Question about Kenmore Washing Machines
The washer agitator is not that strong. - Kenmore Washing Machines
    Sergeant:
  • 222 Answers
Could be a stretched belt could be bad brakes not holding securely.
Posted on Sep 10, 2009
My front loader LG won't spin or wash, what can I do?
(1) If the washer won't spin or agitate the door latch should be checked. The door latch can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design, if faulty replace.
(2) If the washer won't spin or agitate the rotor assembly at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects.
Feb 11, 2015 | LG Washing Machines
My LG intellowasher 7kg WM -131 50 FB is not washing and keeps flashing 5E
If the washer won't agitate the stator or rotor assemblies at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects.
Nov 21, 2014 | LG Washing Machines
The drum doesn't want to vibrate
If the washer won't agitate or spin, then the stator or rotor assemblies at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects
Oct 21, 2014 | LG WM-1832C Front Load Washer
Drum willnot move on start.it just thumps
If the washer won't agitate the stator assembly at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects.
Sep 28, 2014 | LG WM2487H Front Load Washer
Take agitator apart
Can not take it apart but to remove it reach with both hands into the machine grip the agitator firmly at the bottom by getting both hands fingers under the bottom rim of the agitator. Give it a strong yank upwards (towards your body) to dislodge the agitator from the center shaft.
May 15, 2014 | Speed Queen AWS52NW Top Load Washer
Agitator will not spin easily from pully below or
transmission out buy new washer cost to great to repair 15 year old washer
Feb 03, 2010 | Maytag LAT3600A Top Load Washer
Whirlpool imperial spiral will not move
There should be a plastic cap that covers the agitator. You will need a strong knife or a flat-head screw driver, to remove the cap. There you will find a nut, that holds the agitator in place. Once you remove the nut, the agitator should slide right out with a little force.
Jan 17, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer agitates but makes a very loud noise
It sounds like the agitator teeth, that are plastic, are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, and check the circular teeth inside, to see if they are worn out. These plastic teeth are the agitator part of the washer, where as the spinning part is a metal set of teeth, at the bottom of the agitator. You see the metal teeth, when you take the agitator completely out. You will have to replace the agitator if the teeth are worn out.
Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Ge washer
Pull up sharply on the agitator to remove it from the shaft. Check the agitator mounting cup underneath it is probably stripped out. It is a replaceable part.
If the agitator is difficult to pull up,use a old strong leather belt under the agitator and pull it off using the belt.
Jan 11, 2009 | General Electric WHDSR316G Top Load Washer
Washing Machines Logo
12 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
