Question about Motorola Mobility MOTOROKR S9 Wireless Headset for Bluetooth-Enabled Cell Phones - Black/Red
Hi i am having trouble with my left speaker, the buttons don't work, i can't hear on my left speaker and can't pick up calls, how do i slove this problem on my Motorola s9
HI I HAVE A I PHONE G 3 ...I AM HAVING TROUBLE HEARING WHEN PEOPLE CALL ME OR I CALL THEM ..I WENT TO SETTING AND ONLY SAW HOW TO TURN UP RINGER ..PLEASE HELP I AM NOT VERY TECH SAVVY
on the left side of your phone directly underneath the vibrate/silent button there is a long button that is your volume control. While in a phone call press the top of that button and that should work for you. but only while in a phone call because other wise it will just turn up your ringer. hope this helps
Aug 31, 2013 | Apple iPhone 3GS
Hi, one of our Call Center workers cannot hear the ringing phone when she has the headset onWhat's your problem?
The ring from the telephone is picked up by the internal microphone on the HL10 Handset Lifter, typically for most phones, the lifter sits directly over the speaker grill on the telephone where the sound comes out. For telephones that curve out on the left side and don't have a straight edge, there is an accessory called a "Ring Detector" which is used. Here's a link:
HL10 Nortel Adapter Kit - 46780-01
If the internal mic on the lifter has gone out, you can plug the ring detector into the handset lifter and just stick the ring detector over the speaker grill to pick up the ring. Plugging this into the lifter will bypass the internal mic, this accessory would have come with your HL10 lifter. You can also check the ring volume on the telephone, and you can also try adjusting the ring tone on the phone (sometimes it will pick up one ring tone better than another). Here is a link below if you need to order a new ring detector:
HL10 Nortel Adapter Kit 63014-01
Good luck from Headsets Direct!
Oct 27, 2011 | Plantronics PL-CS55 Wireless Headset
My panasonic cordless phone model # KX-TG2258S the handset works but when you dial or talk or even just pick up the phone you don't hear any noise at all. not dial tone but it does call out. you just...
Do you even hear white noise? If not, it sounds like your phone's speakers may be broken, or it has water damage. If your landline is connected to more phones, ask yourself these questions:
Do all of the phones have this problem? If so, it's a problem with your connection, not the speaker.
Is there a volume button anywhere on the phone or the base? Try turning it up.
Do my phones make a "beep" noise when i push the buttons? If not, did they used to? If they don't, then it's likely that the speaker is no longer working properly.
You may need to contact panasonic and see if they will replace it for you.
Hope this helped! Please rate my solution!
- Frankie
May 06, 2011 | Panasonic 2.4GHz Digital Cordless...
Instruction manual for older style corded GE speaker phone
Here are the quick instructions on how to program the phone numbers.
You can also download a copy of the User's Guide from: http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=c96e9c823d0df43989039e5385bef04a&q=GE+29322GE1
Just enter the 4 digit captcha code and you will be able to download the User's Guide.
Please let me know if yo have any questions.
Good Luck!
STORING A NUMBER IN MEMORY
To program priority keys:
1. Make sure the telephone is properly installed. Pick up the
handset and listen for the dial tone. If you don’t hear the
dial tone, recheck or repeat the installation steps.
2. Press the SPEAKER button or pick up the handset.
3. Press the store button.
4. Dial the number to be stored.
5. Press the store button again.
6. Press the A, B or C button.
7. Press the SPEAKER button or hang up the handset.
To program frequently called numbers:
1. Press the SPEAKER button or pick up the handset.
2. Press the store button.
3. Dial the number to be stored.
4. Press the store button again.
5. Press one of the 10 memory location buttons 0-9.
6. Press the SPEAKER button or hang up the handset.
Aug 11, 2008 | GE 29322GE1 Corded Phone
People can't hear me during calls (T-Mobile Sidekick 2)
You can try using your left toggle button push down until you see turn on speaker phone highlighted in blue or use scroll key and just click on it and it works much better. If not try turning phone around and putting speaker to ear and then mic should pick you up but i have found in the last 3 hrs i have had this one speaker phone is easier for this big device.Well hope that helps,good luck.
Jul 25, 2008 | T-Mobile Sidekick II
Problem
Take the phone and have the speaker replaced.
May 29, 2008 | Sony Ericsson K800i Cellular Phone
During the call I cannot hear the caller very well
chnge the spekar nothing slove your problem than jumper setting
Mar 07, 2008 | Nokia 6030 Cellular Phone
Can make calls, but cannot hear when it rings or when it picks up
you have answered the query correctly go ahead and change the ear piece speaker thats faulty
Dec 03, 2007 | LG VX8300 Cellular Phone
Only works on speaker...
It sounds like the earphone speaker is broken. Have you tried adjusting the volume during a call (buttons on top right side)
You can test your earphone speaker by pressing the following combination on the phone.
where > and < are right and left on the joystick.
From the "Service" menu that pops up, pick "Service Tests" and then "Earphone"
Thanks.
Nov 09, 2007 | Sony Ericsson K800i Cellular Phone
Motorola Mobility MOTOROKR S9 Wireless Headset for Bluetooth-Enabled Cell Phones - Black/Red Logo
16 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
