Question about Microsoft Windows XP Professional
I have to window xp pro x64 installations on the
I have two window xp pro x64 installations on the same partition. How do you remove or uninstall one of the os installations so there is only one os on the partition?
  • 49 Answers
You can edit the boot.ini and remove the unwanted windows option then delete it's directory. the best option is to format the hard drive and reinstall windows since doing the above mentioned option will leave remnants of the othe OS. best if only one OS in in a partition. if you need to dual boot, install other OS in a separate partition.
Posted on Sep 10, 2009
Testimonial: "Formatting is the easiest solution and the fastest since editing *.ini or reg settings can end badly. Thanks for the advice."
    Master:
    Sergeant:
  • 460 Answers
You can delete one OS from registery.
go to my computer properties > Advance > startup & recovery settings > edit. here you can find two OS registery. now you can remove one OS registery.
Testimonial: "I spent hours searching Windows help for this kind of answer but never found it. Thanks for your suggestion."
I have a PC with C2D E7200 2.53GHz Processor, 250GB HDD & 2 GB RAM, I HAve 5 Partition on the HDD and i have partitioned it as C: 20.5GB__D: 68.3GB__E: 68.3GB__F: 38.3GB__G: 37.2 GB. On C Partition WIN...
#1 Use windows backup in Windows 7 to create a full system backup of the OS to DVD or a removable drive. (And well as any data on any other partition)
#2 Repartition drive to roughtly 50 50 split
#3 Install XP to partition 1, Install 7 to partition 2 then restore the backup of 7 to partition 2,
Nov 22, 2010 | Microsoft Windows XP Professional With...
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
I need to reinstall window xp pro on my dell dimension 2400-
If you don't need any files currently on the computer, boot from your Windows XP disc, have it delete the current partition and then format the new partition, and install windows XP.
Note: this will delete anything you currently have on the computer at this time!
Mar 22, 2009 | Dell Dimension 2400 PC Desktop
I downloaded the driver but it wont find it and i have windows xp pro x64 does it not work on this ver
try reinstalling it with this one, its neer the bottem of the screen.
http://www.jascoproducts.com/support/software-downloads.asp#pccams
Sep 21, 2008 | GE EasyCam Pro Webcam
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
Pioneer DVD Burner no longer reading burnt disks...
yes your quite correct, starforce once installed can damage the fimware more so for multi writers, a common problem will be slower recording speeds. It can even damage the hardware itself and render the writer totally useless. If your getting to that stage, for the price of a new writer, it's not worth the worry, replacing the drive is the only answer.
Jun 14, 2007 | Pioneer DVR-610 (DVR610B5PK) DVD RW Dual...
How to remove a second installation of a windows o/s
you would not have been able to install xp home over xp pro as pro is an upgrade from home, so xp pro will be on a different drive partition, so the last version you put on will be on the 'C' drive as thats the one that is bootable. Follow your instructions, or simply use your xp disc to format the drive and install XP home.
Jun 13, 2007 | Microsoft Windows XP Professional for PC
Before installing Windows XP Upgrade
In order to update your system from the current Windows operating system to Windows XP Home, there are several steps that need to be taken prior to upgrading. Please follow the items listed below in order to prepare for Windows XP. Uninstall Trend PC-cillin2000 Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click install/Uninstall tab, select "Trend PC-cillin 2000". Click the Add/Remove button to uninstall "Trend PC-cillin 2000". Uninstall NTI CD-Maker 2000* Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click the Install/Uninstall tab, select "NTI CD-Maker 2000". Click the Add/Remove button to uninstall "NTI CD-Maker 2000". Uninstall Intel LANDesk Client Manager* Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click the install/Uninstall tab, select "Intel LANDesk Client Manager 6". Click the Add/Remove button to uninstall "Intel LANDesk Client Manager". Uninstall PowerDVD* Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click the install/Uninstall tab, select "PowerDVD". Click the Add/Remove button to uninstall "PowerDVD". * This software is optional. If this software is not installed previously, please skip the step.
Sep 11, 2005 | Acer n10 Pocket PC
Microsoft Windows XP Professional Logo
101 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
