Question about Ovens
Wiring for emilia oven model EF6A1 I am changing the bottom element There is one green and yellow wire with a joining connection in the middle not connected and 2 brown wires where do they go
5 Suggested Answers
  • 4 Answers
SOURCE: What wire goes where for my Westinghouse Freestyle elements?
oven wiring has the same conventions as house wiring.
green = earth, outside coating
brown or white = one of core ends
black = the other end
Posted on Jul 14, 2008
pride applia
  • 232 Answers
SOURCE: St George wall oven element. which wire to connect
green is always grounded
Posted on Dec 24, 2009
  • 185 Answers
SOURCE: which wires go where on my belling fan oven
do you only have 2 wires? It doesn't make any differents which wire goes where on the element. I found a short video on how to change a Belling fan element I will post the link. Its about 3 minutes long http://www.youtube.com/watch?v=rVOGhil4Avs Hope this helps..... Does have some advertise ments on it but was overall a good video...
Posted on Feb 12, 2011
SOURCE: HI I have a Beko
Have a beko scc 2632 cooker. Need to know the colours of wires fom left to right of grill/oven element as it is different than the old element?
Posted on Oct 31, 2012
Tryin to replace heating element. I have 3 wires. 2 black and one yellow. How do I hook them up?
The yellow wire should be the earth wire. Earth is generally yellow/green or just green. This goes onto the frame of the element. The other wires go onto the main 2 pins of the element. There is no polarity so it doesn't matter which order you put them in.
Feb 10, 2011 | GE Ovens
Element for bottom fan forced oven wiring, I have a blue and green wire, should there be a third wire?
You should have 3 wires, the green is the earth. The other two would normally be blue and brown. If you have tried to change the element the missing one may have fallen back in or it could have been burnt off the element terminal and fallen down the back. Anyway you may have to remove the rear of the oven to locate it.
Feb 10, 2011 | Fisher and Paykel OS302SS, Stainless Steel...
HI I have a Beko Electric oven (model SCC 2632). It has a combined oven and grill element which i redently had to replace. Fitted it no probelm, but when it came to attaching the coloured wiring spades...
Jan 29, 2011 | Ovens
We are having a neff oven U15M62NOGB fitted. The wires in the booklet are earth on the left, live in the middle and neutral on the right. Is this correct as the neutral and live are the other way round on...
Yes, the installation instructions are correct. The wiring from your old oven isn't relevant.
Your query is a little confusing though. The new oven should have a power cable attached to it for connection to the mains supply. This should be on a separate circuit from your sockets and connected to an isolator switch. The wires in the power cable are colour coded to ensure that they are correctly polarised when connecting to the mains supply. I'm assuming you're in the UK as you list a GB model number, therefore, it should have a BROWN wire for LIVE, BLUE for NEUTRAL and GREEN/YELLOW for EARTH.
If your house wiring uses the old red (live) and black (neutral) colour coding, then you just need to ensure that the brown (live) wire from the oven lead is connected where the red wire from the supply is terminated. The blue (neutral) wire should be connected where the black wire is terminated and the green/yellow (earth) wire should be connected where the green wire is terminated.
Internally, the oven probably uses red cable for live and black for neutal, but you really shouldn't need to be doing anything with the internal wiring to install the oven.
You say you are having it fitted. Any competent installer would know (or check) the correct wiring order even if the instructions were missing. If you are installing it yourself, be sure are certain you understand what to do before attempting this and double-check the power for the oven circuit is off before you start.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | Neff B1421 Electric Single Oven
What is the wire conection sequence
If there is no earth wire to the element, then it it does not matter which wire goes on the terminals of the heater, as they are common, so,as long as you do not connect the wires to earth, it will be o/k.
If one wire is green/yellow, then that goes to rearth.
Hope this helps.
Dec 22, 2009 | Neff U1863 Double circotherm super...
4 conductor wiring for a range, red goes to red, black to black, does the white and yellow go to the middle together?
white is the neutral line and goes to the "N" terminal, the other is YELLOW??? not GREEN,which would be the safety ground to the units case you can use the yellow as a safety ground wire and terminate on the case metallic structure, but by N.E.C. only green colored wire can be used as ground wire or any wire marked with green at any place visible or connection point
Sep 24, 2009 | Ovens
Fan oven replacement
if your new element is missing a terminal it is likely to be the earth terminal so when your new element arrives DO NOT connect the green\yellow wire to anything just wrap it in duct tape. As this is the earth if you connect it to the element you are just making a dead short so will blow element and fuse. The element is touching the oven liner so is earthed by the oven anyway. :)
Sep 06, 2008 | Ovens
SMEG SUK61MFX
silly boy!
the element is probably ok as what you did will not damage it.
the green/yellow wire should go to the base plate and if there is no connector for it, just use one of the fixing bolts. the other two wires go to each end of the element
Sep 06, 2008 | Smeg SE250XUK Stainless Steel Electric...
Jul 13, 2008 | Ovens
Neff Fan Oven Element _U1661
hi there green and yellow is allways the earth connection which is usually the middle tag, what are the colours of the remaining wires and how many are there???
Feb 08, 2008 | Neff U1661 Double circotherm super...
Ovens Logo
127 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
