Question about Sony PlayStation 2 (PS2) Console
When the disk tries to turn it has a buzzing sound. Observing it I noticed the disk is having trouble turning. How can I fix this?
  • 767 Answers
Sounds like the coils have shorted out in the
spindle motor .
you can buy a new drive motor from (richs psx repair)
cost around 10.00 -20.00 and replace it yourself.
or send it out for service at a shop . A fair cost
for that repair should be around 45.00 .
Rob
Posted on Sep 10, 2009
  • nnelsen Apr 03, 2011
    Thats not the problem. i just took mine apart and cleaned it and then i had that buzzing sound. I spent 4 hours on it. It you take everything off and then you will see strips of wire coming from the motherboard to where the disc holder is. Unplug all of them but not the power one. plug them back in and make sure they are tight without putting every thing back on, plug the power in and there are two little black switches that are located on the chip that has the power button and the other is in the upper left corner of the of the disc tray. push both of them while you have it plugged in and make Sher that you turned it on. It shouldn't make the buzzing noise. If it does, then unplug it and then the little tab that over hangs a little gold colored screw, push it down a few times. then repeat the step before this. I tried it afterward and it worked much better. And didn't have to pay a penny. contact me if you don't understand this. i can walk you through it. Contact me at nicholasnelsen@yahoo.com
Today I bought SONY KDL37EX402 LCD TV. Immediately when I turned it for the first time I noticed an unpleasant sound like a “buzzzzzz” from the back of the TV. As I worked it for more then 5 hours I...
Take it back and see if another does the same thing before you get out of the store. There's something loose in the backlight circuit, like a power inductor. They shouldn't do that.
Apr 08, 2017 | Sony Televison & Video
Polaroid 37 in LCD TV
combination of loss of your power supply and blown resistors take it to a shop
Aug 30, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Today I bought SONY KDL37EX402 LCD TV. Immediately when I turned it for the first time I noticed an unpleasant sound like a ?buzzzzzz? from the back of the TV. As I worked it for more then 5 hours I...
I'm pretty sure that the buzzing sound is a not normal thing for an LCD TV. I sell Flat Panels during my spare time and it should be as quiet as a CRT types. It is more likely a defect and you should return it ASAP.
Hope this helps.
Oct 23, 2010 | Televison & Video
When I push the start button a buzz sounds and the
sounds as if the motor is not starting,try to turn tumbler manually.if tumbler turns but motor does'nt start check motor.
Oct 16, 2009 | Dryers
Vizio GV42l buzzing
Vizio makes an ok LCD, but if you notice they no longer make plasma. they stopped last year. Anyways. the buzzing sound is semi serious, it sounds as though you have a capacitor leaking. It is best to get it fixed before it goes out all the way, with it buzzing it will be easier to identify. Best of luck
Sep 12, 2009 | Vizio GV42L 42 in. LCD Television
Makes buzzing sound. will not start..battery is charged.
to trouble shoot the problem try to check the ignition switch .and the solenoid if the battery is charge .
Jul 30, 2009 | Yamaha Royal Star Tour Deluxe Motorcycles
Whirlpool lgr4634eqo makes a buzzing noise when trying to start
Try holding the door switch lever in and turning the drum hard by hand. It sounds like you have a start switch out in the motor.
May 20, 2008 | Whirlpool LGV4634JQ Gas Dryer
Buzzing Cerwin Vega LS-12 Subwoofer
Generally, a buzz from your sound equipment indicates some sort of nearby EMI. The normal culprits and.or possible fixes that I've found are:
- Remove any other electronic devices plugged into the same outlet as your subwoofer
- If the woofer is on a power strip/surge protector, remove it and plug directly into the wall
- If there are any nearby wireless devices (cordless phiones, WiFi eqiupment), disconnect/power down them
- Try connecting different speaker wire between the woofer & the receiver
- Try turning off all other eletronic equipment with the exception of your receiver
Let me know if any of these help and good luck!
Nov 27, 2007 | Audio Players & Recorders
Does not drain & makes a loud buzzing sound(KENMORE 44042)
this sounds like something has gone into the pump, coins or whatever, the objects need to be removed, also check the hoses, remove the plug to work on any appliance the buzzing is the pump trying to work but unable to go round, start there and see how you go if i have helped rate me please
Sep 12, 2007 | Kenmore 44042 Front Load Washer
Sony PlayStation 2 (PS2) Console Logo
76 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
