Question about Xerox WorkCentre M118 Black and White Copier
Xerox workcentre M118 is having problem in pulling the paper to the fused roll.. what could be the problem?
  • 388 Answers
Most likely one of the rollers in the paper path between the developer and the fuser is slipping. You are going to have to get a Xerox tech to take a look at it.
Posted on Sep 16, 2009
Testimonial: "it was hel[ful, and I am looking for the xerox tech to correct the problem.. Thanks for your valuable solution "
How to reset xerox m118 drum
Hi, I have a solution to your problem click on the link below which will direct you to a step-by-step guide to fix your problem!
Xerox Workcentre 123 128 Reset Drum Life Free
Aug 26, 2014 | Xerox WorkCentre M118 Black and White...
I need Xerox workcentre M18 Drivers
Xerox WorkCentre M118 Drivers
The required drivers can be downloaded from the above link from Xerox Official Support. Select the operating system you have on your PC and download / instal the files.
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Xerox WorkCentre M118 Printer
How to install xerox workcentre M118 for windows 7 64bits
I am one of the technician trained and specialized in different computer  and printer manufacturer.
Here is one of the instruction on how to install your printer to windows 7 64 bit
-run the driver downloaded from the site, then select the location
http://www.support.xerox.com/support/workcentre-m118-m118i/downloads/enus.html?operatingSystem=win7x64&fileLanguage=en
-Go to Control panel
-choose devices and printers
-add a printer
-add a local printer
for Standard TCP/IP port has already been created on the computer, choose the port from the Use an Existing Port pull-down menu, next, and then skip to step 10.
For the port has not been created on the computer, choose the create new port button, choose standard TCP/IP from the Type of Port pull-down menu, click Next, and then continue with step 8.
-put the IP Address or hostname of the printer
-check if the query for printer is set to automatic, then next
-choose have disk
-choose browse, then select where you save the driver
-choose the required printer model
confirm the name of the printer
-choose do not share, then next
-choose finish
for more information visit:
http://www.support.xerox.com/support/workcentre-m118-m118i/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Contact number:
English 1-800-821-2797
Spanish 1-800-821-7726
Hours of Support - 24 x 7
I hope this will help a lot.
thank you for choosing Fixya
Feb 27, 2011 | Xerox WorkCentre M118 PCL 6
Cómo cambiar el fusor de la xerox m118 y
I need a card red to be used in the Xerox M118 with connection RJ45, wich I can get, model or any specificacion
Jan 20, 2011 | Xerox WorkCentre M118 Laser Printer
Paper Tray won't read
That is a paper tray issue with that machine.
The tabs that are supposed to actuate the switches on the back of the tray either twist or get out of position.
You can try sliding the paper guides around, but more than likely the tray will need to be replaced.
Common problem on the 118
Jan 19, 2009 | Xerox WorkCentre M118 Black and White...
Xerox WorkCentre M118- media tray size wrong
Most likely you will have to replace the tray. There is a problem with those trays. Even when you have them set correct they mis read.
You can try twisting it, but they mis shape pretty easily.
Nov 18, 2008 | Xerox WorkCentre M118 Black and White...
CHANGE A m118 TONER
hey follow the instructions on the toner box,pliz follow them,if u fail get back here.
Sep 18, 2008 | Xerox WorkCentre M118 Black and White...
Xerox WorkCentre M118 Black and White Copier Logo
183 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
