Sansui RZ6700AV receiver, centre channel cuts out
I have a Sansui RZ6700AV receiver (Dolby Digital/DTS). I have custom built speakers all 8ohm spec. Lately the centre channel cuts out at times and will not re-activate. The centre speaker is a smaller that the C fronts. Now it does not work at all with Dolby Digital and works occasionally with DTS. Would it some how be related to a impedance issue with the centre speaker? If I hook up one of the Rear surround speakers to centre channel it some times returns. Does anyone have the speaker channel specs for this model of amp?
4 Suggested Answers
SOURCE: No DTS-HDMA or Dolby TrueHD shown on display
DTS-HDMA and Dolby TrueHD cannot be passed to your receiver via bitstream on the PS3. DTS-HDMA cannot be decoded either so you're out of luck there.
Dolby TrueHD can be decoded internally on the PS3 assuming your firmware is up to date. Set the Blu-ray HDMI output to PCM and you can then pass it to your receiver.
If this doesnt work, do a system update on your PS3.
Posted on Jan 26, 2009
SOURCE: not showing DTS MASTEr OR DG True HD
In the menu is an option for switching master and true hd on. Standard its of and played als normal dts/dolby.
also: check the input (blu ray?): maybe it is set to only output no high def signals, so the amlifier doest recieve hd sound..
Igor
Posted on May 30, 2009
  • 3 Answers
SOURCE: DTS Master HD audio problem
Hey! Make shure your amp and blu-ray player output and input signals are set to "bitsteam" and you are useing HDMI and optical connections. I hooked up my Onkyo tx sr 506 integrated amp to a Samsung BD 1400 player and everthing worked perfectly right out of the box. Perhaps your amp can"t decode DTS HD Master or your blue ray doesn't support it although i think a firmware upgrade may accomplish this. Put on The Chronicles of Narnia Prince Caspian which will DEFAULT to DTS HD MASTER 7.1 and see if it works. It's an excellent source to test your system. Picture and audio recieved 5 stars from Home Theatre magaziene and like i said, either your amp, or player doesn't support it or your interconnects are keeping it from coming thru. HDMI and OPTICAL connects and check your set up for "bitstream" Remember what Todd Rundgren allways said,"Everything will work if you just let it!"
Posted on Jul 26, 2009
Code to change settings for Small loud speakers to large. Model No HT-F450K to HT-F455K models
Speaker size selection usually is part of receiver set up; the DVD player has nothing to do with it.
Jun 27, 2016 | Samsung HT-C650W DVD Home Theater System,...
UNABLE TO POWER UP
Check for a bad fuse inside the receiver.
Jun 20, 2015 | Yamaha AVENTAGE RX-A1030 3D A/V Receiver -...
I have a buzzing coming from my suuround sound speakers
Check to make sure your audio cables aren't touching any power cables. This will ensurethat you aren't getting signal interruption from latent overflow. Next, make sure you volume levels are correct. You could be overdriving the channel with too much output. Finally, make sure your speakers and/or source aren't next to anything with a strong radiation signal such as a transmitting device (2.4 GHz phone or microwave). Let me know if you've verified this and then we'll troubleshoot further. This sounds like interference to me.
Jan 02, 2015 | Onkyo HT-R2295 3D Ready A/V Receiver - 7.1...
Speakers not playing
The problem can be the cable or speakers or RX-V463 or settings. Need to check one by one.
Set the RX-V on DTS or Dolby Digital
1) Check Cables - connect the 2 (surround) cables from RXV's Centre Out to Centre speaker. If the Centre speaker works, then cables are ok.
2) Check speakers - Connect each Surround speaker to RXV's Centre out. If it works Speakers are ok.
3) Check RXV - Set it on DTS or Dolby Digital
Connect RXV's surround out (one at a time) L and R to the Centre speaker. If there is no sound, the problem could be RXV's settings (I need to read the manual).
Hope this helps.
Nov 20, 2013 | Yamaha RX-V463 Receiver
Someone is trying to sell me a Panasonic Home Theater system SC-HT900 from year 2005 for $200.00 Is it a good system, is it also good for listening to classic and jazz or just for movies? how is the CD...
here it is some tech info ..it is a fair price for 2.hand unit...
as ebay has the similar prices..it seems to be a good deal...
