A piece of wire fell out of a bra and made its way through the little holes in the drum of my frigidaire affinity front load washer. it appears that about a million parts must be removed to access that spot. how do I get something out of there?
  • 11,896 Answers
You will have to remove back panel, remove agitator, then remove tub and bearings.
Posted on Sep 10, 2009
My Frigidaire affinity washer leaks water into the washer stand. Whenever I open the drawer after washing a couple of loads there's water in the drawer.
That's what I thought was wrong with mine to I had 1.75 in change and a piece of a wash clothe in the screen. I toke all that out and it still leaked. Took it apart further and found a piece of the weight that is made out of cement broke of and rubbed through the drum. That sounds like junk to me!!!
Oct 30, 2012 | Frigidaire ATF6000ES Front Load Washer
Bra wire went through holes in drum
Will cause damage remove heater element to see and pull out.
Apr 06, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer is putting holes in clothes
Check the inside of the drum when the machine is empty by feeling the entire surface with your hand. Take care as you are looking for something that's got stuck in one of the holes in the drum and is protruding into the drum, and this can often be a wire from an underwired bra!
If you find anything it should be removed by pulling it out carefull with a pair of pliers.
Mar 21, 2010 | Frigidaire ATF6000ES Front Load Washer
My wifes bra wire got stuck behind rubber gasket how do i get it out
You could remove the heater assembly , Thats how I go about it or try to fish out with thin wire between drum if you can feel/ see it....
Feb 22, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
We have a Zanussi model ZWF1621W washing machine and a piece of bra bone(wire) has gone through the holes in the drum and is stuck and rotating with the drum against the drum outer body how do we get it...
DONT RELEASE SEAL. Tilt machine and remove sump hose get someone to rotate drum in hope you can catch hold of wire. be careful of fingers on drum as they are like cheese grater. good luck this is best way and a little patience will do the job
Feb 12, 2010 | Zanussi ZWF1630 Front Load Washer
Holes in clothes
no yo may have a pin or needle type stuck in your dryer and when clothes go around they get stuck on it cheack drum very carefully
it may be a bra wire that jammed in between drum
Jun 17, 2009 | Electrolux Frigidaire Affinity AGQ8700FE...
My frigdaire front load washer ate my underwire bra wire
Do not attempt to remove a drum unless you have been trained to do so
First thing to do is to dump the back drain hose into a big dish and drain off all of the standing water
in the machines sump.
Remove the power !!
Tip the machine towards the back and front to get as much water out of it as possible
Tip the machine back agains a wall or a bench with a cloth protecting both surfaces
Put a wooden block underneath the front edge of the machine in case it falls on you
Get a torch and look at the bottom of the drum , there will be a big hose connected to the base with a jubilee clip or spring clip
Remove the clip and pull the hose off , place a cloth on the floor as there may still be some water in the hose , if you are lucky the wire will be either in the hose or in the sump that the hose is fixed to.
If the hose is connected to the rear of the drum tip the machine as far back as possible allowing the wire to fall within reach of the hole
If you cant see it get a magnetic retriever or a piece of bent coat hanger and go fishing.
If the hose is fitted to the front of the drum reverse the machine and lay it on its front or as far forward as possible , that way the wire will fall towards the hole
Jun 03, 2009 | Frigidaire ATF6000ES Front Load Washer
How do you remove underwire lodged between drum and outer case
hi to remove bra wire from between drums ? you might try this 1st ? if you diconnect water supply hoses and unplug power supply then remove rear panel from machine you will have access to the large rubber drain hose from outer drum down to discharge pump ? ok hose is held by spring wire clips both ends remove clips then hose you may find bra wire either in hose or close to drum drain if you need ? feel inside drom via drain hole ? or probe with a piece of coat hang wire ? you may even find the mysterious missing sock/ thong / etc when you disconnect the hose too?? any debri has to lay in bottom of outer drum and so a little patience will locate them using this method instead of removing the main front door sealto drum for access to same area also with rear panel off you can check belt tension ? hope this helps/inspires you ? best wishes from uk
Feb 26, 2009 | Hotpoint First Edition FEW12 Front Load...
I need to get access to the drum, how easy is this to strip out?
if you remove one of the paddles from inside the drum you may be able to grab it with long nose pliers or wire coathanger.
put a small screw driver into the paddle's 3rd hole from the front to press in a metal tab carefully not to bend it completely and pull the paddle towards the front and it will come off.
if the bra wire is up the back of the drum you may be able to grab it with removal of the heater element round the back of the machine at the bottom of the drum, loosen the 10mm bolt,(not off clompletely) and wiggle the heater out.
Feb 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
