Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Mowing Blades RZT 50
When the mowing blades are engaged they only spin at half throttle. At full throttle they stop or the deck jerks violently. What could be the problem?
You have a bad blade spindle, bearing or idle pulley. Note: with mower off see if you can turn each blade by hand. First remove deck blade belt. all should turn freely.
Posted on Sep 15, 2009
I have a spring thats off
Posted on Sep 10, 2009
Why would blades just stop when mowing with ex mark lazer Z (model lz25kc604) I had beeing mowing for about 6 hours. Then it just stopped
It sound like the PTO clutch has died.
Test your PTO clutch. It should have a resistance of 1.7 to 2.5 ohms.
Jul 27, 2014 | Garden
Why when riding along mowing and the blades just quit turning, belt is not off?
If you hit a bump too hard, I believe it's equipped with a shock sensor that shuts down the blades or if you slightly lift off the seat the blades will shut off. If this is the case simply stop and restart the blade switch. Hope this helps
Jun 08, 2014 | Mustang Rzt 50" Zero Turn Riding Lawn...
Tractor quits when engaging the blades
unhook clutch and see if blades stop turnig and then try engage clutch with the switch if motor stays running bad clutch
Jun 01, 2013 | Mtd Garden
Huskee model 287707 blades wont spin belt not broke or spinning?
check for power and ground at the connector that feeds the clutch this will tell you if its a switch or the clutch itself
May 23, 2012 | Garden
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
When I engage mowing deck,the engine wants to stall.
sounds like deck froze up check the auto stop s thet stop the pullies from spinning see if they realease also check your blades for debres caught in them , then check deck pullies shhould spin freely when belt off and stops away ? cold also be and ajustment problem?
Aug 31, 2009 | Garden
Mowing deck makes ticking noise when blades are engaged.
A FEW THINGS TO LOOK AT ARE ,1THE PULLY SHIELDSMAKE SURE THEY AREN'T BENT TO CLOSE TO THE PULLEY'S.2 THE PULLEY BEARING'S MAY BE WORE OUT AND TO BREAK .3LOOK UNDER THE DECK TO MAKE SURE YOU DIDN'T GET SOMETHING TRAPED IN THE CUTTING DECK.HOPE THIS HELPED.
Jun 11, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
552 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
