Question about Lands Phones
I have two phone lines one is used for a fire panel other is used for personal use. fire line works, other is not. they were both fine sunday. i've looked at three panels and have counted over eight different colors. i am very confused
  • 74 Answers
I have a phone with gator clips on it, stoners call them roach clips, thats the way I test my phone lines, sounds like you need to pay the phone company
Posted on Sep 10, 2009
  • durantheman Sep 10, 2009
    if you have portable phones unplug all of them from the phone jacks then try a hard wired phone, one without a power cord you plug into the wall see if that works first
MagicJack used to work fine. But now the other person can't hear me. Why?
You cannot use the magicjack in this way. The magicjack is used to enable the telephone to be used instead of the computer.
Plug in the magic jack device when the internet connection is working and it should download the software to make it work.
Jun 04, 2012 | magicjack.com
I have two lines lit up that will not disconnect
when you press the line button it may say "in use" and the have a extension #. That will tell you which phone or port has seized it.
May 08, 2012 | Nortel T7316E 2-Line Corded Phone
I have a Lucent 18D in the office and all the lines are working except line 3 of one of the phones. All the other phones and lines in the office are working. I've made sure everything is plugged i
Sounds like the line 3 button on that set is programmed as something else. When you press feature 00 and the line 3 button what does the programming say on the screen?
Feb 22, 2012 | Lucent PARTNER18 Corded Phone
I bought a G1 off of eBay. I've had it maybe two weeks now. Whenever I send or receive a call, the person on the other line cannot hear me. I've tried restarting my phone, and that worked for a...
It can be microphone problem that is why the person you're trying to talked can't hear you,some can be done on software programming,other can be fix it by replacing the mic component. But i prefer to use your warranty card and get free charge of it,or if its no HTC service center near you,try to ask assistance to any mobile service shop preferably.DIY is not advisable for android phones,you might brake something and fixing this type of mobile is to complicated.
Jul 11, 2011 | HTC G1
Do i need a eol resistor for a fire bell on a three zone fire alarm controll pannel
Usually, No. Any sounder (or strobe) is a warning device, and not a sensor.
EOL resistors are to prevent tampering on sensor lines.
To date I've only found one system that actively monitors the sounder line to determine the presence of a load.
Usually, a printed installation diagram is included inside the control panel to indicate EOL requiremants. Failing this, Google for an installation manual for the specific model of control panel (indicated on the main printed circuit board).
Apr 23, 2011 | Hardware & Accessories
While switch on my blockberry 8520 phone it shows app error 523 and below it shows reset but my mobile is not open at all and also its automatically on /off please find
i have the same problem the phone was working fine on sunday i charged the battery and after the reboot the error message appeared. I
Jun 28, 2010 | RIM BlackBerry Curve 8520 Smartphone
Telephone disconnected from first alert professional alarm system
The phone wires run from directly from the telephone company connection to the alarm on the red and green. They return on the other two wires. These wires are hooked to your home phones. That's the UL way to do it. The alarm is supposed to be the first device on the telephone line. You can just run a phone line to the alarm panel. There probably is a diagram inside the cabinet door or a phone jack very near the alarm.
Apr 11, 2009 | First Alert SA302 Dual System Smoke...
Need to connect phone and fax machine to one phone jack
You have the wrong adapter probably. Most common types are single line splitters and will not work like you want. They only split line one and 2 gets blocked out as they only have 2 copper connector on the plug centered to get line 1 only. If you want to use an adapter you will need a 2 line splitter like this one:http://www.trianglecables.com/tellinsplitl.html
A simpler solution is to plug your fax into your phone. On top of your phone are multiple jacks labeled L1/L2, L2 only or L2/data. Plug your phone into the wall using the L1/L2 jack then plug your fax into the L2 jack and this will work fine and still allow you use of line 2 on your phone. If you don't want to hear the ring then set your fax machine to auto answer. Hope this helps you.
Mar 29, 2009 | RCA 25201RE1 Corded Phone
RCA 25205 Visys will not record message
Called the company. There is a misprint in the instructions.
In the section titled "Out-Going Announcement RECORD" on last step it says Press Exit to stop recording. It should have said Press Sel/Save.
I did this and it worked.
Repeat for Line 2 if you are doing both lines.
Next thing is to make sure you go right to the section titled "Configure Out-Going Announcement" and select the right type of message you want callers to hear for each line.
Worked like a charm and took 3 seconds to get 2 different personal messages on the machine.
Aug 07, 2008 | RCA 25205RE1 Phone
Vintage phones cannot dial out
Any standard phone should work, even phones made in 1800's should still work on a standard phone line.
I'm not sure what phone you have. The one listed in the question "M7310" is a business system phone and will ONLY work on the Nortel business phone system.
If you have standard home phones, my only suggestion (using the information supplied) is to check if the Tone/Pulse switch is set to tone... even though both should work.
Do you have phone service through a cable line?
May 28, 2008 | NorStar M7310 Phone
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
