Question about HP Pavilion dv4000 Notebook
My laptop screen have a thick line at the bottom of the lcd... why it is there........?
  • Dale Barrett
    Dale Barrett May 11, 2010
    Can you give a description of the line and its color please. Thanks...
    President:
  • HP Master
  • 2,017 Answers
It is screeen problem try to change the dispaly resolution see it is good or show it service center.
Posted on Sep 10, 2009
  • mukhtar21 shaikh
    mukhtar21 shaikh Sep 10, 2009
    it is screeen problem try to change the dispaly resolution see it is good or show it service center.
4 Suggested Answers
Pyrhyc
  • 2028 Answers
SOURCE: Thick Black Line on Screen
This is caused by dead pixel sensors. There are hundreds of pixel sensors at the edges of the screen, when they go out it will cause a line varying in size depending on the amount of sensors that go out, and the line can vary in color, red, blue, green, white, and black. Unfortunately, the only fix for this is to replace the screen.
Posted on Jul 30, 2008
SOURCE: my toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external monitor to your laptop's video-out, and then swap your monitor view to 'both' or mirrored (usually just the function key (FN), plus one of the Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
Posted on Aug 21, 2009
  • 8 Answers
SOURCE: a straight line appear on bottom of the screen
how old is your laptop?
try running a powerfull anti-virus.
back up everithing in your hard drive (image file if u can) and recovery CD so u reset it to factory defaults. if it's still getting worse. go to a repair store, monitor or video bus is malfuncioning.
Posted on Sep 03, 2009
A small horizontal line going across the bottom.Now a horizontal shadow appeared above the line.Each day a new shadow appears & lighter then the rest.Now a thick box of silver/purple lines at bottom.
Seems like back-light fault. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 12, 2016 | Televison & Video
Samsung TV thick black line running across the bottom.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 08, 2016 | Samsung PN51E450 - 51" Class 50.73...
Samsung lcd tv
May 22, 2016 | Audio Players & Recorders
How do i remove the thick black line at the bottom of my tv screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 19, 2014 | Luxor 27 Inch 2 Shelf Mobile TV Cart -...
My Sony Bravia 46" has a 1" thick black line horizontally thru the middle of the screen. It separates the top and bottom. Has anyone seen this happen before?
It sounds lcd screen problem and lcd panel (screen) will be replaced. Please check with local tv repair shop or nearest Sony service center for lcd screen replacement.
Jun 17, 2010 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
HI, Thick white vertical line on screen
your lcd screen damaged.u need to replace it with new.
Dec 08, 2009 | HP Pavilion zd8000 Notebook
My toshiba laptop has a thick white line down the screen
Hope this helps.
Aug 21, 2009 | Toshiba Satellite p105-S6114 Notebook
42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Aug 19, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Thick Vertical White Line Through My LCD Monitor!!!
You can check if it is a screen or not. Connect another screen to your laptop. If you dont have anotherone you can use your friends screen or go to the nerest computer store and test one there. That way you know 100% it is the screen or another thing: video card wireing...
Nov 12, 2007 | Computers & Internet
HP Pavilion dv4000 Notebook Logo
155 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
