Question about Clarion APX480M Car Audio Amplifier
Blue power light blinking
I have a Clarion APX480M in my boat and the power light is blinking blue. Is that normal? All my speakers connected to that amp don't work now. Ive tried disconnecting everything and just leaving power/ground. Nothing works, I need help if someone can explain to me what going on.
5 Suggested Answers
  • 37 Answers
SOURCE: I have a APX480M clarion amp that the power light
you should check the remote cable on the amp which connects to car stereo if its connected.
Posted on Sep 17, 2009
SOURCE: Clarion APX480M amp
This sounds like a signal problem. Make sure that all of your signal cables are plugged in fully. If all are, you need to check for coninuity between the shield ground of the head unit's RCA jacks and the case of the head unit. With no RCAs plugged into the head unit, you should read ~0 ohms between the shield of the RCA jacks and the case of the head unit.
Posted on Sep 09, 2007
Benimur
  • 6966 Answers
SOURCE: fuse for pwr amp.
For a single Clarion APX480M, the inline fuse should have a rating of 40 amperes.
Incidentally, perhaps a copy of the installation manual would be of use to you. One is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 16, 2008
jdinse
  • 74 Answers
SOURCE: My Clarion APX480M marine amp cuts out at random
try to unplug each speaker one by one while playing it. There can be a defective speaker that grounds out at the speaker terminal or internally causing the amp to go into protection causing all the speakers to go out.
Posted on Jun 08, 2010
I have a clarion axp480m. the power light is blinking blue and it will not allow sound to the speakers.
Tried all that and still mine is in protect mode. Every other amp works fine on the wires but that amp is an epic fail. Solution: DO NOT BUY THIS TYPE OF AMP...
May 19, 2011 | Clarion APX480M Car Audio Amplifier
I am changing out a Clarion ARX7570z to NZ500. Have most of the bugs worked out but I need a wiring diagram for the ARX to figure out the which wires are which. HELP!
the wiring diagram is out dated for the cassett player ....
here is what i know
red is ignition swichted
yellow is contstant power
black is ground
blue power antenna
blue with white strip amp turn on
gray + f right speaker
gray/black strip - f right speaker
white is + L front speaker
white with black strip is - L front speaker
green is + L rear speaker
green with black strip - L rear speaker
purple is + r rear speaker
purple with black strip - r rear speaker
your orange with white strip is illumanation not used
100% of all aftermarket radios are color code this way if you have install diagram for new radio it will be the same as old clarion radio ..
but make sure u have a digital volt meter to check power on red and yellow wire and comming from the factory harness be for you connect new radio just to make sure it does have powers and check other wire for power also just so you dont blow up new radio ... you can blow up a radio by connecting a wrong wire faster than you can blink your eyes ..... if you need a wire diagram for you modle car email me with it a http://www.tintingbyfredjohnson.com and go to contact and send email
Dec 28, 2010 | Clarion ARX7570z
I have taken the head unit out of my old boat, would like a wiring daiagram, to installin my new boat!
Red = switched power
black = ground (earth)
yellow = bat power (on)
blue white striped antenna turn on
solid blue remote turn on for amp
(speakers)
(all will have one with black/white stripe if all sets have black = ground if all sets white = hot/+
green = rear
( cant remember left/right)
purple = rear
white = left front
Red = Right front
all of this should be on the bottom of the stereo
Dec 14, 2010 | Clarion M255 AM/FM Marine CD Player
Jun 05, 2010 | Clarion APX480M Car Audio Amplifier
We had a clarion reciever with tape deck in our boat and found another clarion reciever with two new speakers and two good 1996 speakers which had not weathered. The instalation was difficult but the...
As long as you have connected the ground(black) try adding one wire at a time to the live(red). If possible try connection each wire one at a time to the power line and then both together. If nothing has blown(fuses) and the unit starts working then you can try by trial & error method the remaining wires. You should be able to figure out which wire is required and if there are any extra wires like cellular phone(mute) and then decide whether to connect them or keep them open.....sodeep
Jul 27, 2009 | Clarion DB245 CD Player
Three blue lights blink
check you speakers and power source make sure all connection is correct
May 26, 2009 | JBL CS300.1 Subwoofer Mono Amp - 200W CS...
Clarion APX480M amp
Aug 28, 2007 | Clarion APX480M Car Audio Amplifier
Clarion radio wiring diagram
i have the same stero in my boat made 2004 it is easy red(hot) black (Ground) Orange (Illumination) (hot) the 2 fused yellow is bat direct (memory) blue w/white stripe (remote) solid blue (power attenna) the 2 white wires ft left speaker, 2 gray rt front, green left rear, purple rt rear, the single brown is for the changer i believe
May 28, 2007 | Clarion DXZ645MP CD Player
400 watt amplifier not working
Disconnect all the speaker wires from the amplifier that runs the 6-speaker system. Switch off the amplifier or disconnect the remote turn-on wire, then re-connect it. Does the power light still flash with no speakers connected? If so, your amplifier is probably damaged. If not, then connect one speaker and see if it plays. If it doesn't, disconnect the first speaker and connect a different one. If the first speaker plays, continue connecting the rest of the speakers until you find the one that's causing the problem.
Mar 05, 2007 | Clarion APX401.2 Car Audio Amplifier
Clarion APX480M Car Audio Amplifier Logo
288 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
