the keys. kr gijs
Posted on Sep 10, 2009
Have Eee pc with windows7. wifi connection looses connection every few minutes.Network adaptor problem
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Sep 11, 2012 | ASUS Eee PC 900HA Notebook
How to turn on wifi? Its been 2 -3 days wifi isnot being loaded?
Press and Hold the FN function key then hit F2 while holding the FN Key down.
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
May 25, 2012 | ASUS Eee PC 1000HE Netbook
Wireless does not work on asus eee pc 900
What exactly is the problem? Wireless not working is not very descriptive of your problem because there are many things that come into play in order to have wireless.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
May 18, 2012 | ASUS Eee PC 900 PC Notebook
To whom can help, The wireless is not working on my ASUS Eee PC 1000HA. It's working on every other laptop in my house so, it is turned on, it's just not working on my Eee PC 1000HA. Thank you, Dr.M.Seus
Right click the wireless icon in the lower right hand corner by your clock and click view available wireless networks. Then select configure advanced settings. Click on the wireless networks tab.
In the lower part of the screen select your wireless network and remove it. Reboot the laptop
Once back on, view available wireless networks again, double click yours and join it again. It may ask you for your password so make sure you have that handy.
Mar 01, 2011 | ASUS Eee PC 1000HA Notebook
Wireless internet connectection problem
Sometimes the wireless receiver can only connect with the signal in a location where the signal is strongest, in your own house, for example. If you carry the pc outside or elsewhere, it might not be able to connect because other wireless networks will not allow you to pirate their connection. Usually these require a password to logon. There is nothing really wrong with your pc. If you don't like this, you could try searching for an updated driver for your wireless card.
Aug 20, 2009 | ASUS Eee PC 701 Notebook
Asus eee PC 900 wireless access points
You should be using one access point and have repeaters to give you wider wireless coverage,
Jun 22, 2009 | ASUS Eee PC 900 Notebook
Eee PC 900 has problem with wireless connection
Hi terryandy,
I am using the Eee PC from Taiwan also. It is running good.
Based on your scenario, have you tried changing another new router?
Your description of having "out of range" is highly probable due to router hardware failure.
Try replacing the router and update us again.
Thank you.
Jan 06, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
try to change the password to wpa personal in router and then try it on lappy
Dec 17, 2008 | ASUS Eee 4G Notebook
Wireless mobile service connect to eee pc 8 GB?
MINHHANH::
What type of o/s [operating system]? I did quick research and I saw Linux ? I think that they don't have SOFTWARE DRIVERS for your o/s. Not in USB,connect 881 and not to loose you u, they did not tell you.
TNTEE::
you already have a wireless receiver in your laptop, u just have to configure it [Tell it what to do!]
Then u goto the internet explorer or some other BROWSER and get on WIFI if you can receive a signal from the air
Apr 16, 2008 | ASUS Eee 4G Notebook
ASUS Eee 4G Notebook Logo
160 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
