Question about Philips 170B4MG 17" LCD Monitor
Problem cant unscrew the case
  • 555 Answers
Please try to check what type of screw does it attached in that unit and find a screw driver that is exact match to that screw. Or try to see if it has only have a sliding opener that you don't need to used a screw but rather you have to slide it to open the case.
Thanks
Posted on Sep 10, 2009
  • 5,603 Answers
OFTEN in addition to screws there are little plastic grabbers that have to be released to open the cases.
I cant get grill to stay lite
What is the model name? Is it gas, electric or charcoal? If it is electric start it could be as simple as removing the push button start and replacing the batteries. This can usually be done by unscrewing the unit by hand. If that is nit the case a picture would be handy.
Aug 19, 2016 | Grilling
Paper jam inside printer cant pull too far inside.
Unscrew your printer, carefully remove the casing of the printer,be carefull also of the cord that connected on the case ...after you remove and the paper inside, same way back all that you remove
Sep 10, 2015 | Office Equipment & Supplies
I cant unscrew the bottom of the glass jar to clean it.
If u cannot unscrew it is a problem. People normally twist anti clockwise where as in the blenders to unscrew it is twisted clockwise.
Aug 11, 2014 | GE small appliance blenders 169106 User...
The belt has come off, how do you unscrew the 4 white screws ( white disc front about 1 inch in diameter with a 2 mm hole at centre to get the back off ? The Rubber belt was loose at the bottom of the...
There is no need to split the case simply turn it upside down be careful there are concrete blocks in there and they make it heavy. You can then work on the belt and the drum bearing which if you cant turn the drum sounds jammed if so you will need new drum bearings and to replace them you will have to split the case, but having seen it from the bottom it should be easier
Dec 03, 2012 | Zanussi ZWF1430W Front Load Washer
Removing bath drain
There are two types of tub drain stoppers for the delta brand - lift & turn and toe tap.
Lift and Turn:
The lift & turn stopper for the bathtub unscrews counterclockwise while in the full up position.
Toe Tap:
The toe tap stopper does also but if the cap may unscrew from it before the entire stopper comes out. In that case, there is a nut that is now exposed and can be accessed to unscrew the assembly.
If either of these is "spinning" without unscrewing, the threads are stripped and you would need to exert upward pressure while unscrewing in hopes of uncoupling this from the bath waste. If that doesn't work you would have to unscrew the bath waste flange from the drain pipe.
This will require access under the tub. I hope this answer the question for you. Thank you for using FIXYA. Jeff
Apr 09, 2010 | Delta Home
Cant take the front panel of 5sw398
You can but have to unscrew from within case, Although be careful dont want to break anything.
Jul 29, 2009 | Compaq Presario 5000 PC Desktop
I cant pull out the date/time pin on my luminox 3204. any suggestions?
On some watches - scuba usually - the crown has a rubber seal and that seal is engaged when the crown is screwed to the case. If your watch is like this, you need to unscrew the crown before you can pull out the stem. Twist the crown in a counterclockwise direction several turns. You will be able to tell when it is completely unscrewed because youwill feel spring tension. Pull out the stem to set the watch. When you finish, push the stem back in. Push against the spring tension and carefully thread the crown back onto the case. That should do it.
Jun 12, 2009 | Luminox Navy Seal Dive 3204 Wrist Watch
Need to clean the trap and cant undo it
Assuming the filter is at the front of washer, you need to keep trying to pull it out,and then push it back in, wiggling it about at the same time, having unscrewed it anti- clockwise first..
Just keep on doing this, as there is probably something stuck in the filter, which is preventing it coming out.
The worst that can happen is you break the filter, so it might be a good idea to have a spare one handy, just in case.
Please rate my fixya solution.
Thanks.
Feb 03, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
Trying to take the motor out a 18 v ryobi drill
You need to unscrew the drill casing to remove the motor. be carefull some parts may fall out. open slow and take note of where all parts go. you could also take a pic after opening as a reference.I am wondering why you would take it appart.
tom
Dec 12, 2008 | Drills
Electrolux contour 1100 flexihead. Z1436
You need to unscrew the screw at the back / base of the handle. The whole handle section will need to be slid backwards. Best way is to unscrew the screw on the rear approx 5 turns and then bump the end of the screwdriver. A few more turns then bump the end of the screwdriver again. The whole handle will eventually slide backwards and fall off. Then unscrew the two screws at the front (near switch) and the front switch cover plate will lift up (hinging at the top). This reveals the incoming wires etc.
Jun 18, 2007 | Electrolux Cleaner Lux 6000 Vacuum
Philips 170B4MG 17" LCD Monitor Logo
129 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
