Question about Kenmore 94702 Front Load Stacked Washer / Dryer
Turn the switch and nothing happens on the front loading dryer.
  • 612 Answers
Reset the breaker first. If this does not fix the problem, you most likely have a bad thermal fuse inside the dryer. It could also be a bad door switch, broken element, bad thermal cut off. But I dont think so.
Please rate solution
Posted on Sep 10, 2009
  • James Hilton
    James Hilton Sep 11, 2009
    If you would like, I can explain how to get to the thermal fuse and how to check it to make sure that it's the problem. I'm 90% sure that's what it is. Let me know if you would like further help.
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Kenmore Dryers
Nothing happens when I push the start button to dry a load of clothes. I have checked the circuit breakers and the plug in and the door is securely closed.
There is a micro switch on the door to stop the dryer when you open the door during normal operation. Unplug the dryer and locate the switch by visually inspecting around were the door contacts the dryer and identify if you can remove the switch without opening the dryer top. If you cannot remove the switch from the front try to access the switch by lifting the top of the dryer cover off. Unplug one of the wires and touch the wire connector you removed to the other connector on the switch using electrical tape to insulate and hold it in place. Plug the dryer in and see if it works. If it does you need to order and replace the switch. If it does not the start switch could be bad and you will need to test it with an Ohm Meter which will be the safest way to test the switch.
Jan 21, 2010 | Whirlpool LEB6200 Electric Dryer
Maytag Neptune MDG4000BWW
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool duet dryer gew9250plo dryer will not turn on
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor (check wiring diagram heaver red wire for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Lights stay on constantly even when not running; does not run aft
That clip is necessary as it tells the dryer when the door is open and when the door is closed. you will have to get a new door switch.
Jul 04, 2009 | Dryers
Kenmore 600 Series gas dryer
trigger broken dryer will not turn on. I need a replacement. Where can I buy this part.
Nov 02, 2008 | Dryers
Smeg washer/dryer not filling
Check the pressure switch, aka water level switch. If this isn't the problem, it may be the water valve.
Mar 26, 2008 | Washing Machines
Dryer won't turn on
the heater element on the drier has gone short circuit.without a model no. its impossible to give more info.contact me on dazzie@blueyonder for more assistance.
Dec 29, 2007 | Dryers
Kenmore 94702 Front Load Stacked Washer / Dryer Logo
75 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
