Question about Pentair Minimax NT Heater
Minimax 400 heater not operational
Power light comes on but no pressure, heat or service light. burners seem clear and water pressure appears ok
    Champion:
  • 246 Answers
What is ok on the water pressure? th heater need from 40 to 60 gpm in order to work properly clean the filter and let me know
Posted on Sep 11, 2009
The fan in the heater turns on but the heater does not turn on.
Probably a bad circuit board. I have the same problem once the water gets above about 82 deg. I tried cleaning the filter and strainer, cleaning out the heat exchanger, replacing the temperature limit switches, bypassing the pressure switch, and cleaning the ashes off the burner, and none of these worked.
Jul 30, 2010 | Pentair Minimax NT Heater
I have a pentair minimax 400dv ,my heater burner comes on for a minute and then,the burner cuts off. The fan keeps running, the burner will ignite again. This will do this several times. Eventually the...
Cleaning the Thermal couple can work at times, however most times you will need to replace it. You may also be having an issue with the ignition control. You are in pretty deep now and it would seem like you are determined to save this heater, I would change them both.
http://www.parts4heating.com/Pool-Heaters-Pentair-MiniMax-NT-400-s/696.htm
Jun 30, 2017 | Pentair Minimax Ch 400,000 Btu Propane...
Not heating the pool water
The burners could be sooted, the burner orifices could be dirty or clogged. It would be similiar to an engine not running on all pistons. The power element could be bad and or stuck. Lastly, the gas pressure could need to be adjusted or is out of adjustment. Some of these are items you could might be able to diy depending on your handiness. Some require special tools. HTH
May 19, 2010 | Pentair Minimax NT Heater
Triton minimax 400 pool heater won't ignite
Make sure the gas valve is set to on and thermostats are set properly. Check the pressure switch and high limits for continuity.Check wires for signs of damage, etc..
Jun 27, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
I have a Mini Max 100 pool heater. The pilot
check pressure switch for proper adjustment and make sure filter is clean so system pressure is normal
Jun 07, 2009 | Pentair MiniMax 100 Aboveground 100,000...
Pentair Minimax NT 400 heater. fan keeps coming
Sounds like the controller is the problem. This is the circuit board that has the display and controls on it. You can swing that panel open and try tapping on the white plastic cover the controller is under that. This might get the fan relay to release but you will have to replace the controller it will stick again
Jun 06, 2009 | Pentair Minimax NT Heater
Pentair Minimax NT Heater Logo
334 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
