Question about Water Heaters
Where can i find books about water heathers - Water Heaters
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Go to library, wikipedia, google, sales person or shoppe
vitally
Posted on Sep 10, 2009
Is this thermostat wiring correct for this Rheem water heater? also it only has one thermostat...shouldnt there be 2?
Heather, first know that most water heaters are 220 volts and are dangerous to work on unless you know that the power is off. Second it is hard to say any more without knowing the model number and the make. Third from the picture, a thermostat breaks the current in one side of the circuit and that appears to be depicted. There are usually TWO heating elements not thermostats.
Feb 09, 2017 | Rheem Water Heaters
Bosch 125b-ng water heather has low flame only
Did you check to make sure the shut off handle is on the on position?
Dec 19, 2012 | Bosch AquaStar Natural Gas Tankless Water...
How to tell which element is bad in a hot water heather , when the heather have two element.
if you have a multi-meter you can remove the cover plate and check for current flow through the element.
Aug 06, 2011 | Element Chromalox SG1207 430086 Electric...
RHeem 21v40-7 gas heather leaks on the top. Water comes out from all four connections: Cold water in connection, warm water out, rod dip, valve. Do i need to change it? Should I tightened the connections?...
You are sure it is LEAKING pater at all those 4 locations-- correct?
None of the water is from condensation, right?
If you have had pressure water leaks for many years-- then likely a lot of damage has been done to the insulation-- and the sheet metal outer liner?
Does the sheet metal 'skin' (outside jacket get real warm?-- if so, you are loosing a lot of energy -- Probably time to invest in a new, better insulated, and more efficient combustion burner-
and this time, Make sure there are NO LEAKS, when the installation is done!
Mack B
Jul 03, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Too hot wather/ thermostat problem
its 3 phase not 4 Your wired wrong one of those should be a nuetral or ground
May 10, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water heather does not com on when water is truned on wide open
when to local dist. got owners manuel which after installing 4 of these uints the person impersonating a plumber took with him. easy to understand tbl shooting. resolved tbl. thanks
Jan 05, 2010 | Noritz Commerical Tankless Water Heater...
Our electric water heater doesn't work.
make sure it is wired correctly, check circuit breaker, check breaker built on to element. If all fails, and it is determined your not getting power to it, you may need a electrician. Be careful. good luck.
Steve
Oct 11, 2009 | Rheem 65 GAL ELEC Water Heater 6YR Self...
No hot water
Is hot water present when opening the drain valve. Use a bucket to catch the water. Adjust thermostat from high to kow then prefered detting. Make sure hot water out line does not have a closed valve. If gas, ck pilot. If electric, elements may be damage if heater was powered up before or while initial filling.
May 11, 2009 | Water Heaters
A.O. Smith Water Heater Problems
someone has messed with the differential setting - so the water heats to correct temp but cools too low before coming on. get book -easy fix
Oct 26, 2008 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
