Question about Dell Latitude D400 Notebook
No power even its plug. started when the battery emptied. when we plugged to the power supply, it doesnt operate by that time.
    President:
  • Dell Master
  • 2,017 Answers
Just remove the laptop battery and connect the power cord. may be battery is faulty and check the adoptor also getting power .
Posted on Sep 10, 2009
Why doesn't it start?
Hi Jake, when checking for spark the CKP needs to measure the compression bump, in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. And the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
3. Fouled spark plugs.
4. Engine flooded with gasoline as a result of overuse of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections, especially the negative cable at "BOTH" ends
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose, or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure," "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sprocket spline sheared or missing spacer.
14. Security alarm system not disarming.
For a primary suspect please visit the website below. If you are still having trouble getting it started you can reach me at xlch@mail.com. Good luck and have nice day.
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jul 30, 2015 | 2001 Harley Davidson FXDWG Dyna Wide Glide
1989 1200 xl sportster some times starts some times wont
Hi Anonymous, and the usual suspects are:
1. Fuel tank empty
4. Engine flooded with gasoline as a result of over use of enrichner.
7. Discharged battery, loose or broken battery connections.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
13. Primary cam sproket spline sheared or missing spacer.
Good luck
Jan 24, 2014 | Harley Davidson Motorcycles
2000 eletra glide has full battery wont start
1. Fuel tank empty
For a primary suspect please visit the website below: Good luck
Jan 11, 2014 | Harley Davidson FLHTI Electra Glide...
Will not start
1. Fuel tank empty
For a possible primary suspect please visit the website below: Good luck
Jan 05, 2014 | Harley Davidson FLHRCI Road King Classic...
Slow chanking will not start,
1. Fuel tank empty
Jan 04, 2014 | 2006 Harley Davidson FLHX Street Glide
Will not start. no lights on power commander box
Hi Jamie, and the usual suspects are:
1. Fuel tank empty
Dec 07, 2013 | Harley Davidson Motorcycles
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
1993 HD fatboy won't start. has spark and fuel and turns over
Hi Leon, and the usual suspects are:
1. Fuel tank empty
Good luck
Jan 05, 2013 | Harley Davidson FLSTF Fat boy Motorcycles
My acer doesnt power on at all i plugged it in to the charger and it wont charge power light doesnt even light up and i plugged it in with no battery and still nothing. any ideas on whats wrong with it?...
Check it by putting it on another Power Adapter. It sounds to me as if the Power Supply has failed... Thats the bit that supplies DC.. to the laptop, and charges the battery, they fail frequently. Take it to a PC store and ask them to test it with another supply. The Power Supply MUST be the same specs tho.
Jan 19, 2010 | Acer Extensa Laptop
Troubleshooting a computer that doesnt start
It's more than likely the CMOS battery a disk shaped 3V watch type battery found on the motherboard. Change this then reset time and other settings and your away.
Dec 26, 2006 | Compaq Deskpro EN PC Desktop
Dell Latitude D400 Notebook Logo
50 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
