Question about Apple iPhone 3G Black Smartphone
Ihave just bought an iphone 3GS. I already had itunes installed as I have a touch. Now when I try to sync my iphone itunes freezes up. I have updated the software with latest. Can someone help?
Need to download iOS 5
to update to iOS 5 is only possible on iPhone 3GS / 4 / 4S with connecting the device to iTunes on a computer.
- Plug the iPhone to your computer and open up iTunes under devices click on your iPhone and then click on check for update.
latest iOS possible:
iPhone 1 = iOS 3.1.3
iPhone 3 = iOS 4.2
iPhone 3GS = iOS 6.1.6
iPhone 4 = iOS 7.1.2
iPhone 4S = iOS 8.1.2
iPhone 5 = iOS 8.1.2
need-download-ios-5-rb1lxwwedrgyiycdlihok4mn-5-0.jpg need-download-ios-5-rb1lxwwedrgyiycdlihok4mn-5-2.jpg need-download-ios-5-rb1lxwwedrgyiycdlihok4mn-5-5.jpg
Mar 19, 2014 | Cell Phones
How can i install an apps in my iphone 3gs using itunes
Plug iPhone into mac.Open iTunes.Download applications in iTunes.Set iPHone to sync applications with iTunes.
Sep 03, 2012 | Apple iPhone 3GS Back Case Black ...
I have an iphone 3GS 32G and when syncing photos I get a window saying Itunes has stoped working and is looking for a solution, it never finds one and I then need to close Itunes
If you are using Windows 7 then, right click on itunes icon and select Run As administrator. If this does not help then the only solution is to re-install Itunes.
P.S: Re-installing Itunes might loose your synced data on PC.
Sep 24, 2011 | Apple iPhone 3GS Black (16 GB)
I'm Upgrade my iPhone 3gs to 4.2.1 after install upgrade my iPhone gone no service then i break my iPhone to Jailbreak after that its become itune ...... now what can i do..... Plz help me
Got the same problem. Iphone 3gs, just updated to 4.2.1. Checked mute switch, sound settings, headphone jack. Makes sound for settings, texts and ipod mode. Tried resetting "all" on phone, restore/sync with iTunes. No avail.
Dec 18, 2010 | Apple iPhone 3GS Black (16 GB)
How to fix my iphone 3gs having icons of usb pointing up to the icon of itunes then slide emergency call?
your iphone needs to be synced with itunes or activated with your service provider.
1. open itunes on your computer
2. plug your iphone in to a usb port on your computer
3. follow the instructions on the screen
Nov 09, 2010 | Apple iPhone 3G
Can't sync my iPhone, due to error code 13019
This error is usually resolved by updating to the latest version of iTunes. Currently, it is iTunes 10.
If the error still occurs after that, deselect the syncing of voice memos, or better yet, remove the check on the Sync Music checkbox then click Apply and immediately right after the sync is finish, check the Sync Music checkbox again and click Apply.
For more iPhone / iPod touch tips like jailbreaking and unlocking, CLICK HERE or contact me personally at this email:
sale-47hyk-1863377234@craigslist.org or add me on Skype: ebayseller.ca
Sep 19, 2010 | Apple iPhone 3GS Black (16 GB)
Can't sync iPhone 3GS 3.1 with Vista iTunes 9.1
Zone Alarm and itunes do not play well together. ZA running will corrupt some pictures, apparently some music and does not allow the update of an ipod (touch) to occur. I have had to turn off ZA for any of the above to get either a clean install or adding (or removing) photos.
Oct 05, 2009 | Apple Audio Players & Recorders
After syncing my iphone 3GS all of my customer
just go to iTunes from your iphone. Log on to your account and try to download the rigtones again. It should say something like "Item already downloaded. Would you like to reinstall it ? Press OK." That should do it. At least it worked like this with apps i purchased, but had to download again :)
Jul 21, 2009 | Apple iPhone 3GS Black (16 GB)
How to sync .ipa files from comp to iphone thru itunes ?
when you sync the iPhone with the computer, iTunes will only add what is new, it will not delete your apps.
Setting Up Syncing You use iTunes on your computer to set up which items are synced. Make sure you have the most recent version of iTunes (On a PC, open iTunes and choose Help > Check for Updates. On a Mac, open iTunes and choose iTunes > Check for Updates.
Step 1: Connect iPhone or iPod touch
  1. Connect iPhone or iPod touch to your computer using the included cable. You can connect the cable from your computer directly to iPhone or iPod touch, or connect the cable from your computer to the Apple Universal Dock (available separately) and put iPhone or iPod touch in the dock. By default, iTunes opens automatically.
  2. Select iPhone or iPod touch in iTunes under Devices on the left hand side and click the Info tab.
Step 2: Set Up Which Items Are Synced Click the respective tabs in iTunes to specify which media and information you want synced from your computer to iPhone or iPod touch.
For more information about syncing iPhone with your computer see the iPhone User's Guide:
On your computer: click here to download and view "Chapter 1: Getting Started" in iPhone User Guide.
On iPhone: Tap Safari and view http://help.apple.com/iphone/guide/.
For more information about syncing iPod touch with your computer:
On your computer, click here to download and view "Chapter 1: Getting Started" in iPod touch User Guide.
On iPod touch: Tap Safari and view http://help.apple.com/ipodtouch/guide/.
Step 3: Sync iPhone or iPod touch Click Apply in the lower-right corner of the screen. Your computer syncs with iPhone or iPod touch according to your settings.
The first time you sync iPhone or iPod touch, you are asked if you want to merge data, replace data on the service, or replace the data on your computer. After that, anytime you connect iPhone or iPod touch to your computer, iTunes opens and syncs with iPhone or iPod touch according to your settings.
You can adjust sync settings anytime iPhone or iPod touch is connected to your computer. You can only connect and sync with one iPhone or iPod touch at the same time. If you need to sync more than one iPhone or iPod touch, disconnect one before connecting the other.
Note: Syncing won't delete any contact in Yahoo! Address Book that contains a Messenger ID, even if you've deleted the contact from your address book on iPhone or your computer. To delete a contact containing a Messenger ID, log in to your Yahoo! account online and delete the contact using Yahoo! Address Book.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Apple iPhone Smartphone
Can't sync ipod touch
If you haven't already, Uninstall your itunes and download a clean version.
install the clean version of itunes and try your ipod again.
you can get a clean version at www.apple.com/itunes/
It appears your install is corrupt.
also have you updated your touch recently.
if it is jailbroken you should be able to update it to a newer version.
If your version is to old, it maynot be compatible with the newer versions of itunes.
They are constantly trying to thwart the jailbreak and unlocked ipod and iphones.
Check your version and update to something newer if the re-install of itunes doesn't help.
Apr 05, 2009 | Apple iPod touch
Apple iPhone 3G Black  Smartphone Logo
61 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
