Question about Canon MultiPASS MP360 All-In-One InkJet Printer
Printer says cartridge is jammed press the "set" but I can't find any such key
    Scholar:
  • 81 Answers
This is just an educated guess however "set" is the term used by Cannon to refer to the operation of installing a new ink tank, possible they are requesting you remove and reinstall the ink tank, ensure it is in the right slot and ensure you hear a click.
http://www.retrevo.com/r/262bh333/85/Replacing+An+Ink+Tank#q=Canon+MP360
Posted on Sep 10, 2009
Print job disappearing and not printing
1. Check for a paper jam. Paper jams occur when one or more sheets of paper become stuck in the feeding or printing mechanism. Gently remove any jammed paper and reset the printer.
2. Check ink levels. Those ink cartridges run out fast. If your printer looks like it is printing but nothing comes out on the page, you might be out of ink. Try replacing the cartridge and printing again.
3. Check for a clogged print head. If you know you have ink, the print head might be clogged. Navigate to "Control Panel > Printer > Right Click > Properties > Maintenance > Clean Cartridges" to attempt to clean the print head.
4. Reinstall printer drivers and software. If none of the above helps, try uninstalling and reinstalling the printer and software to correct possible software bugs, errors or conflicts.
Canon-Specific Issues
5. Check printer drivers. Navigate to "Control Panel > Printers > Right Click > Properties > Update Driver" to check for a new driver for your printer. You can also find drivers and software on the Canon Support site (see Resources).
6. Resolve the Waste Ink Error. Press menu on the printer and press scan/copy to enter service more. Press the right arrow to access "NVRAM." Set ABS-M level to 0. Set ABS-P level to 0. Press "Stop" to exit.
7. Resolve Wrong Cartridge Message. Turn off the printer and unplug the power cord. Remove the cartridges and the print head. Clean the print head in lukewarm water. Set it aside to dry. Clean the contacts gently with an eraser and wipe with a tissue. Reinstall the print head and reinsert the cartridges. Run a cartridge alignment.
8. Resolve E0D02 error. Clean the cartridges and the sender strip. The sender strip is behind the rubber drive belt behind the main hatch. It runs horizontally across the machine. Wipe it gently with a lint free cloth.
Aug 19, 2012 | Canon Pixma Mp250 Printer
I keep getting the Unable to clean message, even after cleaning manually. Is my printer about to go to printer heaven?
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 31, 2011 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-640CW USB all in one printer. It cannot clean itself and thus it is not performing. How can I fix it. Thanks.
Hello
Something might be jamming the internal parts.open the paper tray,remove anything that is not supposed to be there do the same for the printer top and cartridge compartment.
Wait for the printer to restart to see if this fixed the error. If not, you can try a printer reset. Simply un-plug the printer and wait for about 3 minutes. Plug the printer back in and the usual display should show now.
If that does not work, you can try a manual reset by doing the fallowing :
1. Press the Menu & Mono start keys. Next press the up arrow key 4 times to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. Press the mono start key several times until the purge count appears on the LCD.
4. Enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero.
5. Press the stop/exit key to return to the initial stage of the maintenance mode.
6. Enter 9 twice by using the up arrow & set key's to exit from maintenance mode.
If this does not work, most likely the printer needs to be serviced.
Jan 15, 2011 | Brother Office Equipment & Supplies
Cartridge jams
remove the cartridge and directly off the printer let the carriage remain in center.then with your hand manually move the carriage from left to right.3 to 4 times.then on the printer and insert the cartridge after cleaning it with dry tissue.then check out.also in the back side of the printer there is access door to remove the paper if jammed so check out there also if any paper jammed.
thanks.
Apr 01, 2009 | HP PSC 2210 All-In-One InkJet Printer
CARTRIDGE jammed
Always it show the error messages like this then go to the authorised service centre they will do the needful you guys cannot do it yourself were are not here to do any free service as such in many issues.
Feb 08, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
After a paper jam, it said "cartridge problem 50C" consult manual
Hi Error 50c
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
Jan 10, 2009 | Lexmark X5150 All-In-One InkJet Printer
Align cartridges
Hi ,
can u cet alignment print from u r printer if u get this printer .
please put this print on scanner & press scann button for scanning ........it will automaticaly align u r cartridges & printer will get ready for printing ......
if this information is useful for u please Rate me...........
if any update give me comments for it....
thanks & regards
Sandipk
Jun 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Canon mp30s cartridge jammed
Since making my query post my husband seems to have solved the problem. I first tried the solution offered here for another printer model (remove then replace actual print head unit with the cartridges intact) but that didn't help. So my husband put a small amount of WD40 (also known as CRC) on the slide bar that the print head moves along. That seems to have freed everything up.
Oct 10, 2007 | Canon SmartBase MP360 All-In-One InkJet...
Canon MultiPASS MP360 All-In-One InkJet Printer Logo
125 people viewed this question
old marine
old marine