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Product Features and Technical Details
  • Dolby Digital, Dolby Pro Logic II, and DTS-decoding home theater receiver with 5 speakers and a powered subwoofer
  • 35 watts per channel x 4 "tallboy" speakers, 140 watts for the center channel, and 150 watts for the subwoofer
  • High-resolution DVD-Audio playback; JPEG, MP3, and WMA CD playback
  • Magnetic shielding for distortion-free placement near a TV or computer monitor
  • Includes digital FM/AM tuner and a universal remote control
Technical Details
  • Brand Name: Panasonic
  • Model: SC-HT900
  • Output Wattage: 390
  • Component Type: Home theater system
  • Audio Output Mode: Surround Sound
  • Surround Sound Effects: Super Surround Sound
  • DVD Type: DVD changer
  • Built In Decoder: Dolby Pro Logic II, Dolby Digital, DTS decoder
  • Remote Control Description: Universal remote control
  • Optical Digital Input: Yes
  • Audio Input: None
  • Tuner Technology: Digital
  • Radio Bands Supported: AM/FM
Jun 21, 2011 | Panasonic Home Theater System System
CANT GET MY TV TO WORK WITH DVD PLAYER
Connecting a DVD player to your stereo receiver (or television, if you don't have a receiver) involves making two basic connections: audio and video.
Audio
The first connection to make is for the audio portion of the signal. There will be several options depending on the receiver you have.
  • The best choice (if available) is either to use an optical (also called Tos-link) or coaxial (RCA) digital connection. These two choices are equal in quality. In order to use either of these, you will need to have both an output on the DVD player, and an input on the receiver. Only receivers with built-in Dolby Digital decoders will have this type of input.
    The audio outputs on a DVD player
  • If your receiver does not have a built-in Dolby Digital or DTS decoder, but is "Dolby Digital ready," look for the 5.1-channel Dolby or 5.1-channel DTS. This connection involves six cables, corresponding to different speaker channels: left front, center front, right front, left rear, right rear and subwoofer.
  • The last option to connect the two components is with analog RCA outputs. This is a two-cable connection, with one cable delivering the left speaker sound, and the other cable delivering the right. This connection will deliver only stereo sound, but it may be your only option if you are hooking up directly to a television, or if you have an old receiver with only two channels.
Now let's take a look at the video connection.
  • The best quality choice is to use component connection. This connection consists of three cables: color-labeled red, blue and green. The quality is superb. However, these connections only exist on extremely high-end receivers and television sets.
    The video outputs on a DVD player
  • The next option is s-video. One cable connects the DVD player to the receiver in this setup.
  • The last option, similar to the audio setup, is to use the analog RCA video output, usually color-labeled yellow on both ends. This will deliver the lowest quality, but will suffice for most older, analog televisions.
Jul 03, 2010 | Symphonic Televison & Video
Denon AVR-682 center channel has no output
You may have had the receiver set to "Stereo" mode, or Analog instead of "Digital" or "Auto" (automatically switches to digital when it detects a signal) modes. Also, setting it to "Direct" (2-channel from an analog source) could result in loss of center channel. Or your Surround Parameter dial (on the higher-end Denons, at least) could be set to a 2-channel mode.
Finally, if your digital inputs are incorrectly assigned (e.g., COAX1 instead of OPT1, or OPT2 instead of OPT1) for that source, the receiver will use the Analog signal which is stereo-only. You could get a center channel via Dolby Pro Logic II but it would be a "matrixed" signal, not the "real" center channel you could get via digital input using Dolby Digital or DTS.
(If all else fails, re-check your center channel speaker wire connections. It's very unlikely, but also possible, that either the receiver center channel amp or the speaker has failed.)
Feb 13, 2010 | Denon AVR-682 Receiver
Analog only
what cables are you using ?
if you are using anything but optical or coaxial
you will only get stereo sound
Mar 28, 2009 | JVC RX-5032 Dolby/DTS 5x100 Watts Receiver...
How to play dts/dolby digital on HK AVR5
I believe he avr-5 has 6 channel inputs, what you will need is a dolby digital 5.1 and DTS outboard surround sound processor, say an item as the Technics SH-AC500 decoder, a Harman Kardon Signature 2.1 DTS version outboard processor/preamp, and many others on the market by different manufactors, Run the discrete audio outputs from the Processor into the AVR 5`s 6 channel inputs, select 6 channel input or DVD inputs on the receivers selector and your good to go. Be sure you are playing Dolby Digital 5.1 or DTS encoded material.
Feb 08, 2009 | Harman Kardon AVR 100
TX-SR304 AV receiver
If you put DVD with Dolby Digital soundtruck it will show on your TX-SR304 Dolby Digital mode, and if you have DVD with DTS mode it will show DTS
Jan 17, 2009 | Onkyo TX-SR304 Receiver
170 people viewed this question
 Grubhead
Grubhead
