Question about Watches
How do take off the knob that winds the hands on a wristwatch
So i want to take the wind knob off with out breaking it
    President:
  • 2,976 Answers
The knob doesn't come off. It is attached to the stem, inside the watch. The only way to remove it, is to open the watch, pull the stem out, loosen the plate and move the pawl out of the way of the stem. If you ever want to use the watch again, it's best to have a jeweler or watchmaker do it.
Posted on Sep 10, 2009
How do you know how much to wind the watch
Your watch needs a service. Options are to send it to Rolex or to bring it in to a Rolex re-seller that offers watch repair. You do not have to send it to Rolex. Expect to pay between $200-$500 depending on what may need to be replaced.
Jun 02, 2014 | Rolex Submariner 16618 Wristwatch
My automatic omega watch stops after 20-24 hours eventhough i am promised it should last for 48hours if worn continuously for 48 hours.
Almost all automatic wristwatches made today have an 18-24 hour "power reserve" when fully wound. A 24 hour reserve is actually very, very good. I can't think of a modern self-winding wristwatch that has a 48-hour power reserve because that would require a super-long or much larger mainspring than would fit in a modern watch movement / case. There may be some hand-crafted or super-premium watches that can do this, but only a very select few.
Manual wind railroad pocket watches, which were some of the finest and most accurate mechanical watch movements ever made, generally had a 40-hour power reserve. That extra capacity was created by using a large mainspring to store the extra energy. These mainsprings could be used because of the much larger size of these watches, compared to modern wristwatches.
If you are concerned about keeping your watch ticking, even when you're not wearing it, you might want to look at a "watch winder"--basically, a small watch case that rotates the watch for you, keeping the automatic winding rotor moving and the watch ticking. In addition, sitting at a computer all day will wind your watch much less than walking and otherwise moving around. Even though you're wearing your watch, if you're not moving, you're not winding it.
May 09, 2011 | Watches
Cant set wrist watch
To set a basic wristwatch, simply pull the crown (the winder button at the 3:00 position on 99% of watches) out gently - it will click into adjusting position. Wind to send time and then push back in again.
Variations on this are: If you have a watch with date display, the crown will have 2 positions, the first click will be to set the date and the second click (fully out) is to set time. If you need to adjust the date, I suggest you wind the date to the day before you need and then use the second click to wind the hands to the correct date. This way you will be able to know if you have the hour at a.m or p.m position and avoid it have the date changing during the day instead of at night.
One last variation for wristwatches is a screw down crown. Some water resistant and sports models incorporate an added feature whereby the crown is threaded so it can be tightened down to avoid water entering - the most common place water gets into a watch! If you have one of these, you simply need to screw the crown anticlockwise until it pops out and then refer to the instructions above. Don't forget to push and screw the crown back in clockwise when you are done
Apr 07, 2011 | Movado Juro 0605023 Wrist Watch
How do i set the date on a locman ref 487?
  • To set the date you pull out the winding knob to the first stop and turn it either clockwise or counter clockwise to set the date. The second stop, or the stop furthest from the body sets the time.
Mar 07, 2010 | Locman LOC487MOPFBK wristwatch
It just wont wind
Wind it back and forth at least 15 times, then twist the watch very quickly back and forth a few times. That should restart the balance wheel moving. Twisting motion must be around the axis on which watch hands are fitted.
Feb 28, 2010 | Rolex Day-Date President 118238 Wristwatch
Tag Heuer date adjustment doesn't work. I pull the crown out one notch, turn it clockwise, and nothing happens. Turn in it counter clockwise, nothing happens. ???? The only way to adjust it is by adjusting...
The date change occurs at midnight, so winding it past midnight changes the date. To change it again wind the hands backward to (say) 11 O'clock) and then forward again will change the date again.
How far you need to turn it back will have to be found by experiment.
Jan 03, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
WIND UP MY ARMANI AR0203
Try puting it off and wind it then.
Dec 31, 2009 | Giorgio Armani Emporio Armani AR0203...
My winding knob is missing
A watchmaker should/may be able to source replacement parts for you and fit them as well.
Jul 26, 2009 | Locman LOC487MOPFBK wristwatch
How do i get my Lucien Piccard 26570SL Automatic running?
You have to wind the watch first. Pull out the crown (the knob on the right side of the watch) to the intermediate position (the winding position will not move the hands or the date so this is how you know that you are in the correct place. Most watches have 3 positions where you can set the date, time, and wind it) and wind the watch. It will need to be re-wound every 24-48 hours.
Jan 05, 2009 | Lucien Piccard 26024 Wrist Watch
Indiglo WR 30M
i wind the clock hands forward until the calendar date and week day changes and then i re-wind the hands until it comes to the correct time. when i re-wind the hands, the week day goes back to the correct date and the calendar date does not go back by one day. i don't know if this is the "correct" way to do it, but it works.
Sep 12, 2008 | Timex 27191 Wristwatch
Watches Logo
655 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
