Panasonic air conditioning model no cu-v9ckp5 inside unit switches on but no fan operation outside unit starts then after approx 1 min whole thing shuts down again
  • 41 Answers
The outside unit has a fan capacitor and it must be faulty!!! thae capacitor tells the fan to rotate and if the fan does not work then the compressor will shut down due to a high head pressure and temperture!! change the capacitor located in the electrical section of the outside unit and it should work fine...
Posted on Sep 10, 2009
My outside a/c condensing unit's fan runs, but inside vent air is not cold. compresser may not be running. inside vent air was cold last week. Janitrol ckj361ab is model # of outside unit.
Start the unit and go outside to see if the insulated pipe is sweating or cold, hot air should be discharging from top of outside unit. Since the breaker is not tripping, my best guess is the compressor is not operating. You might have to replace the capacitor.
If you can hear the compressor operating, then most
likely needs refrigerant
Jun 17, 2010 | Heating & Cooling
Outside cooling unit shuts down after approx. 5 min. Of operation ?
Check condenser fan motor. If that goes faulty, shut down will occur.
Jun 15, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
The outside unit will work only briefly and bring the temp. down about 1 degree in 2 hours of running. Then the outside unit turns off for at least 2 to 3 hours.
Does the outside unit completley shutoff or does the
condensor fan keep on operating? If this is the case
the compressor could be overheating and shutting down. Try washing the condensor from inside out.
If you can read electrical diagram on the back of the
condensor electrical panel check to see if it has a
high pressure switch, if this is the case it probably
is cycling off this switch. Wash the Condensor and make sure the fan is operating.
If the big insulated line does not feel cool after 15 min. of operation you could be low on freon.
Jun 12, 2010 | Carrier 38CKC042 Air Conditioner
Outside unit keeps shutting off after 15 to 20 mins.
When compressors are on their way out, this is a symptom that is common.
May 15, 2010 | Carrier 38BRC036 Air Conditioner
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
Compressor kicks out and it's new
First of all, clean your outside coils so that you are assured of good cooling air. The compressors have an overtemp device that is usually internal to protect them against heat. If you have an air compressor use it to blow out the coils good. If the compressor will start, the capacitor is good so it sounds like a cooling problem with the compressor
Jun 25, 2009 | Ruud UAMB Air Conditioner
Bryant air condition fan outside not coming on
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Jun 15, 2009 | Ruud UBHC Air Conditioner
Goodman air conditioner will not turn on outside
When ever you hear a buzzing like you are hearing means one thing one of the fuses on the outside disconnect box is bad. Only getting 1/2 the power. Find the bad fuse and get the same size and will be good to go. ken
May 02, 2009 | Goodman CLQ36AR49 Air Conditioner
Have a near new panasonic cs-e28hkr split system air conditioner and the outside condensor fan continously runs even with inside unit is turned off? Thanks
Sir/madam,
If the inside unit (evaporator) is turned off absolutely.
The condensing unit must be turn off outside because the power
are derived comes from the evaporator.
Possible it seems on the cut out stage inside and remain the power still on
Otherwise theres somebody tamper the connection?
Fan cable consist of 3 wires
1 Common line
2 Start /stop line***Change the connection of this wire where it located, To On/ Off switch of the
evaporator inside unit
3 Ground green line/Earth
note: you can get all that wires inside the power supply in evaporator area.
If still under warranty inform the manufacturer
r_ic7
Nov 29, 2008 | Panasonic Heating & Cooling
No cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
Heating & Cooling Logo
199 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
