According to a separate posting I see the it may be a resistor or the pump.
1. How do I found out what is the problem? Whether it is the pump or resistor?
2. How do I get access to and get the part for the volume resistor r-11 on the control board.
3. Where can I get my hands on a service manual for the Maytag Neptune MAH3000AWW
571 people viewed this problem
This solution has been voted best by the Fixya Commnunity
First and foremost unplug the unit
remove back panel
remove hoses from pump (expect water have towels handy)
open pump by removing screws
remove foreign objects if any
check impeller blades to ensure that they arent worn down
rebuild and reinstall pump
or replace pump reconnect hoses, replace rear panel
you should be good to go
After wasching it did not pump out vater from the drum. When I opened Top cover, I found that electrical board is...
When it gets to the spin cycle it falshes this error code. We had this problem before and they replace a part and said...
My washing machine control board has a burnt resistor labelled R11. Do you know rhe value of this resistor?
Intermittently, we are receiving a "water outlet fault" indication. There ISstill water in the machine. I open the drain...
I have a Maytag Neptune washer,5500 series. It started like it had a out of balance load shaking bad and leaking from...
