Can't setup my Bytecc Me-850 LanDisk network storage device.
I've got a Bytecc Me-850 LanDisk network storage enclosure. The box and website both say mac compatible, but there are only instructions for setting it up with a PC. I've got a mac and I can not get this to work.. anyone here have a similar problem or solution.
I've contacted the manufacturer by email, but they have yet to respond. I'd use a PC but unfortunately all 4 computers I have at home are Macs.
I would imagine that the drive you put in the 850 has to be formated so a MAC can see it. That would be fat 32.
Posted on Dec 26, 2009
I had to replace my router and I now cannot see the dlink enclosure. I wanted to get the IP so I can reconfigure the IP address but like I said I cannot seem to get the device to show up on my belkin...
You can try a couple of things, easy thing is to reset the NAS server by unplugging it and allowing it release its leased IP address, assuming that it is setup for DHCP. Once this is reset it should grab another IP address. If you remenber setting it up for a static IP, then you could do a google search for an IP scanner http://www.radmin.com/products/utilities/ipscanner.php or find one that you are comfortable with download and install look for device on your network that will give you your IP to the NAS server. Good luck
Nov 28, 2010 | D-Link DNS-321 Network Attached Storage...
IDE hard drive in Bytecc ME-535U2 enclosure not recognized by OS
smc4
There is a couple of things that could be going on. The first thing to check is that the drive did not get bumped off its drive letter by another device. If that is the case you just the to assign it a new one. The link below will help you do this.
http://www.fixya.com/support/r4183994-change_drive_letter_in_windows_xp
The other issue is the drive may have gotten disconnected improperly. I had the same problem with one of my drive on my XP system as well. It partly has something to do with the USB controller to my understanding. Alot of times if you plug it into another computer it will detect it and ask to run a scan to repair the drive. After this you should be able to access the drive on your XP system again. Note I have the best resolutes when I plugged the drive into my Vista system. So I would recommend trying to plug it into a Windows Vista or 7 computer to attempt the repair.
Let me know if you have any more problems or questions.
Issken
Feb 23, 2010 | BYTECC ME-535U2-BK Aluminum 5.25'/3.5'...
Please can you tell me user name and password for web interface?
username: admin
pwd; <blank> just leave blank
try also u:dmin p:admin
Sep 24, 2009 | Ma Power 3.5" LanDisk, IDE to USB / RJ45,...
Windows won't recgonize my enclosure
My Setup:
Bytecc Model ME-535 hard drive enclosure with Seagate 80GB SATA drive (ST380815AS) hard drive.
My Problem:
I plugged in but didn't see anything in My Computer.
My Solution:
After Windows finds your device -> Start -> Run -> compmgmt.msc -> OK -> click on Disk Management -> a pop up will ask if you want to initialize the disk, select MBR -> OK -> your disk should show up as unallocated -> right click on that disk -> New Simple Volume -> Next -> next -> Assign drive letter: E -> Next -> Format this volume NTFS with quick format -> Next -> Finish -> It takes a minute or two to finish formatting -> Now shows up in disk management as "Disk1: New Volume (E:) -> My Computer -> see E drive now and it is working!
Jun 13, 2008 | BYTECC 1 Bay ME-350U2 USB 2.0 External...
Software for 500GB
I don't think BYTECC sells complete external hard drives. But they do sell the enclosures. People buy the enclosures and install a hard drive in them and, now you have a working external hard drive. I have don't this before, but I have never used BYTECC before. You can download the drivers for there enclosures at there website:
http://www.byteccusa.com/
They have several different versions, Just pick the correct one, hopefully the enclosure has some markings or a sticker identifying the model.
Nov 17, 2007 | BYTECC 1 Bay ME-350U2 USB 2.0 External...
ME-940 usb enclosure not reconized
This behavior occurs if you map a network drive to the first available drive letter after the drive letters for the local volumes and CD-ROM drives. When you install a new device or volume, Mount Manager, which assigns drive letters to volumes, does not recognize the mapped network drive and assigns the next available drive letter to the new device or volume. This causes a collision with the existing mapped network drive. To prevent this issue from occurring, when you map a network drive, assign the highest available drive letter to the mapped network drive. To work around this issue if the new volume appears in Disk Management, specify a different drive letter for the new device or volume. To do this, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Disk Management. 3. In the list of drives in the right pane, right-click the new drive and then click Change Drive Letter and Path(s). 4. Click Change, and in the drop-down box, select a drive letter for the new drive that is not assigned to a mapped network drive. 5. Click OK, and then click OK again.
May 29, 2007 | BYTECC Aluminum USB 2.0 5.25'' External...
Problem with external enclosure ( No power)
Perhaps the gentleman at the store did not connect the power from the case to the drive itself.
Feb 11, 2007 | BYTECC 3.5" Aluminum USB 2.0 and Firewire...
Computers & Internet Logo
392 people viewed this question
David Payne
David Payne
