Question about SanDisk Sansa MP3 Player
When i push the select button my sansa expres 1gb turns of
Sumtimes the "building database" occurs three times.
  • 728 Answers
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work for you.
Posted on Sep 16, 2009
Hello, the problem that I have with my SanDisk 2 GB MP3 player is that now, whenever I try to put songs on it, I get a message that "the device has stopped responding" or "the device does...
Try and reset the player first, If this does not fix the problem, Click this link to down load the Sandisk updater program to run a firmware update...Updater... Resetting the device: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Next time you need to delete files heres how. --
There are two ways to delete files on your Sansa player. You can delete them from the player directly or using a PC.
METHOD 1 - Delete files directly on the device 1. In playback mode, press the Submenu button. 2. Select Delete.
METHOD 2 - Delete files using a PC For all other Sansa players: 1. Connect your device to the PC. 2. Select Open device to view files using Windows Explorer on initial connection. 3. Locate the folder where your files are stored. 4. Click to select the files you want deleted and delete the files.
NOTE: If songs still exist after deleting, you may need to switch USB modes from MTP to MSC or vice versa. See this tip HERE
Capacity issue This error occurs when a Sansa player is almost filled to capacity. A Sansa player can NOT be filled to full capacity. (i.e. you can't put 2GB worth of songs into a 2GB player)
The player needs the extra capacity to create and maintain a "database", a database holds all the information such as playlists, recordings, song information, etc. The larger the amount of songs, the larger the database gets.
To resolve this capacity issue, you have to delete contents on your Sansa player using a PC.
STEP 1 - Delete files on your player 1. See first note on how to delete files on your Sansa player using a PC.
FAT corruption This error also occurs when there's a file system corruption in your Sansa player.
To resolve this issue, run error-checking to fix errors in your device using a PC
STEP 1 - Connect the Sansa player to the PC in MSC mode
STEP 2 - Run Error-checking to check and fix errors 1. Double-click on My Computer (Computer for Windows Vista). 2. Right-click on the drive letter associated with your Sansa player and select Properties. 3. Click the Tools tab and select Check Now. 4. Click both check boxes under Check disk options. 5. Click Start
If an error occurs while plugging in the player to the PC and some files are missing in the player, the database might be corrupted. To resolve this, you will need to format your player.
NOTE: Formatting will delete all files in the device. Your data (music, photos etc) is NOT recoverable.
Nov 16, 2010 | SanDisk Sansa e260 MP3 Player
What does "Refreshing Database" mean
try holding the power button and the play button for 20 secs at the same time
Oct 12, 2008 | SanDisk Sansa e260 MP3 Player
Refresh database?
Try this
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Jun 19, 2008 | SanDisk Sansa e260 MP3 Player
Refresh database
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Apr 10, 2008 | SanDisk Sansa e250 MP3 Player
Sansa mp3 player stuck on different laguage
For the Sansa Clip:
Turn device on
Scroll to Equalizer looking thing (box with 4 sliding levers)
This is the settings function Select it by pushing middle button
Hit the scroll down button 3 times or scroll to the option right above the one that has FM
Scroll up or down until you see english
Good Luck
Dec 25, 2007 | SanDisk Sansa Clip MP3 Player
Sansa Hack!!! please help!
You device is too full. You need minimum 6MB for the "music database". The more music you have, the bigger the database needs to be. Try freeing up 30MB or so, that should solve it. Please add to the question, dont select NOT HELPFUL if this didnt work. Best of Luck.
Sep 26, 2007 | SanDisk Sansa e250 MP3 Player
Sansa Hack on Refreshing Database!!! HELP!!!
Lock your sansa and hold the rec button while starting it up.
It will go to recovery mode. Hook it up to your computer. Now download this file: "http://www.MegaShare.com/392319" put it onto the device that should pop up that is called "16MB-FORMAT". Once you put this file on there you should take out the thing that links your sansa to the computer and it should install the firmware. It will also restart your sansa. (Make sure that you unlock your sansa first.) And Now all problems should be fixed!
Refresh database message
Run the recovery tool from the SanDisk website. Make sure you select format when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 10, 2007 | SanDisk Sansa e260 MP3 Player
Freeezing
Hi. The symptoms you described may be due to corruptions in the player's music database (this player maintains an information pool on the music files you download to it). To resolve that, you would need to delete that database and let the player re-create a new one. To delete the corrupted database, let's do this: Step 1: Switch your player to MSC mode Step 2: Browse the player in "Windows Explorer", and look for the folder named "System" and/or "Data". Note: if you can't locate these folders, your Explorer may be configured to "Hide" system files and folders. To change that, please go to "Tools" on the menu list on the Explorer window, then choose "Folder Options". This will display a Window arranged in tabs. Select the "View" tab, find the "Hidden Files and Folders", then choose the "Show Hidden Files and Folders" radio button Step 3: Under the "system" or "data" folder on the Sansa E260, look for this file and delete it: "PP5000.dat" Step 4: Safely remove your Sansa E260. Then power it on. Your player will now either display "Rebuilding Library. Please Wait" or "Finalizing Update". Either way, it would re-build the database and hopefully resolve the error your player is encountering. I hope this helps. I love the Sansa E260!!
Mar 15, 2007 | SanDisk Sansa e260 MP3 Player
Refreshing database - Everytime
there nothing wrong its jsut the way the mp3 player refreshes the play lists mine does it too
Feb 06, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa MP3 Player Logo
152 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
