Question about Microsoft Windows XP Professional for PC
Installing xp i want to install xp which file system is best
    President:
  • 216 Answers
Always use NTFS - NTFS is the standard file system of Windows NT, including its later versions Windows 2000, Windows XP, Windows Server 2003, Windows Server 2008
Posted on Sep 10, 2009
  • 4,234 Answers
For the sake of completeness, let me try to clear up a few things.
The difference between the file systems is the method for using disk space to define files and data. In FAT there is a file called a File Acces Table which contains the information about a file. This info includes the initial disk block location, the file name and other stats about files. Each file section contains a pointer to the next block in the file. FAT has a limit on the number of pieces that can be addressed (FAT16 has 1/2 the number). Each of these parts is called a cluster. If you recall the older W95 and W98 systems, you would see a cluster size based upon the total capacity of the disk. Since the "cluster" is the smallest chunk of disk space that can be addressed direxctly, the larger the cluster size, the more space is wasted. Most disk files are small and with FAT there is alot of wasted space because hte individual clusters are not full.
NTFS uses a different method to address disk space with allows for less wasted space and does not have the limitation of a fixed number of clusters.
The bottom line is that NTFS is more efficient in terms of disk space usage and thus will allow more files overall.
In contrast to a previous entry, the amount of space consumed by a byte of information is the same for both schemes. It is the way that files are created that is different.
Hope this helps,
Dan
    Problem Solver:
  • 11 Answers
Also, NTFS uses disk space much more efficiently than FAT32 or FAT16. In other words, it uses less physical disk space per byte or character.
    President:
  • 2,022 Answers
Ntfs file system is good .
  • Microsoft Master
  • 3,289 Answers
NTFS - supports very large large file sizes, FAT is limited to files smaller than 4GB. This helps when transferring a large video file from camera or other to the hard disk. When trying to do do this, you'll be informed that there is not enough space on the drive - when in fact there is - it's all about the file system.
If you decide on FAT and later decide to switch to NTFS, it can be done from a DOS window in XP "convert <drive letter:> /fs:ntfs" (no quotes) fairly easily. For example, typing convert D: /fs:ntfs would format drive D: with the ntfs format. You can convert FAT or FAT32 volumes to NTFS with this command. If converting the boot disk, it will start at the next boot if you allow it.
Posted on Sep 15, 2009
  • Microsoft Master
  • 13,433 Answers
NTFS, FAT is limited in many ways, just go with NTFS, it will work much better.
On the start of formatting there was no error but when it copies files on the the cd 57% then mpr.dll was missing then the program will ask if to retry or exit the installation? how can i solve the mpr.dll...
For installation to be completed, files must be complete. the error you recieved is because the file meant for installation is either missing or corrupt. the best is go to a repair or sale shop where computer accessories or components are sold not just any road side shop, request for XP installation disc. OR contact HP for disc.
Mar 28, 2011 | Microsoft Windows XP Professional for PC
I am missing the listing of an previous Security update for windows Internet Explorer KB938127 installed on 20/02/2008. Operating system in Windows XP home edition service pack 3 with IE Version 7. Since...
I downloaded the Internet Explorer 7 installation from http://www.microsoft.com/downloads/details.aspx?familyid=9AE91EBE-3385-447C-8A30-081805B2F90B&displaylang=en and let it finish then rebooted again.
Opened Microsoft Update and it again found available updates
KB953838 and KB938127 and both installed successfully.
Jan 11, 2010 | Microsoft Windows XP Home Edition
Nvrd.32 sys not found so no boot help
You XP install CD would of course be the best option if you have the CD; but you can boot to any XP or Windows 2000 install disk and select R for the repair console. When you do, it will put you to a command prompt where you can log into the WINNT or WINDOWS directory as your administrative user and run chkdsk /r...this may fix the file.
If this doesn't work, you will need to use an XP CD of the same version as your system and run a reinstall/ repair to replace the missing or corrupted system files. It should not wipe the drive and your files will stay there, but you may have to reinstall your applications.
Sep 30, 2009 | Microsoft Windows XP Professional
Hello sir i had lost my operating system that was windows xp.i have no cd rom but i had copied all the content from cd to a thumb drive.is it possible to install window through this thumb drive please...
But was it an "upgrade" version of XP or New install? NOT what you did, but how the original CD was sold or labeled. Because Upgrade version do not have boot files on the cd, only new install cd's do.
Apr 03, 2009 | Microsoft Windows XP Professional for PC
Need to install install XP PRO on used cluttered hardrive.
Please follow this excellent guide XP Pro Clean Install to lead you through the process.
Check first to be sure your system meets the requirements for an installation of XP.
Also make sure beforehand that you back up any documents or files you wish to save from the old drive, because you will not have access to them after installation. Make sure you have a CD with Drivers for the hardware installed on your system; you will need these to access the internet once you install the new OS. Also be sure to have downloaded AntiVirus software installation files so you can load this onto the new system before going online.
You could, if you choose, buy a new hard drive and install your existing drive as a slave to the new master on your existing computer. In this way, you will still have access to all your old files and documents, without having to back them up.
Best of luck, and enjoy XP!
If this information solves your problem, or answers your question, please take just a moment to rate this post...thanks!!
Mar 30, 2009 | Microsoft Windows XP Professional SP2 for...
How to install window xp on aspire t650
Well yes you can install windows xp without the FDD. But it will be best to first gather all the XP compatible drivers for your Acer Aspire T650 at this link http://global.acer.com/support/index.htm before beginning to downgrade your operating system, burn all your XP drivers into a Disk backup your personal file. Then you can begin the installation.
Jan 24, 2009 | Acer Aspire T650 (AST650UC3601) PC Desktop
Unable to open all attachments
If you have Office be sure PPT is installed (some MSOffice do NOT include PPT ) if you have PPT installed launch your powerpoint.
go to File/ open
select any powerpoint file.
If you do not find any .PPT file simply create a PPT presentation save and try to open.
You can then associate .PPT file with Powerpoint program in your Windows Explorer: (go to Tools/Folders option File types tab)
Jan 14, 2009 | Microsoft Windows XP Professional With...
How to install XP in toshiba Satellite L45-S7423 laptop
You cannot uninstall Windows Vista, but you can reinstall your previous operating system, which then replaces Windows Vista. To reinstall your old operating system, you must have the original installation disc. Back up your programs and files, insert the installation disc into your computer, and then reinstall the old operating system. To regain the hard disk space used by Windows Vista, reformat the disk during the reinstallation process. After reinstalling your previous operating system, reinstall your programs and files.
Feb 29, 2008 | Microsoft Windows XP Professional
Uninstall xp
You can remove service pack 2 from within add/remove programmes, you will not lose any documents, but you will lose the udated security patches which is not recommended. If you mean you wish to remove XP SP completely, obviously the files and everything you have installed on c drive will be deleted as you can only save docs etc within an operating system, as c: is just a partition on your hard drive the files reside within the operating system. If you are upgrading to another operating system my advice would be to use a dual boot system and install the other operating system on a seperate partition of your drive, but you would have to have a fair knowledge of pc operating system installation processes.
Oct 03, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional for PC Logo
119 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
