Question about Maytag Neptune MAH5500B Front Load Washer
Washer won't drain maytag neptune washer MAH-3
    President:
  • 1,776 Answers
Check the drain line for kinks or obstructions. You can take a flashlight, remove the hose from the pump and look into the suction port of the pump. Check for anything clogging the pump. (like the occasional stray sock). Also check the pump impellers for broken or missing blades and ensure that the pump impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective and will need replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
Posted on Sep 10, 2009
4 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: E3 code showing sometimes on Neptune MAH-3
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Posted on Sep 23, 2009
SOURCE: On my Maytag Neptune MAH-3, the water is running non-stop
check plastic hose out side of tub to pressure switch
if ok replace pressure switch
Posted on Nov 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: softener dispenser will not drain
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Ou Maytag Neptune Washer MAH-3 will not drain.
This problem was answered a couple of years ago in detail. A search should produce it. Search the name Scruggs.
Sep 02, 2014 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG NEPTUNE WON'T SPIN OR DRAIN
If it can't drain, it shouldn't spin. Pump blocked? Broken pump? Level sensor broken?
Sep 05, 2012 | Maytag MAH6700AWW Neptune Front-Load...
The washer ran fine then stopped with water not draining. When I push the on button I get a buzz or humming noise .nothing moves. There is no error code.
Sounds as if you have something doen in the pump preventing it from draining and in doing so shutting the machine off as a safety action. I think you can actually access the pump from the rear of the machine. just unplug the machine, prepare to get wet, take the back of the machine off, take the lines off the pump and check for the blockage.
May 27, 2012 | Maytag MAH6700AWW Neptune Front-Load...
I have a maytag Neptune washer and it does not drain water, why is that?
the drain pump is plugged with foreign materials,you can access the sloped front "MAH" series from the front by removind 4 screws around the door perimeter and removing front panel by swinging outward toward you,others by removing rear access panel on the back side of the machine
May 11, 2012 | Maytag Washing Machines
Maytag Neptune MAH 3 will not drain
usually with this model
you have something clogging the pump
if u unplg it take it out
take off the back
the pump is right there
disconnect the hoses
you might just find a quarter
Oct 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Oct 12, 2009 | Maytag Neptune Washer
What is the cubic size of my maytag neptune MAH 1 washer
You can find the literature at this Maytag website if you have the correct model number.
Have a great day.
http://www.maytag.com/support/manuals_literature.jsp
Jul 05, 2009 | Maytag Neptune Washer
Maytag washer MAH 5500bww seems to run OK, but it does not pump out all the water(pumps out some) at the end of the cycles, churns remaining water during spin
Open the rear panel and remove the drain pump and clean it.
If there is nothing in the pump, check the drain motor for 18 ohms with a volt/ohm meter.
Not 18 ohms, replace the motor.
May 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
227 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
