Question about Samsung MS1040BB Microwave Oven
Just quit. No power, no display....nothing
It is like the microwave is unplugged. It has no power at all. I checked the fuse box and made sure it was plugged into a powered outlet.
    Sergeant:
  • 222 Answers
There are several possible causes, check voltage at outlet
check the 20 amp bus fuse on the main board ohm out the cavity thermostat, replace the bad part
Posted on Sep 10, 2009
It just quit while cooking. Is there afuse in this microwave?
If the model number is correct, there is a 125V, 20 AMP line fuse inside the microwave. Its usually mounted at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line fuse is listed as item 12.
You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit.
Apr 27, 2010 | Maytag MMV1153A Microwave Oven
No lights - no power - DEAD! Worked fine an hour earlier now ... nothing. Check fuse in mains box - all OK - tried it plugged into another outlet... nothing.
Your unit is dead, mains are good, tried in other receptacles, still no power. You have a bad fuse inside the unit. Unplug. Remove the cover. Generally this requires removing all the screws on the back perimeter and lifting the cover up. Sometimes they stick due to old grease, etc. Somewhere in the area of where the power cord comes in or near the transformer there should be a small fuse in a holder. It is not a glass fuse and should be replaced with the same kind (ceramic) and value. This is important for future protection. You can get the fuse at www.mcmelectronics.com . Get a box of five for future problems. If this was the only problem your microwave should work. If it blows the new fuse you could have a shorted power transformer, bad high voltage diode, or a bad magnatron in that order. There could also be a short in the board with the display but that would be unusual. Let me know if you need anymore helpl
hardrocko
Thanks for using FixYa
Feb 26, 2010 | GE Microwave Ovens
Micro wave simply quit. How an I check to see if
The fuse is located inside the microwave. You will need to remove the front panel to get to it. It will be located on the black power wire inside the microwave and installed inline. Make sure that the microwwave is unplugged before removing the front panel. Once you locate the fuse inside you will need to remove it and test it with a continuity tester to see if it is blown. If it is make sure you replace the fuse with the same amp rating you found. If the new fuse blows again then there is an electrical short somewhere inside the microwave.
Dec 24, 2009 | Emerson MW8778 Microwave Oven
Panasonic Microwave NN-T993SF has no power. Was working and suddenly the power went out like it was unplugged. It is not our fuses or cord but something in the microwave itself. Is there a fuse or...
most microwaves do have an internal ceramic fuse either 15 amp or 20 amp the cover has to come off to locate it usually at the top just behind the control board. do not touch the high voltage capacitor as it holds a charge even when the unit is unplugged.
Nov 07, 2009 | Panasonic NN-T993SF Microwave Oven
Dead microwave, after power surge
look for a ceramic fuse in a fuse holder. probably 15 amp or 20 amp. if this is blown (and likely is) the micro won't work at all.
Oct 16, 2009 | Microwave Ovens
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson Microwave stopped working
Have 1 of 2 choices, the main fuse or the control board for the front switches and clock. primary of the small power transformer has opened. Unplug the unit and take case off and measure the fuse with an ohm meter. if u read 1 ohm or less then fuse is good. then measure across the main power plug tips. If read open then the power transformer is bad. Need to replace the board as not sure if transformer is available.
Jul 26, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave was ran for 5 minutes with nothin in it now no display
most have an internal fuse check it first if that is not it check the thermal fuse both parts run 10-15 dollars
Jun 30, 2009 | Maytag MMV4205 Microwave Oven
No power
The door switches are designed to prevent the unit from running while the door is open. You probably have a blown fuse, and it's a white or dark grey ceramic fuse of 15A or 20A, available from local big box stores or appliance parts stores. The fuse is usually located on the floor of the chassis behind the control panel, or mounted in the same area as the door switches. Also, I'm really curious how the door switch got stuck while cleaning? That sounds scary...
Nov 13, 2006 | Kenmore 62622 Microwave Oven
Samsung MS1040BB Microwave Oven Logo
303 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
