Question about Kodak EasyShare C743 Digital Camera
Confused in Milliken????
I have an issue with my kodak easyshare c743. I replaced the batteries and now it won't turn on fully. It lights up green and begans the process to on but the quicky shuts down and I don't understand why. And once It does that I turn it off and then on again and nothing, when I pull the batteries out and put them back in It does it all over again. What could be causing the camara to do this??????
  • wendy206 Jun 12, 2008
    The same thing happened with mine - when I changed the batteries for higher power ones the camera turned on but the screen just shows "noise" and now none of the other functions work.
Have you made sure that it has not gone back to the eye lens and not the LCD screen i had the same problem and i felt really dumb when i figured it out. hope it helps
Posted on Mar 21, 2008
    Scholar:
  • 151 Answers
Check your battery power, regular alkaline batteries couldn't power up a digital camera, you need at least an energizer e2 or rechargeable types with high current ratings. Try replacing them with high current batteries and it will completely turn on...
Posted on Dec 10, 2007
When does the blinking green light stop
if the battery is getting weak it will never stop get it replaced
Aug 21, 2016 | Kodak EasyShare Z650 Digital Camera
Cannot format my memory card.
Try with a different Memory Card
Try the same Memory card with another compatible device to confirm whether the issue is with the Card or Camera. Please make sure that you're using fully charged battery pack.
Remove the battery and reinsert after 1 minute.
Reset the camera by following the reset procedure from the manual of the Camera.
If the issue persists again, service is required
Dec 31, 2010 | Kodak EasyShare C743 Digital Camera
I have the EasyShare CX7430.The light(green)comes on but it won't open the zoom lens. The ready light comes on red and doesn't go off. You can't push down on the button to take the photo.
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 11, 2009 | Kodak EasyShare C743 Digital Camera
Kodak easyshare M893 IS will not stay on. The battery has been charged and replaced, however, when the camera is turned on the green light comes on, the "Kodak EasyShare" screen appears for a second or...
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Nov 23, 2009 | Kodak EasyShare M853 Digital Camera
My Kodak EasyShare C743 digital camera goes through batteries like water. It's gotten expensive and the camera is so unreliable. Any advice would be very helpful! Thank you!
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Jul 01, 2009 | Kodak EasyShare C743 Digital Camera
C743 digital
A Kodak tech told me to use only rechargeable batteries as regular dry cells do not have enough power and will go dead at the most inconvient time.
Jun 23, 2008 | Kodak EasyShare C743 Digital Camera
Will not operate
Be absolutely certain the batteries are installed correctly. The Kodak C743 battery compartment is poorly marked so that if you don't look at the underside of the flip-out door and see the positive and negative imprints (very faint) you may be installing the batteries upside down. This happened to me as I hadn't used my camera in a long time and replaced the batteries for the first time. Finally, I tried the batteries 'upside down' and it turned on right away.
Mar 17, 2008 | Kodak EasyShare C743 Digital Camera
Kodak EasyShare C743 Digital camra has cracked LCD
You can find a replacement LCD for Kodak EasyShare C743 in this link:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/secFpd27LFqGPg/?ObjectPath=/Shops/160419/Products/%22Kodak%20C743%20713%22
Jan 08, 2008 | Kodak EasyShare CX7430 Digital Camera
Buy a used camera on eBay that has a good screen and change it yourself. It is very simple to do and here are the instructions on how to do it.
http://www.clickondavid.com/LCD7430.pdf
I have done this and it works just fine if you follow the instructions.
Dec 11, 2007 | Kodak EasyShare C643 Digital Camera
Kodak EasyShare C743 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
