Question about Panasonic SC-HT995W System
When we switch on our DVD home theater SC-HT995/SC-HT995W, it makes a loud humming noise for about 5-10 mins, then it stops. do you know why it is doing so or do we need to replace some parts?
Panasonic SC-HT locked , please help me open lock.
Posted on Nov 15, 2009
My avs 2000 makes a load hum
One of the 'cons' of the AVS 2000 is that it makes an audible 'hum' when switched on that can be heard during quieter moments. This shouldn't be overly loud though - If it is, I'd take the unit back for replacement / repair.
Jan 17, 2014 | Monster Pro AVS 2000 Automatic Voltage...
My Ht995 disk seems to run continously
Your opical unit is faulty,must be replace with a new one
Sep 07, 2012 | Panasonic SC-HT995W System
There is no sound coming from the speakers on the SC-HT900 dvd home theater sound system. It used to make a loud pop sound but then would still work. Now it does not make any sounds. The dvd will play...
May be a fuse inside blown , if it makes a loud pop that can take out a fuse, If you find one blown , replace with same type and try machine .Dont replace with higher rated fuse though , if it keeps blowing. Try using headphones and if you get sound , may be speakers.
pete
Nov 29, 2010 | Panasonic SC-HT900 System
Error F61 How to reset SC-HT995W system?
I'm sorry to say, but an F61 error can not be cleared by a reset. Please see the link below for an explanation of protect mode (F61 is Panasonic's version of protect). Usually the output amp pac will need to be replaced. This will cost between $75 and $100 for the part. Feel free to post any additional questions here.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Oct 19, 2010 | Panasonic SC-HT995W System
Panasonic SC-HT995 locked
check the fan, if its dusty clean it then run the player. If it works, your in luck. If the fans are moving and f61 still shows up, the D-amp IC is shortened ( inside you will see IC 5000/IC5200 / IC 5300, these needs to be replaced) its the one by the big cooling fins (behind the rear fan)
Nov 11, 2009 | Panasonic SC-HT995W System
Humming noise when Dvd plays
the motor that's spinning the dvd is bad. sorry you have to buy a new one if you don't want to hear the noise. hope this help
Dec 17, 2008 | Coby DVD-937 5.1 Channel DVD...
Panasonic SC-HT995W Home theatrer System
It's probably a ventilation fan that's making the noise. Locate it and see if you can clean out any dust or dirt in it.
Apr 30, 2017 | Panasonic SC-HT995W System
Panasonic SA-HT740
Think I got it. Check your fan. Power it on and see if the fan spins for a few seconds and then stops. This is why mine kept giving me the F61 code and powering down. Remove the cover and use an air duster on the fan. This may not be enough so if you must, remove the fan (two screws + 2 clips) and pop it out of its housing. Dust the blades off and gently pull the fan away from its center as if you were trying to separate the two. There should be about a 2 or 3 mm gap there now. Dust that out and I even sprayed some lube (WD40) in for good measure. Put it all back together and make sure the fan spins and is quiet when you power up your system.
So far it's working for me. Good luck!
Feb 16, 2008 | Panasonic SC-HT995W System
Humming noise
does it come out of all speakers or only certain ones?
Sep 12, 2007 | Panasonic SC-DK2 System
Panasonic SC-HT995W System Logo
208 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
