Question about Konica Minolta magicolor 2300DL Laser Printer
Prints an inch low on paper sheet
Printings are done with an offset of 1 inch below the sheet border.
The solution is to clean sensors and paper path feed rollers. You must follow the Maintenance Manual or perhaps use an special cleaning sheet.
Posted on Sep 11, 2009
    Master:
    Sergeant:
  • 460 Answers
It is a cartridge problem. so pls replace it.
Posted on Sep 10, 2009
What causes the printing to be cut off around the page edges on my Kyocera FS 4020DN?
when we want to print from email then
there is a print button within email if self probably right side of email which one is opened
a small print symbol is there try with these button
it opens a new widows from which good print can done
Aug 19, 2014 | Kyocera 1102J22US0 Model FS-4020DN Laser...
Paper jam
Duplo and Karagatan were early forms of Philippine drama.The Duplo was a poetic debate by trained men and women in the ninth night, which is the last night of the mourning period for the dead. The Karagatan was also a poetic debate like the Duplo, except its participants were amateurs. Both were held in homes and their theme was about a ring that fell into the sea.
Jul 13, 2013 | Brother MFC-J410W Wireless Compact...
My Kodak ESP3250 printer won't print invitations. It just keeps spitting out the invitation and telling me I have the wrong size paper.
This is common with these printers. When you go to print and the kodak dialog print box comes up you need to change the paper size manually for the printer. The printer does not always take the correct paper size from the program you are printing in if it is a custom document.
another word of advice. USE THE TEST SHEET FIRST. This printer does nto correctly print invitations you need to offset the items about 1 inch to the right or so. Test before you print the real things.
Jun 13, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
The printer is feeding a blank sheet of paper between printed sheets. How do I rectify this?
This causes the printable area on the page to be that much less (10 3/4 or 10 1/2 on an 11 inch page). The software thinks the paper is 11 inches long and keeps track, down to the micro inch, where it is on the paper. When it reaches the 10 1/2 inches, your printer calls the page done and ejects it. However, the software thinks there is still another 1/2 inch to print (usually the footer area). Now when you insert a new sheet of paper, the software finishes printing the rest of the page (normally a blank footer) and form feeds to the next sheet. To correct what the software thinks the paper size is, you need to run the Preferences application and change the default settings. Select the Printer button. In the next window, select the 'Change Defaults....' button. Change both the Document size and the Paper size to a height of 10.875 and click OK. Try a new document to see if the paper size is correct. You may need to go back and change the height a few times until it is correct (the height changes in .125 increments). Usually either 10.875 (for 1/4 inch forced top margin printers) or 10.75 ( for 1/2 inch forced top margin printers) will work.
Oct 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
Trying to Print USPS Labels from PayPal on TLP 2844
see if you can set the printer preferences to borderless printing.
Jun 14, 2009 | Zebra Eltron TLP 2844 Thermal Label...
After paper jam text is offset 1 mm every 0.5"
you still have a piece of paper stuck some where in the paper path have a closer look
May 12, 2009 | Canon Pixma iP2600 Photo InkJet Printer
I print borderless several times & found white border both side
This is because the image is of a different aspect ratio than the paper. That is, if your image's dimension is 8x12 inch and you are trying to print it on an 8x10-inch paper, the printer will adjust the longer side to 10 inches. Hence the shorter side will become less than 8 inches. This will lead to white border on the shorter side. If you try to adjust this, the longer side will fall out of the paper and hence in the print, this portion will be cut.
So please understand that this is normal. One option to prevent this is to crop the image to fit the paper size.
Apr 13, 2009 | Epson Stylus Photo R200 InkJet Printer
Wide black streak on back of printed paper
it is not directly coming from the head. Probably you are printing your photos without borders. This means that the printer prints slightly beyond he paper. As a consequence is sprays ink on the mechanics and after a while it starts to smear on the back of the paper.
This phenomenon is even mentioned in the printer manual (kind of caution when selecting borderless printing).
There is a menu item in the printer utilities that lets you clean the printer mechanics with a folded paper. I tried this, but it helps only little.
I have the same effect on a pixma IP 4500 , and I live with it.
Cheers
Critter
Dec 29, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Dark border one side of paper
This maybe your cleaning blade, your drum or the fuser unit....the best way to find out is to make a copy a to stop it before it's getting to the fuser unit ( that's the thing very hot). If you see your border it's your cleaning or drum...But when you replace a drum you must replace the cleaning blade to !
Hope it help !
Apr 04, 2008 | Office Equipment & Supplies
Konica Minolta magicolor 2300DL Laser Printer Logo
197 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
