Question about Hardware & Accessories
Smiths timer-how to set?
In the small block of flats where we live there are 2 security lights in the car park operated from a Smiths (E2475/1) timer. This has an outer ring covering 7 days with the numbers 1-7 both written twice. There is then an inner moveable ring covering 24hours. There are green and red pins supplied.
Someone has tampered with the timer and we now have no idea how to re-set it to have the lights come on only when it is dark.
Can anyone help??
    Sergeant:
  • 384 Answers
Yes I can help.
Tonight take a flashlight with you.
Posted on Sep 10, 2009
2004 scion xb won't start, does not turn over, battery is good
You car have security system.first locate the security light and make sure goes OFF after unlocking the car
turn the key and monitor the instrument cluster if all the light stay on
apply parking brake and whit left hand turn to starting position and with right sift from PARK to NEUTRAL
locate the starter and connect test light to small signal wire,other end to ground. let helper start the car. did the light go ON?(replace the starter)
the light stay OFF (electrical problem)
Inspect all the fuses,switch the starter relay with known good one,clean battery terminals,scan with advance scanner for malfunction code,and switch to live data Look for starting signal from computer
good luck
Aug 25, 2014 | 2004 Scion xB
Smiths Timer ET 07
These are the original instructions. Unfortunately Fixya won't allow higher resolution images.
Dec 19, 2012 | Hardware & Accessories
Smiths Digital Timer ET 07. Instructions needed.
Here's the original instructions. Unfortunately Fixya won't allow a higher resolution PDF to be uploaded.
Nov 03, 2012 | Hardware & Accessories
I have lost the instructions for use of smiths plug in digital timer etu02
10-30-12
Smith's ETU02 timer does not appear on the Smith's manual page:
http://www.tlc-direct.co.uk/Technical/DataSheets/Smiths/Index.htm
Other sites report this 7-day digital timer is discontinued, but can be replaced with similar timer from local box store locally.
Another option is to search following page for same-similar timer that might yield a manual similar to your timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
Oct 30, 2012 | Hardware & Accessories
Have a 4003-00 Timer for a business park outdoor parking lot lights. I need to change hte tim to come on ~ can't find the book to tell me how to change this? Can you help?
ef74fbb.jpgParagon 4000 series is a mechanical dial timer
Image explains general operation of timer
Attach Black tripper to dial at time you want lights to turn OFF
Attach Silver tripper to dial at time you want lights to turn ON
Minimum on-off period is 1-1/2 hours
Re-set dial after power outage.
The dial rotates with passing time
The timer takes the Paragon X2772 tripper
If tripper does not turn lights off-and-on, then you might need new trippers
If dial does not rotate, you might need new timer
If manual override does not work then check electricity
http://waterheatertimer.org/Paragon-timers-and-manuals.html#Paragon4000
If you need more information, add a comment below and I will respond.
Oct 27, 2010 | Paragon REPLACMENT MECHANISM 110V SPST -...
Program 2 new Keyless remotes
will have to go to local dealer,requires scan tool to acces bcm for programming,not som lock smiths have tool for programing but not much savings.
May 10, 2009 | 2000 Buick Park Avenue
Need instruction sheet
Your unit has a lifetime warranty. Go to this website to get the instructions in PDF format:
http://www.hardwareinnovations.com/pdf/SA_210_IB61056_33.pdf GOODLUCK
SA 210 Zip Set Outdoor Digital Timer with 3 Outlets features a Zip-Set One-Step Set-up where you simply enter your area code and the timer is programmed. Your lights will automatically turn on at sunset, and auto-adjust for seasonal time changes. Other features include a random setting for added security, a 7-5-2 setting for full weeks, weekdays, or weekends. Battery back-up (batteries included) to save resetting time in the event of a power failure. It has 2 timed outlets, plus 1 extra untimed outlet for use with other products. It has an easy-to-read, large illuminated digital display, and 15 amp capacity. Lifetime warranty.
Product Description
Zip-Set™ Technology with One-Step™ Set-Up Two Timed Outlets + 1 Untimed Outlet Controls three Products Simultaneously Controls Outdoor Landscape, Security and Holiday Lighting, Pool/Spa Pumps and Engine Block Heaters Optional 4 On / 4 Off Settings Random Settings for Added Security 7-5-2 Feature allows you to set times based on the 7 Day full week, 5 Day work week, or 2 Day weekend Large Illuminated Easy-to-Read LCD Display & Keypad Battery Back-Up (battery included) saves resetting time in the event of a power failure Weatherproof 15 Amps Lifetime Warranty
Dec 22, 2008 | Sylvania Hardware & Accessories
Hardware & Accessories Logo
448 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
