Question about Acer AC713 17" CRT Monitor
My acer AC713 monitor's brightness value gets reduced to zero.
While working with comp more frequently the brightness display appers and brightness value gets reduced to zero and it never stops, it still tries to reduce the value.
  • 615 Answers
Dear sir,
This is common problem arises mainly due to moisture,especially in rainy season,Monitor front panel control buttons remain pressed,due to deposition of ferric oxide and moisture in between monitor botton panel and circuit board.So you can dry this moisture by hanging a bulb of 60 watt nearer a monitor about 4-5 hrs,(too near may damage the internal heat sensitive parts.).It solves your problem.....and also you may clean the inner monitor button contacting circuit by means of PCB cleaner to wipe out ferric oxide deposition.
if you had any query regarding this issue leave a feedback we glad to assist you.
good luck.
Posted on Sep 10, 2009
  • mohits477 Oct 20, 2010
    thank you my name is Mohit Singh Chouhan
    New Friend:
Dear sirs, I have acer AC713 CRT monitor is shows dimm picture(insufficient brightness) eventhough it sets brightness to 100%.
Please kindly solve the prolem
regards
Posted on Mar 12, 2013
Well i tried using a candle close to it..not too clsoe...but needed immediate results hehehehehe...but it might have worked without frying the circuits...not sure it worked but its gone for now ;) i wud say yes to try this solution... :D
Posted on Oct 09, 2011
Hi guys. i hav an acer ac713 crt monitor. the cable that connects the monitor to the tower/hardrive has been cut by burglars. where can i find a wiring diagram to fix it? thanx.
in 15pin connector of the monitor,
red wire goes to pin No:1
green wire goes to pin no:2
blue wire goes to pin no:3
yellow wire goes to pin no:13
white wire goes to pin no:14
and black wire goes to 5&15. Now display will come!
Sep 08, 2010 | Acer AC713 17" CRT Monitor
Acer CRT moniter 17" Model: AC713 dost not display any thing.
Ok if you prese the menu button on the monitor does the monitors setting menu appear on screen
If it displays adjust the contrast and brightness until a picture appears
If that does not work place a fringe magnet on one of the corners of the monitor if there is now green tinge around it than there is no electrons being fired at the screen and you have missed something so test every component
Mar 14, 2009 | Acer AC713 17" CRT Monitor
Screen settings
You want to recall the factory settings. There should be an entry in your menu for this. Sometimes its clearly indicated as 'reset' sometimes it is a word that means much the same, such as 'recall'.
The numbers you posted that have a 'K' at the end are settings for the white color temperature. This is an old label from the early days of TVs. One is better than the other for graphics vs clarity. Usually you want the higher setting.
Other wise, if you can't locate the reset option. Go into each setting for Contrast, Brightness and set Contrast 50 and Brightness 100, the others affect the position of the display and how square it is. Set all those values for trapazoid, etc to 0.
Anything else you need clarification on please comment back and I will validate or correct your instincts on what is the reset option command if you are unsure about what is being displayed.
Regards,
Worldvet
Jun 08, 2008 | Acer AC713 17" CRT Monitor
Fonts and brightness
1.Change your display settings.
Right click somewhere on your desktop, then click on properties.
Click on the apperance tab.
Under Font Size:
change it to large, or even extra large.
2.
Use the buttons on your monitor. Usually there is a menu button. Navigate your way through the menu to find a brightness options.
3.
Just head over to the manufacturers website for that info.
If its a dell, go to www.dell.com
if its a gateway, go to www.gateway.com
Go to their support section of their site, and just look around.
Hope this info is useful.
-Chad
Dec 11, 2007 | Acer Aspire T690 (AST690UP820A) PC...
Acer AC713 17" CRT Monitor Logo
1,034 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
