Question about Belkin 802.11g Wireless Desktop Network Card [ F5D7000 Wireless ] (109061)
Belkin wireless g desktop card keeps disconnecting
Hey there.. i just had this belkin wireless g desktop card installed in my pc... but the thing is it keeps on disconnecting all the time and its super annoying.. luckily i have my external wifi card and its working fine now so definitely theres a problem with my desktop card.. any suggestion? thanks in advance
    Brigadier General:
  • 4,044 Answers
Go into power settings and disable the option to allow windows to turn the device off in Hibernation mode. Even though the machine is not hibernating if the screen saver activates or windows doesn't detect traffic on the card for some reason windows will power down the device.
Posted on Sep 10, 2009
My computer doesn't recognize my wireless card and has no wifi utility
Did you install the software first? The Belkin card should have had a CD with drivers. I believe the directions say to install the software first, then install the card.
Also, the min. specs are listed on the Belkin box. Check to be sure your computer meets them.
Feb 28, 2012 | Dell Dimension 2400 PC Desktop
Hey, I have a Belkin Dual-Band Wireless A+G Desktop Network Card, but I can't find the correct driver to download. I tried the f63000 but it still is not recognizing the Internet source...any ideas?
You tried this one?
http://www.belkin.com/support/article/?lid=en&pid=F6D3000&aid=6033&scid=223
How about this one?
http://en-us-support.belkin.com/app/answers/detail/a_id/499/kw/f6d3000
I did notice that there is no specified support for 64-bit versions of ANY OS,
and doesn't specify compatibility with any version of Vista or 7.
Try uninstalling any software and drivers you tried so far, then also remove the entry from Device Manager... THEN install one of the above drivers.
May 05, 2011 | Belkin Dual-Band Wireless A+G Desktop...
Internet keeps getting disconnected.Computer needs rto restart
there is nothing to do with adapter... you need to check with some other laptop to isolate where is the issue...
if your laptop works fine without dropping connection then get a replacement for your belkin adapter...
if your laptop also looses connection, then you need to check your wireless router...
Jul 24, 2010 | Belkin (F5D8231-4) Wireless Router...
Add wireless card
You can add one via a USB port like THESE
Or you can add one to an empty PCI slot on your motherboard if you have one available. Like This One
Mar 01, 2009 | Dell Dimension 4500 PC Desktop
Cant get Wireless card to connect to netopia wireless router
There are some things you might try.
The Belkin card will come with third party software you can disable this utility by right clicking on the icon in the Taskbar and choosing "Use Windows Zero Configuration".
Then you will need to go into Control Panel >> Administrative Tools >> Services >> Wireless Zero Configuration >> Right click and check that the service is starting automatically >> click on Start >> Apply - that should then detect your wireless network and the internet.
Feb 25, 2009 | Netopia 2247NWG-VGx Wireless Router...
Belkin Wireless G desktop card & BTHome Hub
hi..
it has been seen that due to some reason the wep key doesnot work...
u can try changing the key type to WPA instead of WEP...
go to the router page and change the security type to WPA instead of WEP..
1 more thing in vista you can use the windows utility only...how come is it possible that you are using the card utility as well..i suggest you to disable the card utility and just use the windows default utility..
vedhick.....let me know if u need steps to change the security type to WPA..
Jan 26, 2009 | Belkin 802.11g Wireless Desktop Network...
MY ROUTER KEEPS LOSING CONNECTION
Hello fieldon68, & to all the rest with the same problem.
There are many things that could be wrong, but intermittant discounnects sounds very much like a interverance from another wireless device. (ie phone, cell, etc)
To try to address this issue, follow the steps below:
Note : The steps below are applicable only for Belkin routers.
  1. Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
  2. You will get a login page. Leave the password blank. Click Submit ( unless you created a password, then enter that).
  3. On the left side of the page, click Channel and SSID below Wireless .
  4. The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel. Click Apply Changes .
  5. Click Logout in the top right hand corner.
Note: The wireless card in the computer will automatically detect the change in channel number on the router and will update the channel on the card.
CauseYou get disconnected wirelessly mainly due to an environmental interference. When the wireless channel is set to auto, the router will cycle to though channels when it detects significant interference. When the router changes channel the wireless connection will reset itself and disconnect all wireless clients connected to the router. Wireless signals are prone to interference from cordless phones and electrical appliances (e.g., vacuum cleaners, microwave ovens). This is one of the more popular reasons Belkin wireless connections can drop. Good Luck Mark P.S. Please leave a rating.
Jan 02, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin wireless G notebook network card problem
disconnect the divice from the computer, unistall the driver, reboot the system, the install the driver beforre connecting the divice
Dec 16, 2008 | Belkin (F5D7011) 802.11g/b Wireless...
Belkin 802.11g Wireless Desktop Network Card [ F5D7000 Wireless ] (109061) Logo
1,687 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
