Question about Gateway 7330GZ Notebook
How to replace a powerjack
How to replace apowerjack
  • Gateway Master
  • 5,660 Answers
This is a difficult task, that only the most proficient tech should try to take on.
There are very fewer, and fewer techs that do this.
Why?
Because it is easier, and sometimes wiser, to just replace the motherboard.
[Also generates more money for a repair shop $$$$. There ARE instances when it is necessary to replace the motherboard though, instead of just the DC Power Jack. Read on]
That said, read the following, and see if this task is within what you want to take on.
1.Basic static precautions should be observed. The tech must wear an ESD wrist device to help prevent static electricity shock, to the delicate computer hardware components. Your body carries static, and body movements can generate Static.
Static can silently fry out delicate computer hardware components, and 9 times out of 10, you won't see it or feel it.
[A cheap ESD wrist device can be purchased for around $6 to $8]
The Electro Static Discharge wrist device has a cord attached to it, with an alligator clip on the end of the cord. The alligator clip is attached to a good ground source. (I use an empty desktop computer case, and attach the clip to the metal frame)
You should work on a tabletop, and wood, or fake wood is preferred. DO NOT work on a bed, couch, or directly on a carpet floor. These are high areas of Static electricity!
2.AC adapter, (Charger), and battery removed, the entire laptop has to disassembled, down to the bare motherboard in your hand. No processor, Cooling Tube and heatsink, ram memory, wireless adapter card, harddrive, optical drive, Nada. [The LCD screen is removed from the main body, and is not disassembled any further]
3.After THE correct DC Power Jack is located and purchased, then it's time to use the proper tools for removing the DC Power Jack. It's best to use a Soldering Station, but if you are proficient at de-soldering, and soldering precise electronic components, you can use a pencil tip 40 Watt iron. I recommend using Desoldering Braid, instead of using a Desoldering tool. Much easier, and a better tool.
I don't know your electronic repair expertise, but be aware that lingering too long when melting solder to remove it with the solder wick, (Desoldering Braid), can result in burning the motherboard, rendering it useless. Not enough heat when soldering, can result in a 'Cold Solder Joint'.
I pull up on the DC Power Jack to be removed with my fingers, as I'm melting the solder joint for one lead. Use finesse with the amount of force you apply, as you can apply too much force, and pull up a circuit trace right off of the motherboard! As the solder joint melts for that lead, only pull it up so far. Now go to another lead, melt the solder, and pull it out so far. Keep going around the leads until lead, by lead, comes out of the motherboard, and the DC Power Jack is in your hand.
I clean the DC Power Jack area on the motherboard with Isopropyl alcohol. Isopropyl alcohol is VERY FLAMMABLE, and should be used with Extreme caution! Keep the soldering iron far away from it, use in a Well ventilated area.
You want those mounting holes very clean, for the Rosin core solder to stick to it. I make sure the small area around each mounting hole, is tinned well with fresh solder. Gives a good area for solder to stick to, after the new DC Power Jack is installed. After the new DC Power Jack is installed, you may have to clip the leads that stick out, IF, they protrude too far. I haven't found any yet, but there is always the first time.
4.Now reassemble the hardware components back onto the motherboard, and reassemble the laptop.
If you have made a mistake anywhere along the way, you now have an expensive doorstop.
Some laptop motherboards have an area that the DC Power Jack mounts to, that resembles a Peninsula. (Like an island attached to the main body of land)
This Peninsula can break away from the main body of the motherboard. When it does, the circuit traces on the motherboard stretch, then break. (Circuit Trace. Think - Very, Flat, Thin copper wires)
Replacing the motherboard is the best option in this case.
Posted on Sep 10, 2009
    President:
  • 3,085 Answers
Http://www.dcjackrepair.net/
I have used this company 5 times and they did a very good job .
Highly Recommended
Posted on Sep 19, 2009
    President:
  • 1,447 Answers
Follow your user guide or go to authirized service centre
  • Sazeed Computer
    Sazeed Computer Sep 10, 2009
    please brows web side download product guide and follow it
How do you dissasymbule the asus x83v to replace the dc powerjack
the dc power jack on many motherboards is soldered to the motherboard itself. it requires many tools and errors will result in the laptop becomming non functional. recommend taking the unit to an authorized repair center.
Mar 05, 2011 | Computers & Internet
Blank screen even when i turn laptop on.
Sounds like you may have gotten the polarity of the wires mixed up, or the two connections are shorting somewhere. If you heated the wires too much they may have melted through the insulation and short circuited.
You may also have a bad connection inside the computer portion of the jack - or the input, and may have to be soldered back onto the board - entails disassembling some of the laptop..
One other possibility is that the output cord to the powerjack is no good and if you can find another cord with the same type of male plug for it you could break the case apart, solder on a new (used) cord.
An Ohm meter comes in handy here but a simple 1.5 volt light with a battery in line can be a cheap meter for testing stuff.
Hope this helps. Could stick your tongue on the end of the wires to see if you have voltage but I would do it quickly and hope you don't have a bad heart. 20 volts shouldn't hurt you, especially if your not standing in a puddle or have a pace-maker. 4 amps is a lot though, as it only takes 1 amp to kill you.
Feb 23, 2010 | Toshiba Satellite P305D-S8828 Notebook PC
Powerjack replace
you have to strip down the laptop so you can access the underside of the motherbord then you need to desolder the solderd connectors and remove the DC jack
then put the new DC jack in its place and solder back in place
please note this is quiet a big job and requires knowlage of laptops
Dec 22, 2009 | Toshiba Satellite Pro L300 Notebook
Dead short on powerjack
replace the complete power jack cord
Apr 23, 2009 | Computers & Internet
How do I open the HP Pavilion ze 4300 to replace the powerjack
All screws need to be removed off the back of the computer then you need to flip the computer over and then remove the plate right above the keyboard and remove the screws there. Once that is done you will be able to get into the motherboard
Feb 08, 2009 | HP Pavilion ze4300 Notebook
How to fit a new dc powerjack on my toshiba laptop A60
To repair the DC connector on the laptop, you need to disassemble the laptop down to the system board. Here is a guide on how to repair the jack after you get the system bd. out.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 25, 2008 | Computers & Internet
My Satellite P35-S611 will not run on ac power nor will it charge the battery
this happened to me also after window update ..i think it was updating with sp3
Feb 02, 2008 | Toshiba Satellite P35-S611 Notebook
How do you replace the power jack ?
Im not exatly sure what you mean... Are you taking about the whole unit where the cord plugs into (the power supply)? Or just the cord? Define PowerJack plz
Mar 25, 2007 | Gateway M250 Notebook
Gateway 7330GZ Notebook Logo
176 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
