Question about Motorola Mobility SLVR L7 Cellular Phone
L7i: Text Entry Mode Problems
My L7i is having problems in Dictionary (Auto Text) mode. It takes a long long time to enter a single letter and seems like the fone is hanging. Any remedy for this??
It sux to be angelo for the moment
Posted on Dec 20, 2007
Problem with RAZR V3i, take itap off
Hello there, the iTap feature is a the mobile phone dictionary feature which helps to spell the words which are located on your phone dictionary. This feature functions when you try to type a text message and it helps to spell the words by the use of a single tap on each key.
To exit iTap mode you simply press the middle button then select entry setup to bring up the menu for that screen selection and from there you can switch between iTap mode on or Off.
Also you can use the # button to switch between modes. To understand this better here is a link to the phone user guide Details on iTap can be found on page 40.
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 27, 2011 | Motorola Mobility RAZR V3
How do i disable auto text correct?
Hi Smith ric207,
To disable the dictionary in your text panel, while in create message mode, select 'options', then 'dictionary', then 'dictionary off'. That should turn off your dictionary mode.
Alternatively, while in the text mode, at the top left corner of the screen, you would see 'Abc' or 'abc' or 'ABC', with an underline mark.
Toggle your hash key (#) till you see an 'Abc', 'ABC', or 'abc' without the underline. Then your dictionary mode would be off.
Hope that fixed your problem?
Have a nice day.
Jun 26, 2011 | Nokia 2310 Cellular Phone
How to undo predictive text v3
Welcome to Fixya. If you want to undo the preddictive text just follow the guide below.
1. From any text entry screen (ie. when you are writing a text message), press the top center button, the one above the directional wheel.
2. Press on Entry SetUp
3. Select the Primary Set Up or Secondary Setup by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
ITAP: it's a built-in software which predicts the word you are typing. THIS IS PREDICTIVE TEXT
TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter F press the number 3 button three times.
Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
To change from one mode to the next you can select it by pressing the top center button from a text entry screen, and Press on Entry Mode. Shortcut: you can press the # key on your phone when you are writing a message and you will see abc1 for your primary mode, 123 for numeric; @ for symbols; and abc2 for your secondary mode.
If you have questions please let me know. Thanks for using Fixya.
Apr 04, 2011 | Motorola Mobility RAZR V3
I have a motorola v545 and want to turn off the predictive text help!
Go to messages, new message, go to the menu(middle button) select entry options/method/settings, go to primary and select TAP English, go to Secondary and select None.
Text-Entry Methods:
iTAP - Lets you enter words using one key press per letter. The iTAP® method combines your key presses into common words and predicts each word as you enter it.
TAP - Lets you enter letters and numbers by pressing a key repeatedly to cycle through the letters and number on that particular key.
TAP Extended - Same as TAP, but cycles through additional special characters and symbols as you repeatedly press a key.
Text-Entry Modes:
Primary - You can set your Primary entry mode to any iTAP or TAP entry method.
Secondary – You can set your Secondary entry mode to any iTAP or Tap entry method, or you can set it to None if you do not want a Secondary entry mode.
Numeric - Enter numbers by pressing the number keys.
Symbol - Enter symbols by pressing a key; its symbols are displayed at the bottom of the screen. Scroll to the desired symbol and then press Select.
To set the text-entry mode or method:
  • From a text-entry screen, press Options.
  • Scroll to and select Entry Setup or Text Setup.
  • Select the desired text-entry mode or method.
Tip: From any text entry-screen, you can quickly change your text-entry mode without leaving that screen. Press the # key repeatedly to cycle through the text-entry modes: Primary, Secondary, Numeric, and Symbol. With each press of the # key, the mode indicator in the upper left of the text-entry screen changes.
Nov 15, 2009 | Motorola Mobility RAZR V3
Change to single letters
when you open to send text go to menu thern go to entry mode then select secondary mode..
Sep 27, 2009 | Motorola Mobility RAZR V3
Character input when text messaging, just want letters, not partial words
If you press the # key at a text entry page you will have options to change the text entry. You do not want the phone set to iTAP (the symbol looks like an open book with a 1 or 2 on the left page). This is the predictive text mode.You want it in single tap mode which would be just a plain 1.
Sep 09, 2009 | Motorola Mobility i776 Cell Phone
How do you change the text message settings to TAP instead of Abc
How to set up Text Entry Mode?
2. Press on "Entry SetUp"
3. Select the "Primary Set Up" or "Secondary Setup" by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
  • ITAP: it's a built-in software which predicts the word you are typing.
  • TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter "F" press the number 3 button three times.
  • Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
  • Jun 11, 2009 | Motorola Mobility RAZR V3
    When trying to text incorrect letters appear
    There should be an option somewhere when you are in the message menu on how to switch from the text mode that tries to finish your words for you to the text mode where you have to push the button however many times to get the the single letter you want. Although if you are in the auto finish mode you can simply ignore what it's suggesting and continue spelling out the word yourself if you want. example: hit 9 6 8 one time each to spell the word "you"..buy if your trying to be able to short hand text like "thk u" your gonna have to look around in your text mode settings.
    Jan 02, 2009 | Nokia 6126 Cellular Phone
    Text entry problems
    sorry i dont know this yet. sorry for me not being helpful.
    Apr 15, 2008 | Sony PlayStation Portable (PSP) Console
    How to turn off the dictionary function on a Razr V3t?
    Ok so like go to new txt message and when it comes up go to your menu it should say something like insert, entry mode, and entry setup. depending on how you want it change the settings more than likely on entry setup to your preference but check entry mode to I can't xactly remember. hope that works for you.
    Mar 02, 2007 | Motorola Mobility RAZR V3
    Motorola Mobility SLVR L7 Cellular Phone Logo
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
