Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
My D link (Di-604) has been working perfectly for the past one year but all of sudden it has stopped to send information to the computer, that means I can no longer brows when my D link is connected to my computer.
    President:
  • 2,185 Answers
If you connect your computer directly without passing thru the dlink, are you able to acquire internet connection? If not, there could be no connectivity being received by the Dlink from your internet provider.
Posted on Sep 10, 2009
  • 4,472 Answers
Have you tried resetting the router? Reset the router and see if that helps.
Thank you,
Lee
My D-Link DI-604 was working well. However, recently, I noticed that there is a delayed in power supply. It doesn't turn on immediately. It would take several minutes before it turns on. Sometimes, no...
I've had a few D-Link power-supplies fail on me, over the years.
Just purchase a brand-new router, for $20 t I've had a few D-Link power-supplies fail on me, over the years.
Just purchase a brand-new router, for $20 to $50.
Mar 08, 2011 | D-Link DI-604 4-Port Cable/DSL Router...
Hi, My d-link dl-604 suddenly stopped working. When I plug it in, only the power led and #4 lights are up. None of the other leds are responding nor the internet is not working as well. Please help. Thanks
The following reset procedure will completely restore the default settings on your D-Linkmag-glass_10x10.gif device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
Hope this helps! Give me thumbs please!
Aug 23, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
My DI-604 router has stopped working. Why
maybe its already defective. isolate it very well. maybe it needs some cold reset.
Mar 05, 2010 | D-Link DI-604 - 4-Port Broadband Router [...
Have 604 router. all of a sudden only two computers can be active through the router and it does not allow the other two to work. things were working fine with all computers getting browser access... now...
On the computers that are not getting Internet access, check the LAN cables to the router. Does the Link LEDs on the router for these computers are ON?
If the LED lights are off then the LAN cable and/or network cards are faulty.
Check Device Manager on these computers to see if the LAN card is working and enabled. If not re-install the LAN drivers. If the driver installation cannot detect the LAN card then most likely the LAN card is faulty and needs replacing.
Get back to me with the results of these tests and I can advise what to do next.
Nov 16, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
I have D-link cable router(DI 604)..i want to
http://www.antifart.com/2006/09/02/d-link-di-604-firmware-rev-e.html
Before using these files, make sure you have the E Revision of that router, you can check by looking on the sticker that contains all the model information like serial, model number.
Be careful while doing a firmware upgrade, very easy to brick your router. Bricking refers to making the router no more useful than an expensive paper weight.
Oct 20, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Cannot share connection
The IP address that you have is an automatic IP address the Windows generates. It basically means your computer is not getting an IP address from the router (DHCP). You should try powering everything off. Then, in this order, power on your modem, wait 30 seconds, then, power on your router, wait 30 seconds, then power on your computers...This should fix the problem since one computer is working already.
Mar 22, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
D-link DI-604 installing
The 192.168.0.1 was probably changed when it was first set up. To return it to default settings take a paper clip and insert it in the reset hole in the back of the router.
Give it a few moments to reboot and the 192.168.0.1 address should work.
Oct 04, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
D-link di-604
I have no success disabling the DHCP server. For me at lease, this will not work
Apr 02, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
D-link DI-604 problem
I had a same problem a couple of years ago with a DLink router and upgrading the firmware solved it.
The Philippines are covered by DLink's Australian office.
http://www.dlink.com.au. Look in the Support section, you will find the latest firmware and instructions on how to upgrade it.
If you don't find what you are looking for on their tech support web site, you will at least be able to contact them from there.
Feb 22, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Open Questions:
See all D-Link DI-604 4-Port Cable/DSL Router (DI-604) Questions
D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
259 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
