Question about Windchaser 3-way Oscillating Fan
Cooling fan not turning
Blower working and contater working but cooling fan not turning spins a little rough but spins like needs oil when unit turned on i makes no noise and wont turn
  • 512 Answers
You need to replace it.
Which cooling fan? There are sometimes several and the hardest one to replace is in the power supply. If you are handy with tools and don't mind the work, you can replace it yourself, otherwise you will have to get someone to do it for you.
Posted on Sep 10, 2009
Suzuki x4 2009 fan does not spin but when I turn air on it blows cold air.
Not sure which fan you mean. Engine cooling fan is different from heat/air blower fan.
Feb 04, 2015 | Suzuki Cars & Trucks
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Blower motor relay make clicking sound when i turn the heater on. Changed relay and still does the same thing
Sounds like your blower motor may have either ceased, or gotten an obstruction. Sometimes an animal will crawl into your heating unit and make a nest or other things get in there and bind up the hamster wheel (fan). Start by checking for power at the fan using a test light with a wire probe end. If you have power at the fan with the switch on but it's not spinning, first check for an obstruction, if no obstruction, check to make sure the ground is good from the motor (make your own ground with the test light by probing the ground) if the motor spins up, fix the ground wire, if not, time for a new blower motor unfortunately.
Nov 13, 2013 | 2005 Chevrolet Aveo
FA4B blower assembly noise
It is possible that the actual fins have separated from the hub. Hold the shaft of the motor (as to stop it from spinning) and the try to spin the fins. You then may notice the welds are broken. Could just be a bad motor, could be just the wheel. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 31, 2017 | Carrier Heating & Cooling
Outside fan on heatpump not spinning
Are you cooling or heating? In the cooling mode the fan should run with the compressor. Shutdown, open up control section of unit, check Capacitor. Try to turn fan blades by hand. Does it spin freely? Do not touch capacitor terminals until you discharge it by shorting terminals to ground. If the capacitor looks swollen then it is bad.
Aug 08, 2011 | Heating & Cooling
Tempstar a/c condenser screeching noise
Could be the fan motor's bearings. Try turning the fan by hand to see if spins freely or is tight. If it's tight you can try oiling it but that may not work for long.
May 30, 2010 | Heating & Cooling
Carrier fa4anf024 blower is not working. Pipes are getting frosty so the compressor must be ok. I hear 'gurgling' from the air handler, but no fan
you can remove the top panel by removing the 5/16 screws his will gain access to motor turn the power off to the unit and check if the motor is hot. if it is let it cool and retest if the motor makes a loud humming noise and does not turn try to manually spin it if it starts up you have a bad capacitor if it wont turn it is seized and the motor will need to be replaced . If it cold and makes no noise you may have a bad blower relay, you will need a volt meter to test. that motor is 240voltmotor
Sep 24, 2009 | Heating & Cooling
After about 5 minutes the unit stops working. No sound or even a fan noise. I just cleaned the filter to see if that helps, but it didn't.
Is the fan running and stopping before the unit completely quits?
If the fan quits the compressor won't run very long.
I would start with the fan motor or capacitor.
Shut the power off to the unit, spin the blower wheel to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
r.
Aug 21, 2009 | Dehumidifiers
RV A/C blower not working and keeps kicking out
If blower not working, and yoou hear a slight "Hum" with fan only on, try this. With power off to AC. Go up on roof, and slide a stick through opening on side near rear, and try to get to fan blades at rear of unit. try to spin the blades a few times, even if it only goes a little at a time. Unless you want to take all those screws out & remove cover to get at it better, but watch for wasps under there. Give fan a couple of full rotations, then have someone turn it on to fan only & see what happens. If fan finally works, let it run for a few minutes on fan, then try cool & see if it all comes together again. Let me know.
Jul 17, 2009 | Dometic Rooftop RV Air Conditioner
OUTSIDE UNIT OPERATES BUT FAN DOESN'T TURN AND UNIT DOESN'T COOL.
the motor could just be locked in place from sitting...take a stick or something and try to see if it spins be sure of rotation! you can also give it a little nudge while it is on and it will take off! if this happens then you have a bad start compacitor but no there are no fuses that only protect the motor!
May 25, 2009 | Goodman CKL42AR42 Air Conditioner
Dryers Logo
153 people viewed this question
Top Windchaser Dryers Experts
Ian Summerfield
Ian Summerfield
john h
Vernon Taylor
Are you a Windchaser Dryer Expert? Answer questions, earn points and help others
