Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP 6110 All-in-one printer. USB connector on Printer needs replacing. How do I dismantle printer to get access to the USB interface board?
  • Italme Sep 10, 2009
    The above post is SPAM and hot helpful at all. I am after instructions on how to dismantle the printer to get access to the USB interface board. I do not need SPAM taking up my time and Internet traffic.
    Clarification the SPAM relates to the Solution 1# below. I have reported it as such.
How to connect?
if you conect via parallel interface make sure to install the driver for the printer. if you connect via USB the computer should recognize the printer automatically and install the driver. if it stays offline try to use the other interface or a new cable. if it doesn't help your printer may be faulty and you need to replace the formatter board
Jul 22, 2014 | HP LaserJet 1200 Printer
HP oficejet 6110 all-in-one usb connection lost
Try plugging it into a different USB port on your computer and see if the system redetects it. If not. try a different USB Cable. If that doesn't solve the problem, and since you ahve already done the uninstall and reinstall, you have a bad printer.
Apr 03, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Need instructions on how to install a HP 6110 Cartridge Return Belt. The belt came off but does not appear to be broken.
Hello HP 6110 Cartridge
Issue : installing Cartridge on HP 6110 Printer
Printer :Desk jet HP 6110
Analysis : it seems that you are trying for Replacing the print cartridges
Solution : Please try the following steps to replace which is very simple and easy. The most important part is to understand and then apply without fear..
1) Turn on the power of the printer
2) Lift the print carriage access door on the front of the unit
Observe : the print carriage will move into the middle of the access area.
3) Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch (You Need to Press Of force Single finger on the top of the Carriage Latch) and then pulling the lower section of the latch forward. Lift the latch.
4) Grasp the sides of the ink cartridge and pull the cartridge out to remove it.
5) NOW by
Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage.
Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch).
6) Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur.
7) Close the print cartridge access door..
Now check the by running a test print
Click Start , click Settings , and then click Printers .
Right-click the all-in-one print icon and click Properties
On the General tab of the Printer properties, click the Test Page option.
Try the above steps hope the best out of it
Happy new year
Jan 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Need instructions on how to dismantle a HP OfficeJet 6100 Printer to be able top remove the USB interface board. PLEASE Only valid real solutions NO SPAM. SPAMMERS WILL BE REPORTED
open the scanner cover then look for the screw on the four corners of the unit i think only four screw you can dismantle it. You have to use T10 screw. if you remove the screw,lift up the scanner gently to avoid destroying the flex cable of the scanner that is connected to the logic board.Good luck..
Sep 10, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Need driver for HP officejet 6110 all-in-one
You can download drivers and manual from the page below.
HP Officejet 6110 All-in-One Printer
After driver setup has finished unplug printer USB and install drivers, the software will tell you when to plug back the printer.
Set your printer as default when asked during installation.
Regards.
Feb 25, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Connecting my hpdeskjet 3820 to my new computer
no. you need to get a pci serial port card or go usb if the printer allows
Dec 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
What router do I use for the hp officejet 6110 All-in-one
You should put both computers under the same "groupwork" name .
to change this settings right click on MY COMPUTER the go to properties
then the go under the COMPUTER NAME tab. CHANGE the settings Look at PICTURE #1
When you choose the "workgroup" name make sure that you pick a unique name.youll probably want to use your name.look at picture #2.after changes are done your asked to restart once you have done this FIRST part let me know i can help you with the setup of the Nwetwork Printer.b07620b.jpgbdecea2.jpg
Nov 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Need a drwaing of how to dismantel the printer hp photosmart 7450
I posted some help on separating the 2 covers. I didn't do any further dismantling than that ..
Cheers,
Paul.
Nov 08, 2008 | HP Photosmart 7450 InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
49 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
