Question about Sony Dual Shock 3 Controller for PlayStation 3
Brought a new Dualshock 3 controller not working
All lights come on then two lights stay on as it should but no buttons work
Well like it happed to many people you have been ripped off its a fake controller buddy whats the model num on the back of your controller...
Posted on Sep 18, 2009
How do I replace the trigger spring on E9131
Trigger Spring replacement procedure - DualShock 4 - iFixit
https://www.ifixit.com/Answers/View/.../Trigger+Spring+replacement+procedure
Sep 4, 2015 - How do I replace the trigger springs ? - DualShock 4. SOLVED: How can I remove the magnetic triggers ...
27 Nov 2016
How to replace trigger spring? - Xbox One Wireless ...
1 answer
5 Aug 2016
More results from www.ifixit.com
Missing: e9131
DualShock 3 Trigger Buttons Replacement - iFixit
https://www.ifixit.com/Guide/DualShock+3+Trigger+Buttons+Replacement/3253 DualShock 3 Trigger Buttons Replacement: Replace a broken trigger button. Missing: e9131
New ps4 controller, where does trigger Spring go? - PlayStation Forums
https://community.playstation.com/content/pdc/.../new_ps4_controller-bc71.html ... Spring go? 10 replies. I've took apart controllers before but this must be a different model. The Spring doesn't sit on the small ledge inside the trigger. It has nowhere that I can see it can fit inside?? It's a glacier white controller so it's a newer model. Please someone help? BRIT-KO (Support MVP). 05/28/2016 - 11:25am.Missing:
replace the trigger spring on E9131 Google Search
Mar 07, 2018 | Garden
If i press the ps button on dualshock 3 controller all four lights on it are supposed to flash but it doesn't therefore the ps3 system cannot be turned on using it
Have you charged it? If you have plugged it in and no lights blink you may have a defective controller. If so check with Sony support/
Oct 05, 2012 | Sony Ps3 Sixaxis Wireless Dual Shock...
My dualshock 3 wont pair with my playstation , all the 4 lights flicker but the number 1 light dont stay lit.
Try attaching the controller via cable, then turn the controller on. This will set you to the #1 controller, then unplug the controller, it should stay on the #1. Then turn the controller off (hold PS button for 3 seconds) and then turn back on.
Oct 15, 2009 | Sony Dual Shock 3 Controller for...
My dualshock 3 controller wont connect to my ps3
i just got my new sony dualshock 3 controller (Japanese white version, i dont know if that matters) and when i try to connerct it without a USB the 4 lights will just flash and evenually just stop as if there was no ps3 there. If i connect it with a USB it will look as if it has connected, the ps3 will think it has but there is no input form the controller and instead of the first light going on the first and the second will go on. if anyone can give me any sort of help that would be great.
Sep 07, 2009 | Sony Playstation 3 (PS3) Console
All lights on Dualshock 3 blink 5 times, then do nothing.
On the back of you dualshock pad next to the L2 button there is a tiny small hole witch looks like it could be a screw hole ! well this is the reset button once you have pushed this you will be able to conect your pad to your usb cable and it work on your console again
Aug 30, 2009 | Sony Dual Shock 3 Controller for...
PS3 Controller will only work when plugged into the USB
I picked up the folling troubleshooting tips from the PlayStation Knowledge Center. I know it may seem silly or insulting; This is not my intention. Problems like this are usually just little things you're over-looking. Give thest tips a shot, one by one, and see if your solution is in here. If it isn't, message me back here & we'll try something else to get your controller working, ok? By the way... Is it a sixaxis controller or dualshock?
  • Verify if the SIXAXIS or DUALSHOCK 3 wireless controller works with the USB cable.
  • Verify that the SIXAXIS or DUALSHOCK 3 wireless controller's battery is charged.
  • Attempt to pair the SIXAXIS or DUALSHOCK 3 wireless controller to another PLAYSTATION 3 system. This helps determine whether the problem is with the system or the controller.
  • Attempt to connect another SIXAXIS or DUALSHOCK 3 wireless controller to the PLAYSTATION 3.
  • Move closer to the PLAYSTATION 3 system. The maximum range for Bluetooth is 30 feet.
  • Make sure you have less than seven Bluetooth peripherals paired with the PLAYSTATION 3.
  • Unplug any other USB device plugged into the system when pairing the SIXAXIS or DUALSHOCK 3 wireless controller.
May 19, 2009 | Sony Playstation 3 (PS3) Console
PS3 Dualshock Does not Charge.
hi i had this problem my controller would not charge although my head set would useing the same usb cable .i brought a new controller and tried two usb leads it was no different .this is the silly bit go and buy a new genuine ps3 usb cable and and i promise you all your problems will be solved .i have no idea y the cables stop working with only the conroller but they do i hope this helps all you people pulling your hair out trust me this will work
May 10, 2009 | Sony Dual Shock 3 Controller for...
Dualshock 3 sixaxis why does it always need to be plugged in
Once the controller is plugged in and connected to the console, hold down the PS button to select "turn off the system." Once the system has completed shutting down, unplug the controller and press the PS button. The console should turn on. If so, the controller will connect wirelessly. Unfortunately you'll have to do this with each controller but it works every time.
Feb 19, 2009 | Sony Dual Shock 3 Controller for...
Sony Dual Shock 3 Controller for PlayStation 3 Logo
412 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
