Question about BenQ FP71E 17" LCD Monitor
Benq monitor flashes primary colours when switch on or off
My 6 month old Benq monitor has started flashing primary colours repeatedly when I switch the computer on or off. It has a message at the top of the screen that says "enter right> burn in" Do I need to do something, and what causes it please, thanks.
  • 2 more comments
  • qwirx Feb 19, 2008
    Mine is doing the same thing could this be a monitor or possibly a screensaver ptroblem?
  • gual42 Apr 07, 2008
    I had the same problem with a Benq Fp2200W.
    Had the power supply replaced 3 times with no luck.
    Eventually sent it back to Benq themselves who found that solder used in the power switch mnaufacturing process had leaked further into the monitor and was shorting out the power switch.
    They replaced the power switch and cleaned out the solder which fixed the problem.
  • Anonymous Apr 14, 2008
    The "enter +right" means enter + right ON THE LCD display. Not the keyboard (in case someone is as stupid as me)
    cheers
    JR
  • andjo Aug 02, 2008
    Primary colour flashing starts when the monitor powers down - it didn't start doing this until a couple of days ago. Temporary solution is to switch the thing off when PC is unattended. Better solution anybody?
This is called burn-in mode. Used to test the monitor at the factory.
To fix this, use the buttons under the front of the monitor,
There are six buttons. Let's number them 1 to 6 from the left.
Press 6 to display menu (at the bottom in Red will say Burn in mode on)
Press 4 or 5 until Recall is highlighted
Press 6 to select
Press 4 or 5 until Recall All is highlighted
Press 6 to select
Press 4 or 5 until Yes is highlighted
Press 6 to select
Press 3 to exit
This will reset all paramaters and also turn-off burn-in mode
If you want to reset some parameters to your preferences, press 6 again to bring up menu and
see you user guide to get explanations for the different settings.
Posted on Dec 29, 2008
Yeah my one does the same thing. it happen when i out a power surge.
Posted on Mar 27, 2008
    Champion:
  • 220 Answers
Problem is front switch panel.
BenQ normally has three year warranty.
Samir
Posted on Mar 10, 2008
My BenQ FP71G powers on and off, repeatedly, by itself no matter whether connected to computer or not. Everything else is fine. Sometimes it stays on for a minute or so, but usually for just a few...
my BenQ FP71G 17 in goes on after hundreds of times pushing on off switch and when it's on it does not go off, I have checked the on/off switch which is working oke and when the moniter is on the auto adjust message (brightness and contrast)pops up frequently and the screen adjusts itself.
Oct 12, 2010 | BenQ FP71G 17" LCD Monitor
When i plug the monitor into my computer the flashes Benq only!
Try connecting the monitor to a different computer, e.g., a laptop.
The power-cord to the monitor seems to be OK.
Check the "data" cable between the monitor and the computer -- try a different cable.
With the monitor turned on, restart your computer, and watch the monitor. The computer should show some start-up messages (white text over black background), followed by the Windows "splash" screen. If it does, the monitor is working correctly.
Jul 03, 2010 | BenQ FP737S-D 17" LCD Monitor
My pb6200 benq projector's colour is wrong. Missing green. Has a lot of blue & red. How do I fix this please? Have since replaced the lamp - does the same with both old & new lamp. Also has a...
Your correct about missing your primary color. this could be either your cable or the connection at the projector could have a bent pin on the port. not sure what your trying to display computer?
Jun 01, 2010 | BenQ PB6200 Multimedia Projector
Benq 567s lcd monitor does not power up. Switch led blinks but goes dead. Tried replacing capacitor 450v 82uf with 400v 100 uf but did not work. please help.
That cap is for the Primary power supply switching circuits. How is the DC secondary side, no blown fuse, shorted transistors in the inverter circuits? Pictures will help, budmrtn@aol.com
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
It may have the same bd as DELL since BenQ makes monitors for DELL and HP.
May 21, 2010 | BenQ FP71G 17" LCD Monitor
Just got a hand me down Benq model t903 19
Quite the opposite -- your new monitor can't handle the screen settings that you're running on the old monitor.
Hook up the old monitor and start up the computer so you're looking at a Windows desktop. If you have windows open, close them or minimize them down to the taskbar so you can see the desktop/background image.
Right-click on the background image and select "Properties" to bring up the Display Properties dialog.
There are tabs across the top of this dialog -- select the one named "Settings"
In the bottom half of the Settings tab, there's a control named "Screen Resolution" with a slider to move between "less" and "more"
Move this slider to 1280x1024 or lower. If you're already at a resolution smaller than 1280x1024, then set it to 800x600 and we'll troubleshoot from there.
Hit "OK" to accept the new settings. Windows will ask if the new settings are OK -- click on "yes"
Now unplug your old monitor and plug in the Benq.
If you are happy with this screen resolution, then you're done!
If you're looking at 800x600 and want to see more, then repeat this process -- go to the Display Properties -> Settings dialog and try a bigger resolution. Hit "Apply" instead of "OK" to try a new setting.
If the screen says "OUT OF RANGE" for a setting, just wait for 15 seconds, and windows will revert to the old (working) settings.
Let me know how this works! If it's helpful, click the little thumbs-up. If it's not, ask questions and I'll try to explain in more detail
Aug 09, 2009 | BenQ Computers & Internet
No signal detected
change the CRT/LCD to Presentation. this is done on a Dell (for example) by pressing the blue Fn key and the F8 key which cycles thru the three modes: off, shared or on. bit late (may 2009)0 but just in case/
Mar 17, 2009 | BenQ G2400W Monitor
Benq FP222W
Your monitor must have multiple inputs (Dvi,D-sub) so it searches when you start for which input is connected.
If menu popping up intemittently is your problem,The culprit is generally defective (Leaky) Key switches.You need to pen up monitor and replace.
Normally BenQ has a 3 year warranty.
Dec 28, 2008 | Computers & Internet
FP531 Monitor flashes 'Benq'
sounds like an internal issue with the power board service tech should look at it
May 10, 2008 | BenQ FP531 15" LCD Monitor
BenQ lcb monitor
Monitor blanks out due to problems with internal power supply, have a quilified technician take a look at it, BenQ LCD monitors have 3 years warranty
Feb 11, 2007 | BenQ FP71E 17" LCD Monitor
Monitor goes blurry, colours/pixels start shaking across screen
Do you have your screen saver enabled, i so turn it off and se if it still does it. Secondly boot your pc in safe mode(pressing F8) on boot up and select start windows in safe mode. See if the monitor still does it, if so a monitor fault or loose/faulty vga lead. If it is ok then your graphics driver may be corrupt and need re installing.
Dec 30, 2006 | BenQ FP71E 17" LCD Monitor
BenQ FP71E 17" LCD Monitor Logo
2,617 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
