Tmobile wing sim is missing, but the sim card works fine on my other phone, I put my wife sim card on the wing it is still saying sim card is missing?
SOURCE: T-mobile Wing - Touch screen stopped working
ok,
finally found the fix for this problem..
i had the same problem -
when you are the welcome screen align section
continue holding your stylus on the marker until marker moves to the next location
and continue this process with all four corners and the screen will go past the tap align screen
enjoy, glad i came across another forum for this problem
Posted on Sep 19, 2008
zohail
  • 1223 Answers
SOURCE: sim card missing for htc touch p3450
its a hard ware issue try putting a piece of paper over ur sim card to press it against the pins on the phone sometimes it gets loosen and does not detect sim cards or try restting the device as follows else go for service centre help but try these solutions first
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
Posted on Feb 20, 2009
SOURCE: HTC Tilt (Trouble Reading SIM Card)
I posted a little too early. There was one other trick I've used and I guess I should have started with that. The problem is indeed related to the SIM not getting enough downward pressure on the contacts to be recognized.
So I took a small strip of paper, about 3/8" by 1 1/4". I folded it three times. When you fold it one end will be closed and the other end will have the two edges of the paper that can open up. Using the open end will make it harder to slide under the bracket. So you will want to take the closed end and gently side it above the SIM card underneath the silver metal bracket that holds the SIM in place.
I used a post-it note as the paper but anything will do. It was working with just a double thickness but I wanted to be sure so I moved up to three layers. Depending on the tolerances of your phone you might be able to only do double layer and still be able to slide it in. Or you might need to go to four layers.
I hope this solves it for you.
/text for Google's indexes so others can find this: HTC Kaiser 8925, Cingular 8925, AT&T Tilt 8925, SIM Card is missing,
Posted on May 15, 2009
kdgaydos
  • 22 Answers
SOURCE: tmobile wing no signal
I have 3. suggestions for you:
1.You should do a "HARD" reset to get everything back to factory (warning: you will lose all of you saved information on the phone.)
2. Go into setting and set the "Network" settings to manual, then ask the phone to search for your Network.
3. Could also be a Tower issue. Call T-Mo and ask if they can chack signals and switch you to a different Tower.
Posted on Feb 05, 2010
  • 4 Answers
Yep I agree with the paper trick. My SIM card was not being recognized so after resetting my phone AND getting a new SIM card I finally folded up a small piece of tissue and pushed the cover down until I heard a little click and locked it as much as I could. Seems to work now! Hooray! Simple, but seems like a common problem with this phone.
Posted on Jun 04, 2010
Nokia 5800 xpressmusic. i just recived this new phone from a friend because he bought a new phone. i put my sim-card in it it asks me for my simcard code. it accepts the simcard code but than it says...
I'm assuming your both on the same network? If your both tmobile customers or AT&T it should work without problems.
If not. The phone needs to be unlocked. to be used with another sim card from a different company.
And to do that. Your friend can call his carrier he bought the phone from, request an unlock code, then unlock it that way, and you'll be able to use it just fine.
Only if your on either Tmobile or AT&T. No other sim cards will work.
Aug 28, 2011 | Nokia 5800 XpressMusic Smartphone
Invalid sim
1. (easyer way) When I got my Blackberry, I had to put it in a couple of times for it to work.
2. Buy a new sim card.
If this does not work, then check to see if it is unlocked.
Feb 04, 2010 | RIM BlackBerry Curve 8310 Smartphone
Changed tmobile sim card to a wing but contacts do not show
Before you remove the sim card from your old phone, you need to import all of your contacts from the old phone to your sim card. On most phones the contacts are stored on the phone, and not the sim card.
Feb 01, 2010 | T-Mobile Wing Smartphone
Phone says no service and nothing from sim card shows up????
I am a tmobile customer and it works for me. One thing I know to make sure your SIM card insert position. For SIM card slot at the bottom, make sure the gold-colored contact facing upward. For SIM card slot at the top, make sure gold-colored contact facing downward. At the first time, I put it in a wrong position and gave me the 'No service" error. Good luck
May 01, 2009 | Dual Electronics CECT P168 Cellular Phone
G1 Android Phone Factory RESET ISSUE
I want to run gprs into my Blackberry 8100.but the network is locked it is grameen phone network.How can I get this/
Apr 28, 2009 | HTC G1
Unlocking my Tmobile Wing
Yes. After unlock it, you can use it with any carrier that has SIM card.
Yes, I used my unlocked Tmobile wing oversea as well. (In Asia, cuz they use sim card as well, not sure about other area.)
Jan 24, 2009 | T-Mobile Wing™ Smartphone
Locked internet on my tmobile wing
You need to have the network setting setup on the phone by your carrier. even though the phone is unlocked the current network setting are for t-mobile. if your not using t-mobile most of that stuff wont work.
Jan 03, 2009 | T-Mobile Wing™ Smartphone
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
