Question about Nokia 5800 XpressMusic Smartphone
Camera screen loses picture but still has settings etc. This happens regularly and can only be solved by turning off and on again MANY times until it works again.While it is not working it will also not show any videos(sound is heard)
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
I own a Fugifilm digital camera that is frozen
It swounds like the system battery may need replacing.
This is separate from the usual batteries that you change and charge up. look on the base of the camera to find a round disk with a groove in it. Inside is a button battery CR2032 or similar. This is the battery that controls all the setting you have set for brightness contrast number continuity etc etc. replace this noting the way it came out + up or down and i think your problem may be solved for abot $4.00
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Cameras
Canon Power Shot SD 400 Digital Elph - image not on screen
On most canon elph cameras you can either go through the menu and reset back to factory default and this might solve the black or white screen. If that does not work you should be able to hold the menu button down for several seconds until a reset prompt pops up. You will then click on yes for reset and this should completely reset the camera and the screen should be back to normal.
Jun 10, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
CAMERA TURNS ON FOR A SPLIT SECOND THEN SHUTS OFF
simply change the batteries as the batteries are unable to tale the load internal damage because of not using regularly.
May 30, 2009 | Kodak EasyShare Z1275 Digital Camera
My panasonic tz5 has started playing up. The lens moves in & out, will not focus & a message 'please turn camera off and on again' appears. This happens each time I want to use it. The battery is charged....
Same problem. At least for now, I solved problem, or at least camera is working again, by putting mode dial in "normal" (not A1) and holding down menu and down button (macro button) while turning camera on. Hope it works for you and continues to work for me.
Apr 18, 2009 | Panasonic DMC-TZ5 Digital Camera
No image in viewfinder or on screen
I found this solution on a different page and it fixed my camera that was having the same problem.
In the case where you get a black image, the following may be of help:
This is a common problem in older Canon S2 IS cameras, especially ones that have not been regularly used. What happens is that the lens iris gets stuck at a small aperture. Most often you can get function back. Here's how:
Turn the camera on in shooting mode.
Turn the mode selector to shutter priority ("Tv").
Use the four-way button on the back to set the shutter speed to 15 seconds. That's right, 15 seconds. (To do this you keep pressing the left direction on the four-way button until it goes from 1/1600 or whatever it might be all the way to 15")
Press the shutter release. Count to seven, then pop open the battery compartment.
Wait several seconds, then close the battery compartment.
You may need to repeat the above sequence several times to unstick the iris. If that does not accomplish it, you will likely have to send the camera in for repair.
Once you have it working again, you should use the camera regularly to keep it from sticking again.
This sounds like a pretty ghetto solution but it worked for me and I know it has worked for others. So before you go wasting your time writing letters, give this a shot.
Oct 17, 2008 | Canon PowerShot S2 IS Digital Camera
Sony Cyber-Shot camera problems
I read that if you bang the camera against your hand a couple of times it can fix it. I tried it and it fixed it until i turned the camera off and on again. Tell me how it works for you.
Mar 23, 2008 | Cameras
Lcd tv magnavox
You might have a timer set on the options menu. look under the sleep mode.
Mar 20, 2008 | Polaroid FLM-323B Television
Sony dsc-w50 flash going off before or after shutter has opened and closed
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and
Jan 20, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Not focusing
Do you hear any unusual friction noise while the lens assembly projects out.. if so then the traction assembly of your zoom barrel has developed mechanical obstruction, in which case it has to be serviced. Take it to the service centre and the problem will be solved. If the zoom assembly does not fully extent to its homing position, the camera retracts and lens and powers itself off. Enjoy
Aug 16, 2007 | Olympus FE-230 Digital Camera
Nokia 5800 XpressMusic Smartphone Logo
27 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
