Question about LG 42LC2D 42 in. LCD HDTV
Heads cut off and no score...
I bought a new 42" LG LCD TV and have had a few issues... first, the standard TV sound is terrible, and second, I am constantly having to to change the aspect ratio for each channel...a lot of heads cut off....  actually, right now i'm watching a football game and I can't see the score at the bottom of the screen.  I've tried both the HD and nonHD channels, and all aspect ratios but still no luck. any suggestions??
  • 1 more comment
  • bl5111 Sep 16, 2008
    I have the same problem. Heads cut off, can't see streaming news or subtitles at bottom of screen. Changing picture ratios does not help.
  • Anonymous Mar 19, 2014
    The image is too large to fit the screen tops of peoples heads are cut off. Aspect ratio is 16:9 Picture is standard. No other aspect raio changes it. Other tvs are ok, just this one. Comcast hd cable
  • Anonymous Mar 20, 2014
    I cannot see the score (bottom) when it is an HD channel.
    New Friend:
  • 57 Answers
Try your setting on your cable box (Screen position)
also maybe wide mode try switching to wide zoom good luck
Posted on Dec 10, 2007
LG LCD 42" sound but no picture
From this web site it says:
http://www.ehow.com/about_5379235_lg-television-problems.html
Powering Off
  • Many LG LCD television owners report having a problem with their televisions where the screen powers on, but then lasts only a few seconds or a few minutes before powering itself off again. The problem usually occurs with brand new televisions, and in this case is inside the television itself. If your television is powering off unexpectedly, contact LG so it can be serviced.
Read more: http://www.ehow.com/about_5379235_lg-television-problems.html#ixzz2qeK8T3SU
Jan 17, 2014 | LG 42LC2RR 42 in. HD-Ready LCD TV
Bought this 42" lcd April of 2012. When changing
Try unplugging set and or a box if used for a while and then plug power back to allow units to reboot to see if that will help--a box can cause odd issues.....
Nov 04, 2012 | Televison & Video
I have an lg tv and picture is to big....cuts the
If you are tuning from cable or satellite you need to change the settings in the picture menu look for options like "stretch" "autofit" etc. cycle through until desired picture is displayed, turn off widescreen setting if you can find it check the manual for options regarding this. If you have it attached to a computer you will need to change the resolution to something smaller like 1366X768 which is the standard 720p resolution for the smaller tv's If there is still a problem it may be
May 21, 2010 | LG 32LG30 32 in. LCD HDTV
My tv picture cuts off at the top, losing scores or tops of heads
Have you tried the "Aspect" button below the menu keys of the remote? Try "Full" Aspect and see if this improves things for you.
Hope this helps.
Apr 08, 2009 | JVC LT-42X688 42 in. LCD HDTV
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
42 in LG LCD TV turns off by itself
Found that TV started switching off by itself. Would try to come on..green light blinked for 2-3 seconds, tv came on (with picture and sound) for 1 or 2 seconds and then it would turn itself off. Found that the issue is with one channel only. If you are facing this issue....try quickly changing the channel the moment it comes on. You can do it either with remote or with the TV buttons directly. also in the same logic, if this is still happening, try changing the source to another (rgb-pc, av1, av2 etc). Basically change it from whatever input it is on currently, if changing the channels does not work. My symptom was that the tv made a loud 'TIK' 'TAK' sound which is louder than normal.
Jan 22, 2008 | LG 42LC2D 42 in. LCD HDTV
SCREEN AND POWER CUT
maybe the inverter board for the screen issue- the power issue seems to be LG has power board design flaw- basically last time I looked the power board is manufactured NOT by LG but by H&E ...who designs this stuff??
Dec 15, 2007 | LG 42LC2D 42 in. LCD HDTV
Sound problem!!!!
remove the cable box and try w the cable direct to the tv if the problem desapear bang you cable box need to be replace
Nov 29, 2007 | LG 42LC2D 42 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
1,344 people viewed this question
