I am using an HP L1706 monitor... This issue happens at random times but I was able to fix them just by turning off my computer and for some reason when I check the back of the tower... reconnect and disconnect the VGA cable it'll work. But last night the problem happened again. I tried to do the same thing and it is still not working. Thinking that it's not the monitor or the VGA cable that's causing the problem I tried to connect my SAMSUNG SyncMaster 753 DFX monitor using also a different VGA cable. Still the same problem happened.
It might be the tower itself that's causing the problem. I've noticed that the motherboard's green LED is not lit. Though theres is power because all the fans are working. Even the GeForce 9500 GT fan is working.
Can it be the motherboard??? I'm using a FOXCONN G31MV Series motherboard, 4GB RAM, Core 2 Duo processor, 250GB SATA HDD, and a GEFORCE 9500GT video card.
may be the power button get stuck when you pressing to switch on.just change the power button cable with reset button and see. also chek the **** aslo just remove it and clean it and fix it again.
hii i got a hp l1706 lcd monitor, the problem i have is the screen is completly not turning on. but...
(More)
hii i got a hp l1706 lcd monitor, the problem i have is the screen is completly not turning on. but the led green light flashes for some seconds and thne it also turns off. can u help me in this plzz
numai lumina amprobleme cu invertorul.nu gasesc nimic date despre mosfet 9960gh.as dori va rog daca...
(More)
numai lumina amprobleme cu invertorul.nu gasesc nimic date despre mosfet 9960gh.as dori va rog daca se poate cu ce sa in locuiesc 9960gh.documentare .va multumesc anticipat
