Question about Wanlida Group MDVD-6838 DVD Player
Cannot get Optical Audio Output to Receiver
Connected MDVD to Harman-Kardon AVR-240 with Digital Optical cable. Configured both MDVD and AVR-240 for Optical Connection. No sound.
AVR-240 receives optical digital from another device fine on second optical port. Moved MDVD to second port using second cable ensuring it is not either the cable nor the optical port on the AVR-240. Still no sound.
Leaves me with MDVD output as the issue. What could be the problem?
2 Suggested Answers
SOURCE: MDVD-6838 and Panasonic Plasma TV incompatibilty
1 click SETUP(left just below the four arrow w/ enter button in the middle)
2 click DISPLAY
set tv system to AUTO
tv image to 16:9 WIDESCREEN
video setup (depend on the connection)
s video or RGB
Posted on Sep 06, 2009
Optical In
There is a control on the receiver for digital input - make sure it is set that way and not in the analog position.
Mar 30, 2014 | Harman Kardon AVR 140 Receiver
Connect pc
To connect your PC or Laptop to your Harman Kardon AVR 2600 you need to connect the HDMI cable output of your graphics card to one of the 4 HDMI inputs on the AVR 2600 receiver. The HDMI connector on the AVR 2600 labeled "HDMI Monitor" is on output and cannot be used as in input.
You need to select the corresponding input from the front of the AVR 2600 or using the remote. Next you need to make sure your have the HDMI output port selected on hour graphics card. This will probably not apply to your PC, but may require some settings from the function keys on your Laptop.
Note that you will probably need to also connect audio from your PC to your receiver as well. I would recommend you use HDMI cable with ver1.4 specification so that you have the best chance of getting audio over the HDMI. If you only get video, then run separate Toslink (optical) or RCA cables to get the audio to the system from the PC.
Jan 12, 2014 | Harman Kardon AVR 2600
How do you hook up a powered sub to Harman Kardon AVR 240 Receiver
On the rear, at the bottom left you have the Pre Out connectors - in there the Subwoofer is clearly labeled : use it.
Apr 22, 2011 | Harman Kardon AVR 240 Receiver
Which optical port in the back of the receiver goes to the optical port on the back of my HDTV
The manual talks about that.
Register and download the manual for free at
Any of the three INPUTS if you're bringing sound IN from the TV or elsewhere; or the lone OUTPUT if you want to send audio to the TV or elsewhere.
If the former, consider sourcing the audio from the REAL original source of the program you're watching, most likely a Cable Box. Less cabling and fewer connections to fail.
Apr 21, 2011 | Harman Kardon AVR 125 Receiver
I have a harmon kardon avr 120 and a samsung blu ray player.the audio is connected through the optical cable. the receiver however is only playing 2 channel audio. but my direct tv, which is also...
Check that the player's Dolby / DTS is enabled. Sometimes it is defaulted in the player to 2.0 / Stereo PCM. What model Samsung? Those Harman receivers are old favorites of mine...
Jan 06, 2011 | Harman Kardon AVR 120 Receiver
Fiber Optic input
No gots. The 3485 is pre-digital stereo-only.
From the manual, page 19
"You may have observed that the HK 3485 is not equipped with digital audio inputs or surround sound decoding. If you prefer the complete home theater experience, you may wish to consider purchasing a fullfeatured Harman Kardon AVR Series audio/video receiver. However, we hope you will find that using a DVD player with the HK 3485 in smaller settings, such as a bedroom or den, surpasses the audio performance of most televisions, including those with onboard stereo speakers."
Apr 13, 2010 | Harman Kardon AVR 240 Receiver
HK AVR-247 protect mode
This is an indication of an internal problem. Typically this is shorted output transistors. Expect a parts cost in the $25-$40 range for this repair.
Apr 06, 2010 | Harman Kardon AVR 240 Receiver
Audio problems using a Playstation 3
First try ensuring that "OPT 1, 2, or 3" function is selected depending which one you are using on the H/K 146 (see manual for selection instructions). Next please ensure that the PS3 audio out set to "optical" (Settings/sound settings/audio output settings/digital out+DD 5.1). That should help.
Dec 05, 2008 | Harman Kardon AVR 130 Receiver
Harman kardon avr-147
Hi Javis. This is perfectly normal ! This mode change is done because the receiver auto detects the digital audio signal and sets the receiver's DSP to decode the signal correctly. You can go into the OSD menu to bypass the auto detection of it, but it's not recommended at all ! You're getting the best audio quality by doing so. Thanks ! cheebster.
May 07, 2007 | Harman Kardon AVR 240 Receiver
Wanlida Group MDVD-6838 DVD Player Logo
59 people viewed this question
Top Wanlida Group Televison & Video Experts
Are you a Wanlida Group Televison and Video Expert? Answer questions, earn points and help others
