Question about Brother MFC 7840W Printer
I can't figure out how to set up an Acer Aspire One netbook with Brother 7840W (multifunction) printer so it will work wireless.
    President:
  • 2,017 Answers
you can follow the instruction from this link http://www.brother-usa.com/ModelDocuments/Consumer/Network%20Users%20Manual/NUM_MFC_7345N_7440N_7840W_EN_1458.PDF
page no 19 to 29 will help you.
Posted on Sep 10, 2009
Tip
How to extend the life of a TN-330 drum kit for MFC-7840W Wireless Printer
If you have received any of the following messages on your Brother MFC-7840W wireless multifunction printer while utilizing the TN-330 drum kit then you may not have to replace your drum, at least not yet.
Drum End Soon
Drum Error
Toner Life End
Toner Low
I had this issue happen to me about 150 pages ago (some text, some pictures) and I still haven't replaced my drum after I executed this little trick.
Take your drum kit out of your printer (make sure you turn off and unplug any cables first)
Take some black electrical tape and cut a inch by inch square off.
Place the black tape over the optical port as shown in the picture below.
Then put the drum back into the printer, cable everything back up and turn the power on.
Your drum should last a long time beyond what was supposed to be a low toner.
Hopes this saves you some money.
on May 19, 2010 | Brother MFC 7840W Printer
I cannot connect wireless 7840w to my internet. i have tried some of the suggestions below but still end up with ng connection. Helpppp
first, Enable the WIFI on you printer, then install the driver in you computer, to option to choose before you finish the installation, First Select your connection, Choose Wireless Connection, not USB Cable
Jan 12, 2014 | Brother MFC-8870dw Wireless Multifunction...
Mfc 7840w wireless printer through bell router
How do I connect a Brother MFC 7840W printer to a Bell Network. Every time I try to connect, I get a connection NG message on the printer. Any help would be greatly appreciated
Nov 14, 2012 | Brother MFC-8870dw Wireless Multifunction...
Brother mfc-7840W not picking up wireless IP address
It is common, mainly because the MFC connection is lost to your PC. Are you able to print or scan from another wireless PC that you have? If yes, contact your network admin or router oem. If no, reset network card. Run the Setup Wireless Wizard. Make sure you have router info such as SSID, Network Security Key, Authentication Method (Open, Shared, WPA/WPA2-PSK), Encryption (None, WEP, AES, TKIP). Enter those info, it must be CASE SENSITIVE. Just in case you dont know your router info, contact your router oem.
For Advanced Users.1. Click your Wireless Icon at Task Tray2. Right-Click your Wireless Network Name3. Select Properties4. Go to Wireless Security Settings5. Take note of the settings that you have there and enter it again on your MFC
Goodluck! If you still need more assistance. Call us 1-877-Brother. :)
Jan 03, 2012 | Brother MFC 7840W Printer
We have Brother 7840w wireless printer. unable to connect to router - connection ng
Try:
Log into wifi router D-Link dir-615.
Change: security mode to WPA-Personal, WPA Mode to WPA Only, and Cipher Type to TKIP.
Then try connecting again.
Aug 09, 2011 | Brother MFC-8870dw Wireless Multifunction...
MFC-7840W Printer: need tp set the wireless setting, lost the instruc...
To setup your Brother MFC-7840W on a wireless network do the following:
Press Menu.
Scroll down to #5 LAN and hit OK
In the LAN submenu, scroll down to 2. WLAN and hit OK.
In the WLAN submenu select 2. Setup Wizard.
(The printer will search for the SSID of your network. If you are presented with multiple networks, select yours and hit OK.)
Depending whether you have setup a network key on your wireless network, you will have to choose the type of connection. Your options will be Open System, Shared key, and WPA/WPA2-PSK.
If you have a Shared Key or WPA/WPA2-PSK network, then you willhave to enter the key to connect. Open Key does not use a key to connect.
So for instance, if you selected WPA2-PSK you will then be asked to enter your passphrase key to connect to your wireless network.
May 16, 2010 | Brother MFC 7840W Printer
Brother MFC-7840W Printerwill only give me Scan To FTP option now
i had the same issue - was previously able to scan to a number of different formats, then switched modems, providers and then only the scan to ftp option came up.
took me about an hour to figure out the solution, but now it works
for windows users: * go to your control panel * go to the scanners & cameras section * your printer/scanner should show up here * right click on it and select 'properties' * select the network settings tab and then -- enter in the correct ip address here OR -- specify your machine by name (enter in name here)
hope this helps!
Jan 18, 2009 | Brother MFC 7840W Printer
Networking
It isn't a network printer since it only has a USB interface (no LAN port)
http://www.brother-usa.com/VirData/Content/MFC/ModelBrochures/Brochure_MFC240C.pdf
but you may purchase a print server if you want to share the printing function on your network (only the printing function can be shared). But some multifunction printers do not work with print servers due to driver issues. There are some users on the net who were able to make this work with an IOGEAR multifunction print server.
There is one Brother multifunction network printer that you may want to check:
http://www.amazon.com/Brother-MFC-7840W-Multifunction-Wireless-Interfaces/dp/B0016ZQ566/ref=dp_cp_ob_e_title_1
Dec 11, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC 7840W Printer Logo
146 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
