Question about Williams 2509612 Ceramic Mid-Size Heater
Williams gravity vented wall furnance - where is the pilot?
Hi..we are freezing at home and trying to light our furnace..we don't know where the pilot is..any suggestions..
    Sergeant:
  • 288 Answers
Its in the bottom of the heater behind the vent cover . I don't know where you are but your local gas utility will come out and lite this for free.
Posted on Dec 23, 2007
How do I light a Williams gravity vented wall furnace model 5009622
they usually have a manual perazo ignitor simular to a gas barbeque.. put the gas valve on pilot, depend the knob and hold it, depends the igniter epeatly until the pilot litghs, hold the knob in when u see the pilot flame for about one m,inute , release the knob, the turn the knob to the "on" posistion
Oct 02, 2016 | Williams Heating & Cooling
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
The pilot goes out when the heater cycles
The thermocouple is not working correctly. sometimes you can clean the soot build up from it and it will work again. sometimes they just need replacing. the thermocouple is what the pilot light flame heats up when you turn on the heater. when the thermocouple gets hot it sends a 20 to 60 millivolt signal to the gas valve to activate the gas flow to the main burner.
Feb 18, 2015 | Williams Wall Heaters: 50,000 BTU/Hr...
Chimney type wall furnace. The furnace won't start However after switch was off for a couple hours and turn on the switch it started. What is a possible problem?
The problem sounds like the thermocouple is not working correctly. After being off for a couple hours allowed it to cool down and reset. Sometimes you can clean the soot build up from it and it will work again. Sometimes they just need replacing. the thermocouple is what the pilot light flame heats up when you turn on the heater. when the thermocouple gets hot it sends a 20 to 60 millivolt signal to the gas valve to activate the gas flow to the main burner.
Feb 16, 2015 | Williams Wall Heaters: 50,000 BTU/Hr...
Pilot goes out when thermostat turned on
In gas appliances it is mostly gas line or igniter or valve or dirty nozzle or dirty line or main control beard problems
All Gas appliances should be checked and repaired and tested and serviced by qualified service expert that are licenced and insured
Dec 09, 2013 | Williams Wall Heaters: 50,000 BTU/Hr...
It is a Williams circa 1985 gravity direct vent wall furnace mdel 30DV 5, 30,000 btu. Light pilot OK. Heat on OK. But when heat not called for (several hours) pilot must go out. There is a small penny...
That hole should only be a problem, if a strong draft comes thru and blows the pilot out. But that hole may also be for match lighting the pilot in an emergency. The older models like yours, had that feature. Check it closely, before you decide to block off the hole.
Hope this helped you.
Jun 19, 2011 | Williams 3003622 Ceramic Wall Mounted...
Hello i have a williams wall Furnace model#25-35-50. I need to know if its a base board heat and also if you could tell me which wires are which. 1 red and 1 white
What you have is a Direct Vent, Gas WALL Heater. It is normally mounted about 6" off the floor on an exterior wall (since it has to be direct vented out). Not sure what the red and white wires are for, but suspect it's for the optional thermostatically controlled blower connection.
In any event, to help you install this heater properly, I have included a link to the Owner/Installation Manual, which should provide all the information you need to complete the installation correctly.
http://shopfnc.com/pdffiles/williams2man.pdf
You can download and print the manual for future reference.
Feb 26, 2011 | Williams 3003622 Ceramic Wall Mounted...
Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Mar 04, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Williams 2509612 Ceramic Mid-Size Heater Logo
883 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
vance jones
Superior Maintenance
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
